John242Ti
LH-Jet & Carb Free Zone
- May 19, 2003
- Duvall, WA
Getting it prepped for slumber. Got the interior wiped down, now I just have to dust and detail the outside before I throw the cover over it.
20181112_081143 by D H, on Flickr
My favorite 7/9 wagon on here.i thought you did a manual swap?
How does that rear dust deflector mount? Screwed in? Clamped in on the tailgate?
Got my new 205/70 R15’s mounted.
If she said yes to a 740, she's brave.Is that good or bad?
1994 945T - Installed interior trim pieces from a '95+ 960 as well as leather seats from a 1994 960 as they are higher quality than those found in the 940. Also has wood trim from a 1998 European 940.
Have been slowly modifying it with IPD sway bars, strut braces, overload rear springs, Bilstein HD shocks, aluminum front control arms w/ Super Pro bushings, 16T turbo,IPD cam, modified exhaust manifold, early 960 oil cooler ( under radiator )so installed early style oil cooler / filter adapter with custom fabricated oil lines, might chip the ECUs, enlarge the exhaust and find a rear spoiler.Has the late 960 tailgate handle, tail lights and wiper and a set of door handles waiting to be installed, assuming I can get away with it as a Collector car. Have been putting off purchasing a pair of Euro signal lenses so that I can install the Euro headlights I have had stored for two years, about time I got rid of those almost useless plastic DOT versions!
Super clean 945t. Looks great!
Very cool. Wish I could find one of those over here! Most of the ones I've seen are for SUVs and drill through the tailgate...The bracket is a narrow U-shape that folds over the upper edge of the tailgate and is held in place by a small set screw.
