Old 12-15-2006, 04:20 AM   #1
the poi
Has been
the poi's Avatar
Default 960=850!
Right front of the ol' 960 right? New brake rotors right?
But no! I was doing the CV joint on my sister's 850 ( ), and had the brake hardware off, and figured, what the hell, right? So ya, right there is an 850 rotor (which as far as I can tell, is identical to the 960 rotor) on the 960 spindle with the 850 brake mount (which mounts the 850 caliper). In other words, any 850 BBKs will bolt right onto a 960. Woo!
Old 12-15-2006, 04:37 AM   #2
mAydAy
Fabricatin'
mAydAy's Avatar
Sweeeeeeeet.
Gotta love it when there are (relatively) a lot of new options all of a sudden...
Originally Posted by KLowD9x View Post
As long as I can sit in the corner and watch you get it on with an admin while I masturbate with nothing but tears in my hand, I will be happy.
mAydAy is offline   Reply With Quote
Old 12-15-2006, 08:49 AM   #3
Chris_R
Kickin' rocks in sandals
Chris_R's Avatar
Only takes about 2 bucks worth of washers to make the 850 brakes bolt up to a 740 too.
Them thar is a pair of 302mm rotors (yes, I know they are rusty!)
Do the 960s have the FWD offset for the wheels?
Ermergherd!! Erm gernner kerhm!!
1995 964 (Silver)
1992 944Ti (White)
1996 965 (Burgundy) - Scrap
1994 945 Ti (Black) - Sirius Black Scrap
1992 944 GL (Black) - Killed by drunk driver
1988 745Ti (Silver) - Sold
Originally Posted by TurboBrickMan View Post
Long story short I found out she's a squirter.
Chris_R is offline   Reply With Quote
Old 12-15-2006, 08:59 AM   #4
thelostartof
unbalanced chemical
thelostartof's Avatar
the 95+ 960's have the fwd offset
and hm who wants to loan me some $ to get a BBK
Old 12-15-2006, 09:00 AM   #5
volvo944ti
ok i've been sayign this for liek 2 years now. s90 and 95+ 960 use 850 rotors. and 940 jumbo calipers and yes they use the 940 jumbo caliper brake mount. i had s90/960 front knuckles and struts in my 940 so iknow from experience! and yes all 95 + 960/90 series are frotn wheel drive offset rear wheel drive cars!
what happens is since the 940 control arm is shorter you throw off camber. know what rack does teh 960 use. if we have control arms make up to correct ti and the 960 uses teh late 940 koyo rack we may be able to use teh 960 innter and outer tie rods and custom control arms to bolt everythign up peachy keen.
volvo944ti is offline   Reply With Quote
Old 12-15-2006, 02:31 PM   #6
ELM
I thought this was common knowledge... late 960 uses the same rotors as the 850 and have FWD offset = huge backspacing.
ELM is offline   Reply With Quote
Old 12-15-2006, 03:29 PM   #7
benflynn
bigpimpin740t@yahoo.com
benflynn's Avatar
what dose this mean to 700s? if anything. i will be looking into some better stopers after the tranny swapp, long live ecomerce!
85 744 Turbo F+T big valved531, stg5 cam, msns, m47, sways, bills, 53mm t3/t4 9lb flywheel, dual 044s, 80lbs, npr og
benflynn is offline   Reply With Quote
Old 12-15-2006, 03:50 PM   #8
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Alright boys, time to order some Stoptechs
Old 12-15-2006, 04:05 PM   #9
tjts1
tjts1's Avatar
Can you elaborate on your setup? Did you use the washers to back space the rotors or for the calipers? Did all 850s use 302mm rotors? Any more pics?
thanks
Greed is good.
tits for president
tjts1 is offline   Reply With Quote
Old 12-15-2006, 06:30 PM   #10
the poi
Has been
the poi's Avatar
thats the plan... after, well, you know....engine, suspension, seats, and everything else, hee
Old 12-15-2006, 06:40 PM   #11
The Aspirator
It's a girl!
The Aspirator's Avatar
Stoptechs are stupid. And by that I mean STOOOOOPID. My neck still hurts from riding in your car and driving Carson's car with the stoptechs, they're so damn grippy!
