Old 10-02-2019, 02:48 PM   #1
itlksez
itlksez's Avatar
Default The Volvo-powered Willys CJ3a
I had a small thread elsewhere on here, but Photobucket tanked it. Rather than try to fix that one, I'll start over here.
I'm 12 years deep into a build that is taking a 1949 Willys Jeep
and a 1987 Volvo 740
to end with a very street and dirt friendly rig.
Almost every part of this has been hand built. The following will be a story through pictures, since I don't have enough patience to sit and type the whole story. If you have any questions, please feel free to ask.
itlksez is offline   Reply With Quote
Old 10-02-2019, 03:10 PM   #2
itlksez
itlksez's Avatar
Body work
Joining the M45 to a Dana 300 transfer case
Fitting the shifter
Old 10-02-2019, 03:30 PM   #3
itlksez
itlksez's Avatar
I toyed with the idea of adding turbo. Ultimately decided against it, but left room for it if I go that route in the future.
New engine mounts
Engine cradle
Crossmember. Round hole for exhaust, other hole for wiring. Front driveshaft utilizes the support bearing from Volvo
Transfer case mount will allow the exhaust to pass through
Radius arm links for the front coil suspension are from the rear of an 850
Front axle is from a Toyota truck
Old 10-02-2019, 03:42 PM   #4
itlksez
itlksez's Avatar
Rear axle is from an Isuzu Rodeo. I had to buy the whole truck for $100 just for the rear axle.
That was a lot of mounts to remove.
I sent the shaft off to Moser to shorten it by 7 1/2"
Cage work up in the engine bay included a sway bar up over the engine because I had nowhere else to fit it. The links go down through the coil springs.
Radiator mount. Rad is an aftermarket 3-core unit for a Honda Civic.
Working on the alternator/air compressor mount
Old 10-02-2019, 03:45 PM   #5
Chumley360
Sweet! Reminds me of the B230FT I saw in a Samurai twenty years ago.
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 10-02-2019, 03:56 PM   #6
itlksez
itlksez's Avatar
Power steering pump mount on the other side
Gas tank fabrication incorporating the 740 in-tank pump and sender
Rear shock mounts
Pedal assembly using Volvo booster and pedal pads.
Cage work between the firewall and dash
Building the cage
Old 10-02-2019, 04:02 PM   #7
itlksez
itlksez's Avatar
Upgraded fuel pump mount
And I just got finished with the exhaust. I had to build the muffler from scratch due to space restraints. It is surprisingly quiet.
And that catches me up to today. Next up is thinning the wiring harness down to a manageable clump.
Old 10-02-2019, 04:07 PM   #8
oldschoolvolvo
oldschoolvolvo's Avatar
cool project and nice fab work!
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 10-02-2019, 07:08 PM   #9
itlksez
itlksez's Avatar
Thanks! I知 finally seeing light at the end of the tunnel.
Old 10-07-2019, 03:40 PM   #10
itlksez
itlksez's Avatar
After 15 hours of tracing wires, this...
...turned to this.
It needs one relay and three fuses to run. I値l go back and add the wiring for the lighting later.
The original firewall grommets are getting re-used. I threw the body back on to start to figure out placement.
I知 re-proposing the original location of the jeep痴 hand brake for the Volvo ignition switch.
Old 10-07-2019, 08:53 PM   #11
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I absolutely love this!
Old 10-07-2019, 09:30 PM   #12
2turbotoys
Astro Zombie
2turbotoys's Avatar
Very cool! Way to gloss over an incredible amount of hard work haha, dam.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 10-07-2019, 09:54 PM   #13
itlksez
itlksez's Avatar
Thanks guys.
Hey @2turbotoys, I’m from your neck of the woods! Boyertown HS, class of ‘93
Old 10-07-2019, 10:58 PM   #14
2turbotoys
Astro Zombie
2turbotoys's Avatar
No sh$$, I am currently working at a Jeep specialist there...stop by and say hi at MPG if your in the area, Manifest Performance Group might help Google. '93...we know some of the same people, bet
Love your ideas and build.
Old 10-07-2019, 11:33 PM   #15
itlksez
itlksez's Avatar
stop by and say hi
I知 *originally from that area. I moved to Idaho 16 years ago and miss nothing but the... well, nothing really.
Old 10-08-2019, 02:00 AM   #16
I read through a thread about this some years ago in some forum that I can't remember. Glad it's still moving along.
Old 10-08-2019, 12:33 PM   #17
2turbotoys
Astro Zombie
2turbotoys's Avatar
Hahaha
Old 10-08-2019, 01:40 PM   #18
itlksez
itlksez's Avatar
I致e been working on figuring out where to route the air intake. The engine bay is getting so crowded, I have no choice but to go inside the cab with it. I was able to turn the stock air horn 180ー and run the bellows through the firewall between the cage and the brake booster.
This moves the air mass sensor inside the cab. I値l need to cut the wires, add a connector and about 2 of length to get it to reach.
I dug through my supply of junkyard parts and was able to piece together the elbows and tubes I need from stock replacement parts for a turbo 940. These get me up and over the steering column and behind the gauges. I値l build an air box behind the dash on the passenger痴 side with the air intake possibly dumping into the wheel well, la Project Binky, if anyone here is following that built.
Old 10-08-2019, 01:55 PM   #19
patrickstar
patrickstar's Avatar
You're in Post Falls? My old neck of the woods. I'd love to check this out some time when I'm home
1983 242 - 4.8/AR5
1980 242 - Daily
1980 242 - Shell
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 10-08-2019, 02:30 PM   #20
itlksez
itlksez's Avatar
You bet! Any time.
Old 10-09-2019, 12:07 PM   #21
itlksez
itlksez's Avatar
Picked up a filter and made the template for the air box.
More to come.
Old 10-09-2019, 12:20 PM   #22
propav8r
F*ck Edgar
propav8r's Avatar
This is hilarious and amazing.
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 10-09-2019, 12:28 PM   #23
itlksez
itlksez's Avatar
Thanks! I think?
Old 10-10-2019, 01:07 PM   #24
itlksez
itlksez's Avatar
My daily two hour allowance towards this just flies by.
I got the pieces for this air box cut out. After I traced the pattern, I re-assembled the cardboard templates and measured the angles so I could write the numbers on the corresponding bend marks.
With the air cleaner in place:
Now that the corners are tacked and the inner frame is in place, I can massage the bends a little to fine-tune the joints before welding it up.
Old 10-10-2019, 01:47 PM   #25
6thousandths
this is awesome, looks like quality fabrication work!
6thousandths is offline   Reply With Quote
