Old 01-07-2015, 12:36 PM   #1
Michael T
Bands make her Dance
Question Can someone take a peak under their hood for me and tell me where this is plugged.
I would have to guess it is something for the ignition. It's been unplugged since I bought the car. Cars cranks and runs, but its missing and not idling great. I've done maintenance items that should of cleared this problem up but it hasn't so now I'm moving on to the mystery wiring I have around the engine bay.
Michael T is offline   Reply With Quote
Old 01-07-2015, 12:43 PM   #2
SwedishBee
Drill em deep
SwedishBee's Avatar
Simply put, nothing.
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 01-07-2015, 12:53 PM   #3
Michael T
Thanks! I'll keep searching for the problem.
Old 01-07-2015, 01:21 PM   #4
PromiseRing
We don't even like Volvos
How bad is your idle?
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
-94' M-Edition Miata-Stock with a hardtop
Past
-80' 242gt m46-
-92' 940 turbo, got for free, fixed, sold
Feedback Thread
can't replace u joints
Old 01-07-2015, 01:25 PM   #5
2manyturbos
It isn't plugged into anything because it never was. It is a system test lead used to diagnose problems.
Old 01-07-2015, 01:41 PM   #6
Michael T
It goes between very nice to being annoyingly rough.
Old 01-07-2015, 02:20 PM   #7
dobber13
Looking at the picture 1 wire (white) isn't connected to coil and if all your electrical connections and grounds look that bad they all need to be cleaned up. Check for vacuum leaks(dry rot hoses)intake gasket,injector O rings.Check by spraying break cleaner on them but not on exhaust side.
I guess what we need to know is what have you done so far.
Charlie
Charlie 85 244 TI B21FT 265K M46
dobber13 is offline   Reply With Quote
Old 01-07-2015, 02:25 PM   #8
2manyturbos
Charlie
I just ASSUMED that the OP had that (grey, not white) wire off in the pic, but, has it hooked up now. If not, that is the problem. That is what triggers the coil. It is coming from the ignition box and also goes back to the computer to turn on the fuel pumps via. an RPM signal. The engine won't even run if that wire is disconnected. If it is off and just resting against the coil terminal, that would cause the symptoms the OP is experiencing.
Old 01-07-2015, 02:58 PM   #9
TWD
TWD's Avatar
I have no idea what car the picture came from.
On my 1988 244 GL, a similar plug is the test point for the AMM adjustment and a ground that that closes down the IAC.
TWD is offline   Reply With Quote
Old 01-07-2015, 03:29 PM   #10
towerymt
the real Towery
towerymt's Avatar
That's what I recall as well, from my '87. Back when it was stock, I used that method to set idle once.
I believe there was also a pink plug like that, which when grounded, would fry the ECU. It was meant for testing, but if not used properly, could do damage.
Read the manual before you ground any unused plug.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 01-07-2015, 07:33 PM   #11
Michael T
Charlie
Thanks, I'll check it out tomorrow.
I've done
Air Filter
Spark plugs
Spark plug wires
Distributor cap
Most of the vacuum lines look redone to me. They are way too new looking to be original.
