Jaypee_6680
- May 18, 2019
- London
I don't have any problem venting through the stock B21 valve cover hole and I'm running 24psi. I actually tried making something that bolts on the mechanical fuel pump cover but got too much oil through it. I don't think I mentioned that I use an HKS SSQV valve in an adapter that goes in the piping that I got off eBay. I don't recirculate it either it just blows off into the engine bay.
This is interesting, so the only breathing you have is from the valve cover? No Air/Oil separator on the block on your car? If thats the case then that's what I'll do for now! Cheers
