Old 09-03-2014, 07:12 PM   #1
HellFound
Default 240 A/C and power steering belt removal?!
I can't find one single thread/video/diagram on how to install the AC/power steering belt. I know there is supposedly a hidden 13mm bolt. But I can't find it anywhere. Can somebody post a picture or something? Driving me crazy. Thanks!
HellFound is offline   Reply With Quote
Old 09-03-2014, 07:34 PM   #2
SwedishBee
Drill em deep
SwedishBee's Avatar
Your in luck.
http://youtu.be/BQhfcdQf1QA
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 09-03-2014, 07:37 PM   #3
MalibuLX3
MalibuLX3's Avatar
1992 Volvo 240 Wagon
MalibuLX3 is offline   Reply With Quote
Old 09-03-2014, 09:06 PM   #4
HellFound
Originally Posted by MalibuLX3 View Post
Thanks for the pic, but where's the hidden bolt?
Old 09-03-2014, 09:25 PM   #5
ikyikthe1st
They're facing each other on the inside of the tensioner assembly in that picture, as far as I know. Loosen those two and then use the 10mm to tension/relieve tension the assembly.
ikyikthe1st is offline   Reply With Quote
Old 09-03-2014, 09:42 PM   #6
HellFound
From what I've been reading, everyone is saying you have to get it from underneath and take the belly pan off etc. which I did, just nothing back there is a 13mm.. Only 15mm
Old 09-03-2014, 10:40 PM   #7
It's right under the main bracket's 'roof', on the slide bracket just to the left of the red duct tape 'cap' in the picture.
I get it with a stubby 3/8" ratchet and short 13mm socket from above.
Look in there with a light and feel around in there, you'll find it.
how psi stock can support?
Old 09-03-2014, 10:42 PM   #8
MalibuLX3
MalibuLX3's Avatar
If you look at the tensioner on the front side that you most likely already loosened...look directly behind there for the other tensioner (minus adjusting bolt) and loosen that 13mm nut found in between the front and rear bracket.
I find it's easiest to do from above the engine, standing by the drivers side fender, with a retching wrench.
Old 09-03-2014, 10:50 PM   #9
MalibuLX3
MalibuLX3's Avatar
Old 09-04-2014, 01:12 AM   #10
HellFound
You're awesome. Thanks man! Finally loose. Still can't get the belt on by myself though. You have a tip for that? Seems a little tooo tight with the belt
Old 09-04-2014, 11:54 AM   #11
Johann245
Volvoholic
Johann245's Avatar
See if you can loosen pump more. Or put on like a bike chain. Put belt Part way around HB and fully around the ac, and spin till belt is fully caught. You will have to remove these two belts again if you do the alternator separately. Are you doing all at once?
"Classic" Project
My '88 245 Sold
My '95 945 Sold
Feedback
Johann245 is online now   Reply With Quote
Old 09-04-2014, 08:16 PM   #12
HellFound
I'm just doing the ac to crank pully
Old 09-05-2014, 12:01 PM   #13
Johann245
Volvoholic
Johann245's Avatar
How'd it go?
Old 09-07-2014, 10:39 AM   #14
HellFound
How'd it go?
Still can't force the belt on. The Bracket is as loose as it will go. Stumped :/
Old 09-07-2014, 11:33 AM   #15
MalibuLX3
MalibuLX3's Avatar
Have you tried loosening power steering pump to allow more slack?
Old 09-07-2014, 12:08 PM   #16
Johann245
Volvoholic
Johann245's Avatar
Have you offered a Colorado TB member beer yet for a little help...? Also do loosen the PS pump if you haven't yet. Some pics to show where you are at or maybe the steps you've taken so far would help us out a bit.
Old 09-08-2014, 09:26 PM   #17
HellFound
I knew I wasn't that stupid... Im usually pretty damn good with mechanical and autos so I knew something was wrong. The lady at the parts shop gave me the wrong belt. Once I found out, I went back and got the RIGHT one and it went on with the flick of my wrist. Power steering works great too! Was kind of nervous about that. Thank you everyone for the help! Seriously appreciate it. If any of you cruise through Colorado, shoot me a message and a drinks on me!
Old 09-08-2014, 10:27 PM   #18
Johann245
Volvoholic
Johann245's Avatar
Contitech belts from eeuro are only a few bucks. Check that out for next belts.
Old 07-06-2017, 12:26 AM   #19
Centsableone
SNAFU - BOHICA
Centsableone's Avatar
Default fast forward to Julu 2017
I was going to duck into the garage and replace the damper to AC belt on the 92 b230f and thought that I would take a quick look in the forum first. Came across this thread and thought now just how could you possibly try and install the wrong belt. (Striking myself in the forehead) I found myself having this exact same issue. The clerk looked up the wrong belt and all I had done was watch that he put the correct year, make and model into the system to find the belt. Went back and got the slightly longer AC only belt and it worked like a charm. The photos and explanations in this thread probably save me a lot of time and frustrations.
OBTW - I just used the other belt on the AC to power steering so now I have two new on that side of the engine at least.
Live and Learn.
1983 245T, 1986 244, 1990 745T, 1990 245, 1982 4- speed 245D,
Currently: 1992 244
Sale and Purchase Feedback
Centsableone is offline   Reply With Quote
Old 07-06-2017, 12:44 AM   #20
thismachine13
That makes three of us digging around the power steering/AC area today. Pulled the later model power steering pump off my parts car to put on my wagon tomorrow. The pic of the bracket and AC sure helps to understand how everything tensions.
Old 07-06-2017, 10:50 AM   #21
coalminer
This post gives a good reason to always take your old belt with you to the parts store.
That way, you can compare it to the new belt.
Even if it is broken, the length can still be measured.
coalminer is offline   Reply With Quote