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 12-15-2006, 06:41 PM   #12
Chris_R
Chris_R's Avatar
thanks
The pics all turned out crappy. The washers were used to space the bracket further outboard. IIRC none of the 850s came with the 302 kit. Some of the *70 did though.
302s w/o spacers:
For the spacers I ended up just buying pairs of various large washers at ACE and tried mixing/matching til I got the bracket centered on the rotor.
Old 12-15-2006, 08:02 PM   #13
socalsean
back in the game
socalsean's Avatar
I have a slightly used set of Brembo calipers, brackets, lines, and 2 piece rotors for a 850 at my work. I could probably give them away for cost +10%.
socalsean is offline   Reply With Quote
Old 12-16-2006, 05:41 PM   #14
MrDoug
"Forty-threee dollars"
MrDoug's Avatar
I assume the S70 calipers & rotors work for this swap also. Is it worth doing with the 280mm rotors & caliper brackets, or should I hold out for a set of 302's?
MrDoug is offline   Reply With Quote
Old 12-16-2006, 11:53 PM   #15
Chris_R
Chris_R's Avatar
You have a bigger piston with the s70 system, but it's just one piston instead of the 2 on the 740. The 280mm rotors are just a hair bigger - my 280 bracket wouldn't quite bolt up, but it was REALLY close.
It would be ok if you already had the parts - and it would make a 302mm swap that much easier later on.
Old 12-16-2006, 11:57 PM   #16
Hank Scorpio
And those were with ****ty ass pads. The Porsches outstopped them "stock for stock" in terms of pads. The next set I try should be ALOT more fun
302s w/o spacers:
http://i22.photobucket.com/albums/b3...2/100_0324.jpg
Glad you finally just took my advice and raided the hardware store! So what did it end up being? About a 1/4"?
Old 12-17-2006, 12:01 AM   #17
Chris_R
Chris_R's Avatar
Slightly less really. Want me to send you a set? Maybe you can offer proper spacers - or do you think the washers will do the job safely?
Old 12-17-2006, 12:11 AM   #18
Hank Scorpio
they will do the job just fine. Just mic em and let me know what the final thickness was
Old 12-17-2006, 12:53 AM   #19
the poi
Has been
the poi's Avatar
You can get actual "spacers" from mcmaster for just a bit more. I'm using some to space out my timing belt tensioner--its good for some really accurate spacing
Old 12-17-2006, 01:47 AM   #20
MrDoug
MrDoug's Avatar
Are the S/V 70 T5's more likely to have the 302mm brakes? Or is it just a random thing? I have a 90 740 turbo, am I better off with the 940 "jumbo" brakes or the S70 302mm?
Old 12-17-2006, 04:58 AM   #21
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
from the ebc catalogue you can get the disc heights, basically how far from the outer face of the hub section to the back of the disc.
i think jumbo 940's are 56mm, 850/960 (94+) are 51mm with the 302's being 50mm which is why you need to space the caliper bracket out 6mm for the 302's
do wonder about S80 brackets, are they same bolt spacing as those had 305's which are 51mm tall so would need 5mm of washers.
MikeHardy is offline   Reply With Quote
Old 12-17-2006, 04:31 PM   #22
tjts1
tjts1's Avatar
Does the 302mm rotor and caliper fit in a 15" wheel?
Old 12-17-2006, 05:12 PM   #23
MikeHardy
MikeHardy's Avatar
i think that might unlikely seen as volvo colombo wheel doesn't fit. but it is only 11.89" so would depend on the inner layout of the wheel.
Old 12-17-2006, 05:38 PM   #24
BB-Q
BB-Q's Avatar
Hmm, wonder if I can get S80 brakes inside my 17" C70 wheels on my 945?
Originally Posted by foggyjames View Post
The man is a pimp, and a fast one at that...
Originally Posted by frpe82 View Post
He's got that "crazy Mark" look in his eyes...........
1992 245 SE B200F, M47, Low and painfully slow.......
v8volvo240.com
BB-Q is offline   Reply With Quote
Old 12-17-2006, 05:42 PM   #25
MikeHardy
MikeHardy's Avatar
if S80 brackets do bolt on. then they should fit fine with some 5mm spacers
