Old 09-02-2019, 06:28 PM   #1
vwbusman66
Eisen-Stein
vwbusman66's Avatar
Default 240 radiator in a crossflow 140
So, today the radiator in the 142 decided to stop cooperating.
I'm poor as f*$k, and I've read that I can make a 240 radiator fit.
Does anybody have any pictures or info? How do you mount it, as it seems there are no tabs like the 140 rad.
1971 142 DD/beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 09-02-2019, 08:10 PM   #2
sksmith
sksmith's Avatar
No help, I only recall seeing them with B21/23/230 transplants.
But I'm sure zip-ties were standard.
Steve
Old 09-02-2019, 08:51 PM   #3
Old 09-02-2019, 09:41 PM   #4
vwbusman66
Eisen-Stein
vwbusman66's Avatar
Thanks Ken.
Old 09-02-2019, 10:20 PM   #5
They're boxy but good!
Location: See my real-time location on Maps: https://maps.app.goo.gl/xiryhjZzwpSvTtnn6
I have a wide 940 radiator in my 242.
"Over the hump of Truth and through the flaming hoop!"
-S.B. Squarepants
Old 09-02-2019, 11:14 PM   #6
Harry Tuttle
I did this last year. First I checked an all-metal rad and it was a little too wide to fit between the frame rails (just like I read on Tbricks). I then looked at a plastic-tank rad and noticed that one of the tanks tapers down toward the bottom, but had a reinforcing rib on the outside. After I cut off the rib, it fit between the rails.
After that, of course there were mounting issues to deal with. I don't have photos, maybe could get some tomorrow.
Originally Posted by dl242gt
It's always better to get into a turbo volvo and drive.
Old 09-02-2019, 11:17 PM   #7
gsellstr
gsellstr's Avatar
I looked into it as well, just chose to get mine recored. A local shop dropped in a nice 3 row brass radiator and put in a bung for a temp switch as well, for about $350. And, no plastic end tanks or aluminum cores.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 09-02-2019, 11:22 PM   #8
vwbusman66
Eisen-Stein
vwbusman66's Avatar
This would be greatly appreciated.
Old 09-02-2019, 11:23 PM   #9
Harry Tuttle
Yeah, I should add that I did it just to get the car running while I get the proper part cleaned and usable.
Old 09-03-2019, 10:59 PM   #10
Harry Tuttle
Here they are
In the first one you can see the taper in the tank and, if you look closely, the cut off rib. It is a little obscured by the foam I put on to keep it from getting banged around.
The second one shows the bracket up top, with more foam. The last one shows the little pan with bolt to fit the bottom grommet.
