Old 08-26-2019, 05:31 PM   #1
patrickstar
patrickstar's Avatar
Default Volvo 1031 flange to 1310 u-joint?
I'm trying to order a custom driveshaft and I'm struggling with the rear differential flange. I took measurements but can't find any adapters online. I was wondering what those of you with V8 or T5 swapped 240s did for the rear u-joint to flange
patrickstar is offline   Reply With Quote
Old 08-26-2019, 05:42 PM   #2
culberro
culberro's Avatar
Isn't the stock 240 flange for a 1310 u-joint?
Old 08-26-2019, 05:44 PM   #3
patrickstar
Oh god damn I'm dumb. Thanks, that explains why I couldn't find any adapters, it doesn't need any.
Old 08-26-2019, 06:20 PM   #4
They're boxy but good!
Location: See my real-time location on Maps: https://maps.app.goo.gl/xiryhjZzwpSvTtnn6
It's actually a 1300 they don't make adapters for it.
"Over the hump of Truth and through the flaming hoop!"
-S.B. Squarepants
Old 08-26-2019, 06:33 PM   #5
culberro
culberro's Avatar
Apparently after 89-ish they went to a non-standard u-joint. 88 and earlier appear to be 1310. I've done 3 different driveshafts, and all were on earlier cars using the 1310 u-joints.
Old 08-26-2019, 06:38 PM   #6
patrickstar
My car is an 83, and my bolt circle measurements line up to this 1310 to flange: https://www.dennysdriveshaft.com/p25...0_series_.html
Thanks for the insight on that. I'm still stressing about getting this driveshaft made
Old 08-26-2019, 06:50 PM   #7
culberro
culberro's Avatar
I was thinking that was the correct one. Small BCD and 3/8" bolt holes.
If anyone is ever looking for random DS parts, I have had great luck with Fort Wayne Clutch (and Dennys Drive Shaft). Lots of parts and dimensions: https://fortwayneclutch.com/part-cat...steel-flyokes/
Old 08-26-2019, 06:52 PM   #8
patrickstar
Any suggestions for custom driveshafts in the PNW? I'll be calling Six States in pasco today, just want some other opinions too
Old 08-26-2019, 07:46 PM   #9
https://www.onallcylinders.com/2017/...right-u-joint/
I'd do some careful measuring
Old 08-26-2019, 07:47 PM   #10
culberro
culberro's Avatar
6 States is usually pretty decent. I wouldn't sweat it.
In Portland we have: 6 States, Driveline Express (Potter Webster), and Driveline Services. I've known people that have used all of them multiple times with great success. My go-to is Driveline Express since they can usually do a rebuild/modify within 24 hours, and full custom shafts within a 2-3 days.
