I keep thinking I should get a steel bellhousing for my LS/CD009 swap thing I've got going on now. I really should have pondered that more before buying an aluminum housing.
I do have a fidanza aluminum flywheel in my Toyota, it sees trips to 8250 rpm almost every time I drive it. I replaced the steel friction surface last time I did the clutch but probably didn't need to. Too bad they don't make something for old ass rwd Volvo's. I think it weighs 7.5 lbs or soA flat flywheel is less likely to blow than a dished unit for a few reasons. The flat geometry has less stress risers then the dished style. The lower weight has less inertial forces as well.
With a dished wheel, having a continuous dish contributes to keeping the unit structurally sound. If you have divisions between the bolt holes for lightening purposes it makes it unstable and can lead to problems.
Better off to have a flat flywheel and use individual pedestals like John V has done in the past then having floating islands that are integral to the unit.
They are both made from cast iron, which can both having problems. One nice thing about cast iron is wears better than steel.
When it comes to high performance flywheels, no one makes them from cast iron, its always steel.
What steel/billet flywheels are available with LH 2.4 sensor holes?
An aluminum flywheel is a different beast, its not made from cast so its much less likely to fragment and grenade... The pieces of metal also are much less dense so if it does let go... the fragments have less energy behind them and less ability to penetrate surfaces.
Aluminum can have its own failure methods but exploding is rarely one of them from what i have seen (i'm sure someone will correct me if i'm mistaken)
