Old 08-27-2019, 09:38 PM   #1
90volvo
Default Mass Air Meter wiring +T
So Im down to the last of my check list of adding a T to my 90 240. My quetion is instead of adding to the MAF wiring so it reaches the passenger side. Can you just pull the wires back thru the harness on the firewall and then route it to the Passenger side? Has anybody trted this or is it to much of a pain. Thanks
Old 08-27-2019, 10:05 PM   #2
bobxyz
bobxyz's Avatar
Yes, you can pull them out of the tubing and move them to the other side. A hair dryer, or a hot day in the sun, helps if your tubing is old and stiff. I think you need to extend/run a separate ground wire because it's crimped to other ground wires near the original MAF.
Old 08-28-2019, 03:22 PM   #3
90volvo
yelp, I tried pull them threw but seemed impossible. Was a cool night. I soldered them but routed them across the front to the passenger side. They are hidden and have protection over them. Just fired it up and all seems great. Wow, what a job but it done except some loose ends and oil cooler will be next. Thanks for all the help Tbricks.
Old 08-29-2019, 12:36 PM   #4
basicbrick
you may not need the oil cooler, just more places for it to leak
good job! pictures always help if you are proud
98 P80 NA: sold
86 240 sedan m46 sold
92 245 wagon, owned 2x, sold
92 940T now has LS swap in Iowa
97 850 NA Wagon sold
89 244+T sold
93 945 sold
basicbrick is offline   Reply With Quote
Old 08-30-2019, 03:01 PM   #5
90volvo
Pics coming. So what’s everybody’s theory on oil cooler. I don’t like to complicate things. It’s almost worth running high dollar oil to avoid it. Anybody run oil temp gauge with out oil cooler?
Old 08-31-2019, 08:49 AM   #6
They're boxy but good!
Location: See my real-time location on Maps: https://maps.app.goo.gl/xiryhjZzwpSvTtnn6
I used the water cooled oil cooler off of a 940, you have to replace the hard pipe that goes from the water pump to the heater. It's easier to do with the exhaust manifold off, which you just bolted on.
"Over the hump of Truth and through the flaming hoop!"
-S.B. Squarepants
