Go Back   Turbobricks Forums > Symposium > article composition
Old 03-18-2017, 01:23 PM   #326
84B23F
84B23F's Avatar
Originally Posted by Karl Buchka View Post
it means the plugs only last X miles instead of Y miles....
Bingo,...platinum discs exist on both sides, ground and the center electrode, to last a long time.
On GM wasted spark engines, those plugs last a long time...I have no idea if there is a cross-reference to work on redblocks converted to wasted spark setups.
Old 03-19-2017, 09:28 AM   #327
Toni_
Here is the new card wiring:
245 B230FT AW71, 403 Hv/573 Nm, 142 B230FB-t M47, 945 D24TIC ZFHP22
http://volvo.tonit.org/
Toni_ is offline   Reply With Quote
Old 04-13-2017, 11:22 AM   #328
Matthama
Matthama's Avatar
Any word on more conversion boards being made?
'90 740 Turbo M46 Wagon,Buchka Spark Waste Mod, TLAO Chips, Persicion 57mm Turbo 48a.r turbine, Full 3", iPd springs, Bilstien HDs, iPd sways
'91 740 Turbo M46 Wagon iPd sways SOLD
'88 Samurai
Matthama is offline   Reply With Quote
Old 04-13-2017, 11:59 AM   #329
Duder
His Dudeness, El Duderino
Duder's Avatar
I took over sales from Karl. You can get them right now via my site: https://cflomoto.com/
Duder is online now   Reply With Quote
Old 04-13-2017, 01:54 PM   #330
boosted12a
weapon of mass detonation
boosted12a's Avatar
price went up. are therr any differences between these and the first run form back in the day?
91 940 SE, 119K, GOLD
93 945, 392K and still going! WHITE
05 S80 2.5T, RED
09 XC70 3.2L gas sucking DD, BLUE
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
boosted12a is offline   Reply With Quote
Old 04-13-2017, 02:26 PM   #331
Duder
Duder's Avatar
In group buy form these were $50 each, but Karl sold them individually for $65. I had to raise the price by $2 to $67 each to cover the costs of running a web store. But the upsides are that transactions are quick and easy, and shipping is included, with a tracking number.
This batch of boards is different from the first run, but I don't have all the details. I'll ask Karl to fill you in.
Thanks,
Chris
Old 04-13-2017, 03:27 PM   #332
boosted12a
boosted12a's Avatar
right. it was a group buy.
Old 04-13-2017, 09:21 PM   #333
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
The design was updated to improve manufacturability. The differences are transparent to the end user (other than the fact that the newest boards are black instead of green).
Fake Race Car
Karl Buchka is offline   Reply With Quote
Old 04-13-2017, 09:54 PM   #334
boosted12a
boosted12a's Avatar
ok. good.
Old 04-22-2017, 12:25 AM   #335
bgpzfm142
crossmember
bgpzfm142's Avatar
Been there and done that, and I'm a very satisfied customer.
The order was acknowledged almost instantly, and the board was here in Oz within 10 days.
_______ THE FLEET (AKA good luck trying to park around here)
71 1800E | 74 142 (x2) | 74 145 | 79 242GT | 87 745T | 88 780 V6 | 93 945T
plus a Holden Commodore VT SS 5.7
feedback thread
bgpzfm142 is offline   Reply With Quote
Old 04-26-2017, 04:14 PM   #336
Matthama
Matthama's Avatar
Got my board within 3 days for $2 shipping. I have it all soldered onto the ezk board. Gonna try to use a newer (06 07?) Subaru coil with module built into it. Its a four wire coil. Power, ground, 1+4, 3+2. Anybody have any experience with this? Or another 4 wire coil?
Old 04-28-2017, 11:42 AM   #337
superboosted
You wish you had some..
superboosted's Avatar
Some quick questions...Got my board about a month ago,had Shane solder it up for me and wired it up last night using his diagram. Using a goldbox EZK.
Using LS coils.
---Just pops and cranks like its out of time.
A couple things.
--I sourced 12V from the factory coil power source -- Is that ok?
--I grounded both grounds to the firewall(B and A) signal ground and ground. Am i missing something here? Should one of those grounds come from the factory powerstage?
Do i keep the factory powerstage?
This is the diagram i used...
Thanks for the help,very excited here...Look how nice she looks
Stormtrooper day off
Photobucket
You may get detonation and the kool-aid man loves 940s
superboosted is offline   Reply With Quote
Old 04-28-2017, 02:20 PM   #338
84B23F
84B23F's Avatar
Originally Posted by superboosted View Post
Using LS coils
When I searched this topic out, several years ago, my understanding then was "dwell time" might be an issue since 8 cylinders have a longer "wait" time before coil is charged (dwell time).
Myself, I would find LS coil specs, and do the dwell-timing arithmetic. IIRC, for a 4 cylinder with wasted spark, one might exceed GM's timing-envelope specification with higher RPMs.
