Old 08-27-2019, 01:01 PM   #1
jjona5
Default torque plate for redblock around Houston
Anyone have a torque plate I could rent? I really dont want to buy one for one build. I have read people use the ford version of the 2.3l but I'd rather use the correct torque plate. I picked up yoshi rods and pistons I want to put in after I get my 6 speed swap buttoned up.
Also before I get scolded for not searching I did. I also asked deeworks about it and they don't rent I'd have to buy.
http://www.turbobricks.org/forums/sh...d.php?t=282535
jjona5 is offline   Reply With Quote
Old 08-27-2019, 01:36 PM   #2
kyote
Ridin' High & Sittin' Low
kyote's Avatar
Give Bobby @ Scroggins Machine a call.
-91 244 soon to be passed down
-14 F150 FX4 3.5 EcoBeast
Old 08-27-2019, 01:38 PM   #3
JohnMc
JohnMc's Avatar
Would something for a Ford 2.3 Lima engine work as well?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-27-2019, 02:45 PM   #4
gsellstr
gsellstr's Avatar
Yes John, it will.
Not sure why the concern over using the Ford plate vs. a 'correct' Volvo plate. The bore spacing, bore diameter, and bolt spacing is the same between the two. I laid a head gasket over the Ford one and it was spot on, even per my machinist's knowing eyes.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 08-27-2019, 03:11 PM   #5
jjona5
I found one to borrow.
