Old 01-11-2017, 03:55 AM   #1
Otto Mattik
Otto Mattik's Avatar
Default Slow/Low heat issue
92 240 aw70, Nissen's all metal 3 core radiator
After recently replacing thermostat and flushing Nissen's the heat situation has scarcely improved. Wondering if the heater core is the culprit ?
A) Last summer installed new Gates pump, no leaks, works fine
B) Recent installed "Wahler"(parts store clerk claims) 91c thrmstt, has correct bleed valve but no markings of any kind
C) Old thrmstt was 87c
D) Checked hose temps on each side of temp control valve & both hot
E) Control valve looks corroded a bit
F) Slow warm up, when below 15f
G) Squeezed large rad hoses for trapped air to no effect
G) Yes, coolant is topped off, yes bleed valve is up
Theories ? * link to show "similar" thrmstt
http://www.oreillyauto.com/site/c/de...2070&ppt=C0331
Otto Mattik is online now   Reply With Quote
Old 01-11-2017, 04:25 AM   #2
Shifted
Briefly 'Jostra Quadrox'
Shifted's Avatar
Unmarked thermostat suspect, and make sure the heater valve is actually functioning. Ie. diverting coolant through the heater core instead of letting it by due to internal failure.
Originally Posted by ME II View Post
Without mistakes there is no learning.
Originally Posted by XxJenoxX View Post
Eventually, you're going to have to understand that you can't get a truly non-crazy chick... We're all f7cking nuts.
Originally Posted by urbanwheeler
I'm not cool enough to be banned.
"Drink up dreamers, you're running dry." Peter Gabriel
Let my soul have its day in the mud
Shifted is offline   Reply With Quote
Old 01-12-2017, 04:16 AM   #3
Otto Mattik
*Thought about the thermostat, but it behaved nearly the same as it did with the 87c thermstt.
*Closed heater control valve, it got cold. So next determine if it's opening entirely (cable slipped, etc ?)
Old 01-13-2017, 02:52 AM   #4
Otto Mattik
Thanks, the heater valve will close off all heat, so I guess next determine if it's opening completely. Also a buddy showed me a way of reverse flow flushing the core by using the heater core hoses from the front of firewall. He said he did his, and lots of crud came out of the core.
* I've only had the control valve's stick open, but I guess it could be stuck part way closed too, eh ? Probbly going to replace the control valve, as it's corroded anyhow
Old 01-13-2017, 05:32 AM   #5
cleanflametrap
Noob
cleanflametrap's Avatar
Curious if you are judging slow warmup by heater output alone or gauge?
-Art
Old 01-13-2017, 01:13 PM   #6
Otto Mattik
The gauge and engine temp are normal, & motor(gauge) warms up faster w/ new thermostt.
Unfortunately the cabin heat is lacking. Leaning towards the control valve and/or partially plugged core at this point (?)as everything else appears normal. Last night it got -15f, dicey
Hopefully I can tear into it this weekend, thanks for concern
Old 01-13-2017, 02:30 PM   #7
Infrared gun.
Old 01-13-2017, 03:21 PM   #8
Otto Mattik
Infrared gun.
Good insight, thanks ZVOLV !
