Old 01-03-2017, 02:33 PM   #1
SwedishBee
Drill em deep
SwedishBee's Avatar
Default STS LS 240 mounts, Hows your fitment? Mines tight
90 240 with 5.3 sitting on sts mounts with hooker 8501 manifolds.
less than 1/2" of total engine movement between the manifold hitting the steering shaft and the the other header collector hitting the frame rail.
do the earlier cars have a skinnier steering shaft?
pics later
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 01-03-2017, 02:39 PM   #2
culberro
culberro's Avatar
Is it hitting in the larger square section of the steering shaft?
The 5.slow moostang has about 1/8in of clearance on the steering shaft and it hasn't been an issue.
Old 01-03-2017, 02:43 PM   #3
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
It'll clear but I'm told from others it'll be a little ~tight~.
Originally Posted by 77volvo245 View Post
We are using our STS ls motor mounts. You can use the Holley Oil Pan #302-1 fits without modifying your cross member. Hooker Cast Iron Headers #8501 HKR will clear the steering shaft, you need to run the TRW cam style steering rack for our mounts.
Old 01-03-2017, 04:04 PM   #4
SwedishBee
Drill em deep
SwedishBee's Avatar
ahhhhh you must use a cam style rack.
does not say that on the website or anywhere, nice.
Old 01-03-2017, 08:42 PM   #5
cosbySweater
cosbySweater's Avatar
get a speedway steering column. they all hit
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
Old 01-03-2017, 09:05 PM   #6
M.H. Yount
M.H. Yount's Avatar
The stock splined sections are hollow. You can cut them off the OEM upper/lower shafts. 0.50" diameter steel rod happens to be a near perfect fit in the hollow splined sections. So you can alter the lengths/angles, get rid of the larger rectangular rubber damper OEM piece and create all the clearance you need to run just about whatever exhaust manifold you like all while using stock u-joints. Getting rid of the rectangular OEM upper shaft/damper makes for a more direct connection with better feel, but transmit a bit more noise. FWIW. Lots of ways to skin this cat.
Edit -- tip - leave the steering wheel on when taking apart all the bits inside the engine compartment....don't ask how I know.
[/QUOTE]
Old 01-03-2017, 11:19 PM   #7
Texas240
Prius Owner
Texas240's Avatar
Mine was hitting. I had to move the whole track an inch and a few pubes over to the drivers side then shave some area off the hooker headers where the steering shaft was hitting. All good now but was not my idea of fun night
93 245 LS Engine Swap Project
Old 01-03-2017, 11:23 PM   #8
77volvo245
77volvo245's Avatar
We adjust the shaft up on the knuckles, we found out every car is different. we made some slight shift change on the current mounts, so it clears the steering shaft more.
STSmachining
77volvo245 is online now   Reply With Quote
Old 01-10-2017, 08:46 PM   #9
Ttownthomas
I did this too based upon Texas240's advice. Had to shift the rack and shave the header. There is also a splined plain shaft available from coleman racing that can create some additional clearance.
Ttownthomas is offline   Reply With Quote
