travisminchew
- Nov 2, 2010
- California
If AFR's are ok as in in the 10-low 11 range under boost but there is audible pinging what could it be?
I know 10.3 is rich but it's not that rich to cause issues is it?
I've been at 18psi for a while now an the car feels good but had to get off the chipped ecu due to a issue so I'm on stock ecu again an when I come in too boost hard te pinging is definitely there
3in maf, 50lb Injectors, some other stuff. Don't see why I can't run 28psi if I have the fuel mods to support it?
