Old 09-16-2014, 04:27 PM   #1
rdp001
rdp001's Avatar
Question 93 240 runs and simply quits.......??? help?!?!
Ok so I have a 1993 240 Classic BF230 Auto.... 180 K ........
I have replaced the CPS and also put in new Fuel pump relay as this car runs and drives like new..........until it just quits....done !!!! No check engine light nothing!?!?!?
Checked the ignition module and put gel between it as it was almost gone.......
Car starts up runs great ...no miss or anything just perfect.............until......it just stops!!
So I have fuel.....I have spark .... AMM works....fuel pumps buzzing like a happy camper...
Seems like when it gets to temperature it just dies...like you shut of the ignition...(which I don t)
Has anybody else had this wonderful problem ???? I don t mind to go search until I find it.
However if anybody else had the same maybe one of you guys can point me in the right place???????
Any help would be greatly appreciated....
1985 245 T 4+od,IPD springs/sways/red koni.s/18"/b21FT/T3 12lbs/Turbo cam+adj/90+ manifold/NPR/strutbar/3" TME exh/and still not enough torque!!! 1995 T5R yellow FMIC/Koni/T16/S60R mani/IPD ecu/3" TME exh/and original looking!!(SOLD)97 855 R black Swedish ECU 3" Exh,coilovers,19T comin! awesome daily driver .Many mods and more comin!
96 850 TDI Platinum ed in europe
rdp001 is offline   Reply With Quote
Old 09-16-2014, 11:06 PM   #2
theknave
theknave's Avatar
Hm. I'll throw out some things. Bad LH or EZK?
Bad EGR? I like to throw out EGR.
Sounds like the issue is going to/from closed/open loop? Maybe go from there?
Bad/touchy ignition switch?
theknave is offline   Reply With Quote
Old 09-17-2014, 10:01 AM   #3
the65dartguy1
I had a bad ignition switch do that to me last year. All of a sudden it was 100% dead, and I was on the interstate at the time!
the65dartguy1 is offline   Reply With Quote
Old 09-17-2014, 10:27 AM   #4
mtd240
Bored Member
mtd240's Avatar
O2 and ECT are likely candidates, but this is all parts cannon recommendations. Download the complete LH2.4 manual and read it...
1990 245DL M47 LH3.1 - 344,000 Miles
1989 244DL AW71 LH2.4 - Sold
1998 V70XC - Sold
mtd240 is offline   Reply With Quote
Old 09-17-2014, 11:07 AM   #5
SwedishBee
Drill em deep
SwedishBee's Avatar
Replace the powerstwge.
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 09-17-2014, 12:03 PM   #6
rdp001
rdp001's Avatar
Ok guys thanks for the tips I will follow up on your suggestions and let you know....
Old 09-17-2014, 01:22 PM   #7
coalminer
Check and clean the terminals for fuse #4 (counting down from the top) in the fuse panel beside the drivers left leg.
Also check the 25A blade type fuse and it's holder that's located under the hood on the left fender.
It sits behind the battery and has a red wire from the battery positive that feeds it.
Follow the wire to find the fuse.
hope this helps
steve
coalminer is offline   Reply With Quote
Old 09-19-2014, 12:34 PM   #8
rdp001
rdp001's Avatar
Ok guys your input has helped ,thanks for all the replies!! I checked main fuses and checked the ignition switch.
Also checked o2 it s a non egr 240 and found no issues even checked the AMM with another unit that I had and no difference!
Also put gel between the power-stage and made no difference......
I just went and got a new bosch power-stage and problem is fixed!!!!!!!
Thanks for all your input !!!
Old 09-19-2014, 01:43 PM   #9
theknave
theknave's Avatar
Note taken on the power-stage...
I should probably do my research and figure out what that thing is actually used for.
