Old 09-03-2019, 07:21 PM   #1
rb92673
Default 12 mm Fuel injection line
I upgraded to a Walbro HP pump in tank on my 85 740 and I want to upgrade the fuel line between the tank and the filter for high pressure. I can only find 1/2" for fuel injection and it slides onto the nipple on the tank without any friction. I am worried it will leak.
I have searched the Internets and also called Volvo, BMW, local auto parts, truck parts, repair shops and I am not finding anything 12mm or 7/16.
Any suggestions of somewhere I can order and receive ASAP?
Also, I am thinking of ditching the hard line between the tank and filter for less possible spots to leak, any problem with that?
This is a track only Lemons car.
Old 09-03-2019, 08:13 PM   #2
lummert
lummert's Avatar
1/2" comes out to 12.7 mm. Make sure it's rated for the pressure you intend to run and that it's rated for fuel. Perhaps the hard line can be replaced with 5/16" or 3/8" hard line.
Old 09-03-2019, 09:45 PM   #3
rb92673
The 1/2” hose I have is rated for 300 psi. It’s 12mm out of the gas tank
Old 09-03-2019, 09:48 PM   #4
The Librarian
https://www.belmetric.com/index.php?...xoC-EwQAvD_BwE
Old 09-03-2019, 10:35 PM   #5
turbotankshane
I used 1/2" push lock hose for the entire feed, hose clamps and no leaky
Old 09-03-2019, 11:24 PM   #6
rb92673
Have you used this for fuel injection pressure? It says 150 PSI, but it also says SAE J30R7 which is not for fuel injection.
Old 09-03-2019, 11:40 PM   #7
gsellstr
gsellstr's Avatar
Been running 1/2" Earls on mine for several years, with rail pressures as high as 80psi, running a single in-tank pump and straight E85. No issues at all, no leaks, just use GOOD hose clamps, not the cheap ****.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 09-03-2019, 11:46 PM   #8
rb92673
Ok, I'll go try and find good hose clamps and give it a shot. Thanks for the replies.
Old 09-04-2019, 12:21 AM   #9
white855T
https://rover.ebay.com/rover/0/0/0?m...2F362665378734
This is what I use. It's the correct 12 mm hose for fuel injection.
Old 09-04-2019, 01:00 AM   #10
Dan
Watching the World burn
Dan's Avatar
https://www.belmetric.com/smooth-hig...99oj6o3kti1ff0
1985 Chevy TPI V8 740.
Old 09-04-2019, 01:10 PM   #11
The Librarian
No, I haven't. I just saw that it was 12mm fuel hose rated for 150 psi but I suppose that could be a typo and should read 15.0 psi.
Old 09-04-2019, 01:33 PM   #12
rb92673
Thanks for all the suggestions. I ordered some of the BMW 12mm line off ebay. Always a helpful community.
Old 09-04-2019, 10:18 PM   #13
lummert
lummert's Avatar
Standard 1/2 inch fuel hose is rated at 25 psi.
