- Nov 12, 2002
Nice seat bracket, i really like the jigsaw approach to building brackets etc like this. Does the bolt head for the bolt between this and the other bracket have enough space?
For welding (and strength, although the bracket wont be the weakest link, probably the bolts or floor sheetmetal) I prefer to make the welds like pictured here:
https://lh5.googleusercontent.com/-...AAAAUM/uU-PH4pb6xI/w1143-h857-no/IMAG2744.jpg (small bracket i made for a machine in the workshop)
Not sure if there is room for this approach in your application but this way of constructing gives slightly cleaner/nicer parts with easier weld and sometimes less distortion.
I did have to grind one side of the carriage bolt head slightly to get it to clear that bracket. The otherside was fine (no angle to the adapter).
Great heads up on the welding, that's basically what I'm shooting for. Keep in mind this entire bracket is barely 25mm tall so not a lot of room to work in there.
