Old 08-15-2010, 08:53 PM   #1
BoostedSwede
Masshole
BoostedSwede's Avatar
Default So sick of this. Strut mount problems.
Hi all...
This is on my 1991 740 with Bilstein HDs and IPD lowering springs. Alright, I replaced my DEAD strut mounts with some used original Volvo mounts (rubber was perfect), and brand new SKF brand strut bearings (I've heard they are the best).
Now, I get lots of low-speed clunking noises, and I have lots of binding and creaking noises when turning the steering wheel back and forth at a stop. If I grab the top of the tire while the car is parked and shake it back and forth, I can hear something clunking up in the area of the strut mount.
Any ideas what this could be before I tear the front end apart again? Please tell me the bearings aren't faulty...I don't want to have to return them.
- 2001 Saab 9-3 SE -
- 2001 Volvo S60 2.4T -
BoostedSwede is offline   Reply With Quote
Old 08-15-2010, 08:56 PM   #2
Poik
Backwards Turbo
Poik's Avatar
Did you forget to install the metal piece that goes between the rubber/spring and the bearing?
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 08-15-2010, 09:11 PM   #3
peehound
"Arf" she said.
Umm...
The later 740 strut bearings are bullet proof.
Nothing exceeds like excess.
peehound is offline   Reply With Quote
Old 08-15-2010, 10:31 PM   #4
TestPoint
TestPoint's Avatar
Check the tightness of the large stamped steel 'nut' that retains the strut cartridge in the tube.
Old 08-15-2010, 11:38 PM   #5
Poik
Backwards Turbo
Poik's Avatar
Originally Posted by peehound View Post
Umm...
What...?
Old 08-15-2010, 11:59 PM   #6
nickm
nickm's Avatar
Check the bearings are not binding when compressed. Jack the car up, turn and see if they bind with no weight on them.
I trimmed the URO bearing as they would bind when compressed.
The bearing were garbage. Then the rubber let go after about 18 months.
I ended up getting new SKF ones from IDP. But these are no longer available.
The parts you are using should have been ok. But you may have not got genuine SKFs bearings. are the bearings orange?
You can remove the strut mount without popping the ball joints etc. lower the strut and swing it out.
http://volvo2.homestead.com/740strut.html
nickm is offline   Reply With Quote
Old 08-16-2010, 12:16 AM   #7
BoostedSwede
Masshole
The bearings are white and black and say "SKF" on them. No, I did not forget any pieces when putting them back together. I'll check for binding when they are unloaded on Tuesday, when I have the day off from work.
Old 08-17-2010, 01:01 AM   #8
gearhead
I don't know if you were able to solve this or not but I thought I would weigh in about a similar situation on a 93 subaru legacy I had.Bought the car with bad struts so I bought new struts and reused the mounts because the bearings looked good.I installed the fronts and got a similar clonking noise.The strut top hat on a subaru has 3 bolts.I didn't think it had to go in a specific way just as long as it lined up with the holes right?Turns out the strut top hat was supposed to go a certain way because otherwise a tab would bind up on the body when turned then it would pop free causing the clonking sound.did the same thing on low speed bumps.It wouldn't hurt to check if thats were your binding is...
gearhead is offline   Reply With Quote
Old 08-17-2010, 01:25 AM   #9
gsellstr
gsellstr's Avatar
Ahh, welcome to my world.
The set I just installed a couple weekends back were brand new KYB mounts with SKF bearings. The bearings were actually all-metal, stamped with SKF and a bearing number. I've run several of the plastic bearing units, never had much life expectancy from them. The rubber hasn't lasted more than about 2 years (last set of SKF boxed mounts got me 2 years, best yet). The KYB's are second.
As for the clunk, honestly, it sounds like the same clunk I was getting when each of my Bilsteins crapped itself. Usually low-mid-speed hits of small to medium severity would get a good, solid clunk or knock from the strut. Haven't had it yet since I installed the koni's 2 years ago though.
I'm working on getting something new prototyped for the Volvo world that should make life, well, better for all of us.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 08-17-2010, 10:57 AM   #10
badvlvo
Bad for Babies
badvlvo's Avatar
Time for plates.
Died at age 35
Old 08-17-2010, 02:21 PM   #11
jpbturbo
Mens Classic Fit Polo
jpbturbo's Avatar
Originally Posted by badvlvo View Post
Time for plates.
Originally Posted by Lord_Athlon
My kia is best kia appliance so cheap.. Oh ****
Originally Posted by Isaac
Ur A LIAR u dident maek 28 psi BOOURNZ!
jpbturbo is offline   Reply With Quote
Old 08-17-2010, 04:18 PM   #12
badvlvo
Bad for Babies
badvlvo's Avatar
I'm ready for plates for the 244, just don't have the $$$.
