adrianpike
- Dec 1, 2002
- Seattle, WA
Hey gang,
So I resurrected my hooptay earlier today, and am having some big misfire issues. I'm using a RSI flywheel with the 60-2 drilling, and a stock VR sensor.
Hitting #1 with a timing light, the mark jumps around a ton - usually it's right on idle timing (~14deg), but about 20% of the time it jumps to what looks to be about 90* before or after target timing.
I've cranked open the idle screw to get it up to ~1200 so it'll stay alive.
I'm using an old MS2.2 with the Zeal daughtercard (which uses LM1815s).
Idle on a datalog looks pretty smooth. No sync loss once it's running.
Anybody got any brilliant ideas? Maybe I've got the VR backwards, would these be that kinda symptoms? Noise on the line? It's shielded the whole way in, but runs kinda close to a bunch of other stuff through the firewall.
Potentially related, cranking is still pretty un-dialed in. I'm getting some kickback, but if I baby it enough (ride ye old flood clear) it'll light up okay.
Cranking timing is trigger return, 10* advance.
All that said, I've got everything I need here to swap to a hall sensor, but it requires a slight rewire and if I can avoid it just to get running and start tuning, that would be bitchin'.
