Old 09-05-2019, 09:07 AM   #1
klork
Default tdo4hl-14t to 19t upgrade?
Anyone ever upgrade a 14t to a 19t? Found this on ebay. I know probably all china but the 14t I have needs a rebuild as it has a lot of side to side play and in and out play.
https://www.ebay.com/itm/Mitsubishi-...UAAOSweW5VTX-J
Anyone ever use this and had any luck?
Looks like I will also need to buy a recirc valve as this doesn't have the bypass valve built in. This is going on my 940 turbo.
I would also be happy with a good used 16t or 18t angle flange turbo if anyone has one for sale.
klork is offline   Reply With Quote
Old 09-05-2019, 11:04 AM   #2
Fa182
Stage 1
Fa182's Avatar
Did you already swap the turbo before? The stock turbo on a 940 is a 13C.
IMHO, if your current turbo has lots of play already, I wouldn't get any of these ebay Chinesium kits.
You should be able to find a good used turbo on here pretty easily for almost TB$. Make a post in wanted section if nothing comes up here in your post.
It took 2 days to find one on here when I was looking for a 16T.
Old 09-05-2019, 11:37 AM   #3
klork
I was given a tdo4hl-14t. So working on fixing it up to replace the stock turbo. I already have a downpipe and full 3 inch exhaust to go with the angle flange turbo. I know I could rebuilt it for about $50 but I wouldn't mind something with a little more oomph since the 14t isn't a whole let better then the 13c.
Old 09-05-2019, 12:28 PM   #4
Fa182
Stage 1
Fa182's Avatar
Gotcha. If you already have the setup for an angled flange turbo though, I'd rather look for an angled flange 16T imho.
I put it on my 945T and it was a very nice improvement along with the KL Racing intercooler.
Old 09-05-2019, 12:59 PM   #5
DET17
Reformed SAABaholic
Full MITSU overhaul kit for the TD04 is around $99. I bought my 19t kit from ARD Tuning in Portland. Of course, I had the CHRA balanced afterwards.
Ignore the Chinesium, unless you want to wallow in misery. You pay for what you get.
Old 09-05-2019, 01:42 PM   #6
That kit looks pretty good to me.
I really like the design of the compressor housing. Lots of easy mounting options for a waste gate bracket for RWD clocking.
its not a crazy amount of labor to put it in a turbo and try it out. As long as the dims of the journal bearings are right it should be fine. If it were ball bearing components i wouldn't trust aftermarket
It doesn't have the CBV intergrated, which is a + if you are going external... but could be bad if you dont plan on that.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-05-2019, 02:44 PM   #7
klork
I would be perfectly fine with a 16t but I havnt found one for sale yet and looking to get this done fairly soon.
Old 09-05-2019, 02:48 PM   #8
klork
Also ard tuning seems to have everything on their website on back order. I ran across their website yesterday looking for stuff.
Old 09-05-2019, 02:48 PM   #9
tryingbe
Boosting along.
tryingbe's Avatar
Look closer, it's a TD04L-14T, not tdo4hl-14t.
The turbine wheel on the TD04L turbos are smaller than the ones on TD04HL turbos. I don't know if they have the same shaft size or shaft length.
Sell that TD04L-14T and get your self a cheap TD04HL-13T with angle housing if you want to upgrade the compressor side to a 19T.
https://www.ebay.com/itm/1999-2006-V...oAAOSwq-xdano~
85 GLH 367whp
00 Insight mpg > yours.
Old 09-05-2019, 09:26 PM   #10
55superbeetle
I put a flat flange volvo TDO4 on my sr20 swapped datsun. I got the billet wheel version 19t and a fancy mamba actuator. Didn't have anything balanced but I been ripping around on 20 pounds of boost for a few months without anything exploding.
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 09-05-2019, 10:07 PM   #11
Tfrasca
Tfrasca's Avatar
I had basically the same unbalanced turbo on my 142 for a year or so, and never had any issues. It's a great turbo, especially for a daily.
Old 09-06-2019, 01:05 PM   #12
turbochimp
Check car-part.com for local junkyard inventory if you are in the US. I bought a complete 13G with td-04hl angled hotside off the shelf for $35 and mated it to 19t cold side. I had to switch one the the studs to bolt (or vice-versa, I forgot) and use a smaller hex nut or something to get it on the manifold. You can find FWD application list here: http://www.swededemon.com/turbo/turbolist.html
I don't know flow numbers, but visually, the angled flange and wastegate is yuuuge compared to straight. You can weld a 3" vband straight to it or flange -if you are buying a flange make sure ID is full 3" - I had one made and welded vband to flange.
-not my fabbing
turbochimp is offline   Reply With Quote
Old 09-12-2019, 04:09 PM   #13
naterhater
naterhater's Avatar
You already have to rebuild the turbo in order to install the kit, so as long as you aren't trying to cheap out and reuse the old bearings then the play will be gone when you're done. and if it isn't the you need to figure out what piece you left out when you were putting it back together
"It's probably fine!"
"If you find yourself doing it a second time, do it right this time"
'93 940 Turbo thread:
http://forums.turbobricks.com/showthread.php?t=288116
naterhater is offline   Reply With Quote
Old 09-16-2019, 08:43 AM   #14
klork
Ended up just rebuilding the 14t. Ceramic coated the downpipe and the turbine housing so that should cut down on the heat in the engine bay tremendously.
