red_rocket
- Jun 3, 2015
- Arizona
I have a 1997 S90. When I go over speed bumps, there is a clunk. I believe the clunk is coming from the right/front of the car, but don't know for sure. I've checked the tie rod ends, ball joints, wheel bearings, and control arm bushings. Everything looks ok. I also checked to make sure all the bolts/nuts are tight. They are. The struts and strut mounts were replaced a few years ago. Is there a way to check these? Are there any other components that I should check?