Old 08-17-2010, 04:21 PM   #13
Wren
Porkchop Sandwiches
Wren's Avatar
What do they cost?
With Volvo strut bearings running about $75+each now, it may be a better option than you think.
Originally Posted by MAVAWRECK View Post
i think you guys ignore me sometimes cause i dont have a turbo or a black primered hood. I make cool engine noises with my mouth when i drive though.
Originally Posted by ElPiloto View Post
The best in-car (mouse)trap is a snake. If you use a rattlesnake, be sure to remove it before you drive the car.
Old 08-17-2010, 06:15 PM   #14
jpbturbo
jpbturbo's Avatar
Originally Posted by WrenWright View Post
What do they cost?
I think the BNE camber plates are around $280.
I've had a set for a few years now and am finally going to have a chance to install them this fall.
although I did have a set of his original plates on the 245 and they were a massive improvement over the stock marshmallows.
Old 08-17-2010, 06:25 PM   #15
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Originally Posted by jpbturbo View Post
stock marshmallows.
Old 08-17-2010, 07:14 PM   #16
BoostedSwede
Masshole
Alright, I put the front of the car in the air today and looked at it. There is no binding at all when turning the wheels when they are off the ground. As soon as I put the car on the ground, the binding started again. Could these be defective parts? Or are the SKF bearings just junk? Help!!!
Old 08-18-2010, 12:03 AM   #17
gsellstr
gsellstr's Avatar
Could be junk bearings. The SKF's I've got and run in the past have been decent, but they're also metal, not plastic. The last set of plastic ones I had literally fell apart and ground the balls into shavings in just over a year.
Old 08-18-2010, 06:40 AM   #18
BoostedSwede
Masshole
Crap. Anyone know where I can get the metal ones?
Old 08-18-2010, 10:30 AM   #19
gsellstr
gsellstr's Avatar
See if your local Carquest possibly has the KYB's on the shelf. The rubber mounts were slightly different as well where the bearing fits, between the plastic and metal bearings on the set I just swapped.
Old 08-18-2010, 01:35 PM   #20
BoostedSwede
Masshole
Are the KYB really any good? I had serious problems with other "known-to-be-good" aftermarket strut mount brands. I previously had the Febi/Bilstein brand, and I literally tore through the rubber in under 1 year.
Old 08-18-2010, 03:56 PM   #21
peehound
"Arf" she said.
I'm missing something here.
My 740 has the original,"plastic" bearings & rubber from 300K ago on top of the coil overs.
I did re-grease the bearings once, though.
Old 08-18-2010, 05:08 PM   #22
gsellstr
gsellstr's Avatar
Probably don't wanna get rid of em then!
The KYB's are pretty much my second choice to the SKF's thus far for aftermarket. They DO come with cool black plates instead of silver too.....
Old 08-19-2010, 03:34 PM   #23
TME Racing Photography
TME Racing Photography's Avatar
Are SKF's what came stock? If not can you get OEM bearings from the dealer still? I need to change mine but the idea of having to do this every 2 years doesn't sit to well with me.
Are there any threads that show how this is done? Are there any special tools needed?
TME Racing Photography is offline   Reply With Quote
Old 08-19-2010, 03:54 PM   #24
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
The alignment of the bearing race is very important when installing your upper mounts in a 7/9xx I've done about a dozen of them, I'm not a professional, I just used to get suckered into working on friends Volvos.
If things don't line up in the strut assembly once the weight gets on them then it's going to work like crap, bind up and spit bearings. I've done it, "in car" nearly every time except for the last time I used a strut compressor at Performance West. I could line everything up and slowly increase the pressure to the strut while looking carefully at the bearing race and the track it sits in. (I usually do this with my hand while jacking up the strut rod from underneath while the car's on jack stands - not safe).
I'm not saying you guys are messing things up. I just think it's important to stress how easy it is to not notice how poorly it may be fitting once it's up in the car.
Gary is also right, there are a lot of other front end issues (blown shocks being one of them) that people blame on the upper strut mounts.
I've used 2 sets of SKF uppers in the 10 years that I've owned my car. They are about as good as you can get for stock replacement. People who know me KNOW that I drive the piss out of my car.
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Black - '98 318i : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 98#/hr injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Driver
Magnum TE is offline   Reply With Quote
Old 08-19-2010, 04:02 PM   #25
badvlvo
Bad for Babies
badvlvo's Avatar
What do they cost?
No good. They last forever with soft stockish springs, deteriorate rapidly with anything stiffer.
And I can't get enough camber adjustment out of the stock crap.
