Old 08-21-2019, 10:45 AM   #1
They're boxy but good!
Location: See my real-time location on Maps: https://maps.app.goo.gl/xiryhjZzwpSvTtnn6
Default How much boost on flat top pistons?
I recently purchased a B23 to replace my exploded B21. It reportedly has flat top pistons at 10:1 CR. I realize I'm not going to be able to throw 25psi at it but hoping I can get to 15psi. Anyone have experience with this? I'm on MS2 extra so I can pull timing etc, and am using 100 octane non ethanol gas.
"Over the hump of Truth and through the flaming hoop!"
-S.B. Squarepants
Old 08-21-2019, 11:10 AM   #2
Dirty Rick
Dirty Rick's Avatar
10 to 1 CR with what head?
You can only make a flat top piston come up so far.....
Use a head that has not been milled and do not use a thin gasket.
Old 08-21-2019, 11:17 AM   #3
iHateVolvoPeople
Turn it up until it blows up, then install a new engine with 1 less psi.
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 254k
99' Camry A140E. 256k
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
Old 08-21-2019, 11:38 AM   #4
398 head, supposed to be a Canadian engine
Old 08-21-2019, 12:57 PM   #5
Broke4speed
Broke4speed's Avatar
I wouldn't worry about it. With enough octane, and a good tune, you will have no worries.
Old 08-21-2019, 01:39 PM   #6
Your PSI is irrelevant without context on what your manifold/cam/turbo/EMS/fuel type are.
Old 08-21-2019, 02:03 PM   #7
15 psi on blue 140 Av gas.
Old 08-21-2019, 02:08 PM   #8
Ipd turbo cam, td05-20g China Bay turbo, stock lh intake manifolds, 90+ exhaust manifold, 3"exhaust, microsquirt, 100 octane
Old 08-21-2019, 02:25 PM   #9
poulrais
poulrais's Avatar
All the boost...
1990, Volvo 740 16v +T
Old 08-21-2019, 05:49 PM   #10
Big intercooler? The high octane gas burns hotter so keeping it cooler will help a lot. If you have the large intercooler then maybe some water injection will help it live?
Maybe consider using a cylinder head with some work done so it flows through easier? This contributes less heat to the overall picture.
Old 08-21-2019, 09:45 PM   #11
John V, outside agitator
High octane gas and other low-specific heat fuels burn cooler and slower---hence their resistance to detonation...
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 08-21-2019, 09:57 PM   #12
2turbotoys
Salaminizer
2turbotoys's Avatar
I enjoy porting and gasket matching aluminum heads for some weird reason, hit me up if you want. I'll even do SS grooves Got a small portfolio of pics to show off if you are interested.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 08-22-2019, 03:10 PM   #13
After a lengthy conversation with John V last night, I'm going to take it all apart and check the bearings, pistons and CC the head to see what the actual c/r is. He said he might have some turbo pistons for it, if not I might open up the head and/or get a thick cometic to reduce the c/r.
Old 08-22-2019, 03:22 PM   #14
iHateVolvoPeople
He’s a good businessman, that’s for sure.
Old 08-22-2019, 06:53 PM   #15
I think my fellow dino Redwoord chair was posting in the wrong place ---the lost squirter thread about "oh dear 10,3 compression to which I answered :
A guy could deck the block till pistons were flush OR say 0,1mm aka .004" out, then unshroud the valves by enlarging the short ends of the combsution chamber to lower static compression thereby killing two birds with one stone: better flow around the valves on the short side and somewhat less scary compression.....
OR
I go back out in the garage and I dig thru all the pistons in boxes and see if i have 4 STD bore B23 turdboat pistons that have any life left in 'em... If I do then the guy could deck block for the desired "zero deck +0,1" and a little unshrouding for maybe a nice 8:1 comp which means he can give it some boost and an OK ignition curve on the yummie 91 okt soup he says is the best there is locally.,...
Guess I better wander back out there...
Tune in tomorrow, same bat channel, same bat station..
OK went out and check and looks like any B23T pistons got re-cycled... Found some B21 flat tops and 1 B21T piston...So
As regards flywheel I'm going thru the stack now..gonna find that OLD B21t pressureplate to confirm 100%
OK?
Old 08-22-2019, 08:36 PM   #16
Found one...dual pattern, confirmed B21T pattern will PM more
Old 08-22-2019, 08:47 PM   #17
Cool thanks! Pistons are even with the deck now. Bearings looked pretty good too.
Old 08-22-2019, 09:52 PM   #18
Looks good.
Old 08-23-2019, 09:28 AM   #19
redblockpowered
redblockpowered's Avatar
My experience has been that Volvo published CR has turned out to be pretty optimistic. No way to know until measuring but I'd love to see what the fabled "high compression" B23 actually turns out to be. If I recall correctly what really matters is the dynamic compression ratio, not static so you can protect yourself with a big cam (and pulling timing of course).
1991 245 B230FNA/M47 no thread: secret LeMons car technology abounds
1991 245 B230F/M47 no thread: very boring (320k!)
Old 08-26-2019, 04:43 PM   #20
I cc'd the head and it appears to be 49.7cc's. my thinnest feeler gauge .008" was a little tight, so I'm assuming John V is correct at the pistons being in .007" , this gives 10.94-1 on the summit calculator. I'm going to get the head skimmed and check it again. I'll probably order up a cometic thick enough to reduce the CR below 9-1. The pistons appear to be forged, but I'm no expert, I'll have the machinist look at one when I drop off the head.
Old 08-28-2019, 01:16 PM   #21
I ordered a .140" cometic, it should knock the c/r down to around 8.6-1, depending on how much comes off the head. Now my concern is getting the timing belt on.
Old 08-28-2019, 01:38 PM   #22
You will be giving up squish, which is actually worse...
Old 08-28-2019, 02:38 PM   #23
cosbySweater
cosbySweater's Avatar
this isn't the 60s, you have a after market ecu, just get it tuned and run the higher compression. it will be so much nicer to drive. no need to knock your compression into the ****ter
2005 v70r
2002 BMW 540i Msport 6speed
1995 Porsche 993
2013 VW Passat TDI
Old 08-28-2019, 07:59 PM   #24
Or do what Volvo did.
Old 08-29-2019, 09:07 AM   #25
iHateVolvoPeople
What did they do?