Old 04-28-2017, 10:13 PM   #339
superboosted
Outputs were reversed. It's alive
Old 04-30-2017, 10:07 PM   #340
84B23F
84B23F's Avatar
board
Sidebar - LS2 Truck Coils
I recently reviewed a 2015 forum thread about coil's dwell time, and then examined two different LS dwell tables here ( factory dwell table for an LQ9), and here (2004 Silverado 5.3 dwell table), from this forum.
Based upon B230F NA LH 2.4 test I did back then, which I plan to recheck with another automotive DVOM in next several weeks, I found an OEM single coil's dwell time range of 6 ms to 3.5 ms (idle RPM to higher RPM).
Vagman posted (May 15, 2013) in that Megasquirt Support Forum that "BTW apparently there are people who "boosted" these coils with up to 6+ms without any spark scatter issues."
As such, if Vagman's statement is true, and NA LH 2.4 idle dwell of 6 ms is true, then these LS2 (D585) coils should not have an issue with wasted spark setup. I would have to see a LH coil dwell table if one was available, but as the RPMs increase, Bosch's LH coil dwell time may be quite similar to GM's dwells.
Duty Cycle wise, a 4 cylinder wasted spark is higher than a 8 cylinder, but duty cycle is more relevant at sustained higher RPMs.
If one wanted to be conservative, the power feed going to these LS2 coils could be dropped down a volt by using a resistor.
Old 05-02-2017, 01:12 AM   #341
84B23F
84B23F's Avatar
Coil Dwell - I did a duty cycle test with a Fluke 78 Automotive Meter today at idle speed on 1993 B230F NA, and it showed 6% duty time. At 800 RPMs, it takes 75ms to rotate crank once, so 6% times 75ms equals a calculated coil dwell time 4.5ms. Using Mac Automotive Multimeter ET 332, it shows at idle rpm an average pulse width of coil around 5.7ms. Since these valves of 5.7ms vs 4.5ms should be similar, this indicates one of these values is bogus.
From my reads, these higher energy coils, like Bosch LH 2.4's coil, do not take much dwell time to charge. A GM HEI coil, for instance, takes 3.6 milliseconds at 13 volts. Further, as RPM increases, there is less time to charge a single coil. Consequently, to have a good spark throughout engine's RPM range on EFI vehicles, a coil's dwell time should match up to higher RPM, when possible.
On a 4 cylinder engine @ 6000 rpm with a single coil, there is about 5 ms of time to charge a coil. Fluke meter showed via duty cycle calculation above to a coil dwell time of 4.5ms at idle.
It's going to take a good scope to measure dwell time, unless Bosch's single coil specs can be found, but I suspect that Fluke meter's measurement might be more realistic. If true, using GM's LS2 (D585) coils should not be an issue, with respect to coil's dwell time.
Old 05-04-2017, 09:54 PM   #342
84B23F
84B23F's Avatar
Originally Posted by Milos View Post
04-24-2012....can anyone tell me if there are other powerstages i can use besides 0 227 100 203?
Here are the specs for the 0 227 100 203, which is similar to the 0 227 100 211 . Bosch 0 227 100 211 "is an external ignition power stage capable of supplying up to four non-transistorized ignition coils." It can be setup for wasted spark (2x2) or four coils.
Offhand, I suspect if four stand-alone coils are used, then sequential firing might be advised. 4 stand alone coils drawing say 8 amps each in wasted spark setup will generate heat in this power module, and I can't say if this module can take it with 4 separate coils in a wasted spark setup.
Bosch shows how to create a simple driver board (igniter) in both of these spec sheets, btw.
cribbj ("Supra" Moderator) posted a wiring setup, about eight posts down in that forum, for this powerstage.
FWIW
Bosch's 0 221 122 334 coil, has a 8A maximum charge limit, and it was used on LH 2.4, and was OE for Audi/VW. This coil is also used for after-market applications, like for Ferrari Dino 246 and Lancia Stratos. For instance, for a Ferrari Dino 246, one person who did this conversion noted,
"This setup has a similar approach and precision as the very effective Marelli AEI200/Magnetic pickup setup in late GT4/GTB/GTS cars, but delivers 33% more power due to the higher coil current (and 100% more power compared to the factory points setup)."
As a side note, that after market kit would be nice to install in a distributor with points.
So, this Bosch coil, 0 221 122 334, can soak up 8 amps and will generate a high energy spark. GM's LS2 (D585) coils can absorb close to 10 amps if 5 ms of coil-dwell time exist.
Wasted spark is an improvement over OEM setup, but for the most spark power, sequential firing setup is needed.
My two cents, if I used a wasted spark setup, I would consider either of those Double-spark ignition coils mentioned in this thread, but I'd learn towards the Ford coil, 8241, since they would be in stock in most auto supplies.
