Old 05-26-2014, 07:06 PM   #1
SwedishBee
Drill em deep
SwedishBee's Avatar
Default 2007 XC90 ac compressor
We changed the expansion valves and drier hoping for the best, but it looks to need a compressor.
Builds pressure for a few seconds of coldness then nothing.
Now I'm learning about the disaster of the serpentine belt and tensioner setup.
That's what I need to know about. Hit me.
Forgot to mention, it's a 3.2 liter.
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 05-26-2014, 07:27 PM   #2
CEHepp
FWDFTW
CEHepp's Avatar
It's super easy.
19mm wrench and a small Allen key, pull the tensioner to remove tension on the serp belt, drop the Allen key into the hole on the tensioner to hold it in place. Evac the system. Remove the two nuts holding on the pressure pipes, unplug the two connectors for the clutch and swash plate solenoid and finally the three bolts that hold the compressor in place.
Reverse to install.
DD: 2004 S60 on copper Pegs
Current project: 2004 V70 T5M
CEHepp is offline   Reply With Quote
Old 05-26-2014, 07:35 PM   #3
SwedishBee
Drill em deep
SwedishBee's Avatar
Hey what engine is this info for?
Old 05-26-2014, 08:06 PM   #4
CEHepp
FWDFTW
CEHepp's Avatar
3.2, of course.
Old 05-26-2014, 08:07 PM   #5
SwedishBee
Drill em deep
SwedishBee's Avatar
So I'm guessing you mean, use the 19mm wrench to twist the tensioner, do you get it from the top? Or what? It just looks like aliens built this thing. Open end side of the wrench?
Old 05-26-2014, 08:19 PM   #6
CEHepp
FWDFTW
CEHepp's Avatar
Under the power steering reservoir, you can see the tab that the open end of the wrench will sit against as you pull it. Beside that is the hole in the tensioner where you will drop in an allen key to hold it in the relaxed state.
Old 05-26-2014, 09:09 PM   #7
vlvman
vlvman's Avatar
Is the compressor clutch staying engaged? It might need shimmed.
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 05-26-2014, 09:32 PM   #8
SwedishBee
Drill em deep
SwedishBee's Avatar
Compressor runs fine. With a low charge it has a equal pressure of 95 psi. When it turns on it goes to 70 on low side and 125 on high side, That's it, it won't take any more Freon either.
Old 05-26-2014, 09:51 PM   #9
CEHepp
FWDFTW
CEHepp's Avatar
The plate sticks on those and they won't cool. You can try replacing the solenoid but I think you're going to be wasting your money. Just put a compressor on it.
These aren't clutch cycling systems either so you would almost never see a clutch failure on this type of compressor.
Old 06-16-2014, 11:10 PM   #10
SwedishBee
Drill em deep
SwedishBee's Avatar
It was super easy just like you said. But changing the belt, which involved removing the power steering pump,
... That sucked.
Old 09-12-2014, 07:32 PM   #11
Steve147b
swedish bee. i just got my power steering pump off and was surprised there was a spring behind the pulley. Any suggestions on how to reattach? Also, do you have the serpentine belt routing diagram by chance.
Steve147b is offline   Reply With Quote
Old 09-12-2014, 11:36 PM   #12
CEHepp
FWDFTW
CEHepp's Avatar
You have to remove the 2xT25 fasteners from the power steering pump pulley and reinstall the spring and coupler back into the water pump. It's kind of tight so watch your thumbs. I can't tell you how many times I have smashed my thumbs putting one of those pumps back in.
