Old 09-02-2019, 11:57 PM   #1
90volvo
Default injector?
Just did +T 90 Volvo 240. Heres my list parts
15g turbo set at 9lb curently
740 intercooler but have a klracing ordered.
upgraded fuel pump dont have specs.
3 inch exhaust free flow muffler
+90 manifold ported
bosch 830 injectors (330cc?)
AEM afr coming in mail.
manual boost controller onway
940 ECU and EZK
Vcam advanced 4 degrees
940T FPR
My goals- get as close to 300 hp as possible running on pump gas 91 octance is local. Yes this will be my limiting factor.
Question- what injectors would recommend. Be nice if I did have to deal with the resistor pack and can use factory fuel rail . I also have access to a 4 bar FPR. Yes, I have read probably 50 posts. But never really find an answer.
Old 09-03-2019, 03:08 AM   #2
Triebwerk
Hi,
Bosch 0280155830 - 380ccm (12 Ohm --> resistor pack mode necessary).
Enough juice for the 15g. Dont see 300hp with the 15g.
http://www.forums.turbobricks.com/sh...d.php?t=345062
regards Mathias
[Austria]
Triebwerk is offline   Reply With Quote
Old 09-03-2019, 08:20 AM   #3
90volvo
Originally Posted by Triebwerk View Post
Hi,
Ok. Thanks. Yelp kinda wondered what the limit was with 15g. I will upgrade but love how fast the 15g comes on.
Old 09-03-2019, 09:14 AM   #4
iHateVolvoPeople
15g isn’t gonna make 300hp, not without spinning it to death.
Have you heard about the green giant injectors?
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
'04 TSX 6MT, 210k
Old 09-03-2019, 10:14 AM   #5
soclosenotnear
Originally Posted by iHateVolvoPeople View Post
15g isnt gonna make 300hp, not without spinning it to death.
Yeah, Bosch injectors from an s60r/v70r will outflow a 15g. I had more than enough fuel with a 16t. Bypassing the resistor ballast thing is easy.
check my feedback here
Old 09-03-2019, 01:35 PM   #6
90volvo
So what kind of power did you make with the 15g? Thanks
Old 09-03-2019, 03:41 PM   #7
Fa182
Stage 1
Fa182's Avatar
I'm running a 16T at 12psi on my B230FT with KL Racing intercooler, T5 injectors (that actually flow almost the exact same as the stock green -804, just changed them because an old one was leaking - they both have plenty of flow for the 16T), TLAO chips, stock 2,5" exhaust.
Haven't been on a dyno but if I had to make a guess I'd say it's not more than around 190-210whp max.
Old 09-04-2019, 01:38 AM   #8
Triebwerk
A lot of posts and dyno info available here. You will find values from 180 to nearly 300 at the wheels.
http://turbobricks.org/forums/showthread.php?t=295269
Old 09-04-2019, 01:56 AM   #9
90volvo
Thanks appreciate it. Id be happy with 270 at engine.
Old 09-04-2019, 04:43 AM   #10
Triebwerk
http://forums.turbobricks.com/showthread.php?t=287202
Old 09-04-2019, 08:07 AM   #11
soclosenotnear
I strung that 16t out to 20psi. It felt strong. But probably closer to 200 then 300.
Old 09-04-2019, 01:57 PM   #12
90volvo
Gotcha. Think you guys are talking about wheel hp and Im refering to crank hp. Regardless the T really woke the car up. I appreciate the advice and help.
