Old 02-24-2007, 02:27 AM   #1
mymomswagon
Default blue "R" injectors
Is anyone running these injectors with motronic or LH computers? If so does it require any modification? What's the impedence of these injectors? How do they compare to bt's and gt's? I think the "R" injectors flow 391cc's. They come in the s60r. Isn't a resistor required when running the bt's with these fuel systms?
joshA
mymomswagon is offline   Reply With Quote
Old 02-24-2007, 03:37 AM   #2
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
they fit and run as is. aren't they 391cc at 3.8bar though not 3 bar. not sure.
MikeHardy is offline   Reply With Quote
Old 02-24-2007, 05:33 AM   #3
SeriousSteve
staring at my desk
SeriousSteve's Avatar
They're high impedance so you need to bypass the resistor pack with something that looks like this
The pic belongs to Boris (the knocksense guy) so credit where it's due etc.
2002 Volvo V70 T5 - Daily beater
Now completely RWD-less
SeriousSteve is offline   Reply With Quote
Old 02-24-2007, 08:51 AM   #4
242GTMD
I think I still have it..
242GTMD's Avatar
S60R injectors are green and flow 465cc. The blue injectors are off of 99+ T5 motors and flow 395cc.
Chris
GT Spec Turd
GLT Spec Gramps
S60 Spec Super Gramps
242GTMD is offline   Reply With Quote
Old 02-24-2007, 05:10 PM   #5
stoni
stoni's Avatar
can anyone give me also the Bosch or Volvo Part number from the inj. above, just to be sure to have the right injectors ...
Is there a list out there, which lists injectors, flow and part numbers?
SeBCON-µC Programmable Boost Controller
My ride: 945 Turbo MJ. 1993, 530, A-cam, +90M, T3, 9.5:1, 16psi, 630cc/min injectors, modified 937 ECU (modified 967 bin, higher fuelcut, opt. for E85, lower consumption, better top power and throttle response), EZK 148 with 219 bin, 012 AMM, M46/3.73, E85 fuel, 2.5" 200Cel metal race cat, tight squish squirter block (0.030inch)
stoni is offline   Reply With Quote
Old 02-24-2007, 05:28 PM   #6
frpe82
Guest
Bosch "Green giants", 42lb/hr, 0280155968
Bosch "Green Tops", 42lb/hr, 0280150558
I can´t find the p/n for the blue injectors, but they do flow 395cc/min.
Old 02-24-2007, 05:43 PM   #7
stoni
stoni's Avatar
Originally Posted by frpe82 View Post
42lb/hr
= 465cc/min ?
you know, european ... ;)
Old 02-24-2007, 05:44 PM   #8
v40jlt4
300+ Member
http://users.erols.com/srweiss/tableifc.htm
Volvo V40 T4 2000 323BHP/440NM (325lb-ft)
Volvo 940 LPT 1997 Freds Chips 2B modified further if I don't sell it.
v40jlt4 is offline   Reply With Quote
Old 02-24-2007, 05:55 PM   #9
stoni
stoni's Avatar
Originally Posted by v40jlt4 View Post
mh, strange ....
Fred wrote, the Green Gaints 280-968 are 42lb/hr,
the list says 29.5 lb/hr 310cc/min for the same injectors....
Old 02-24-2007, 06:49 PM   #10
frpe82
Guest
= 465cc/min ?
Oh yeah, sorry...
42lb/hr = 440cc/min
mh, strange ....
Yeah, that is strange...
Old 02-24-2007, 07:05 PM   #11
stoni
stoni's Avatar
look at this:
http://www.forums.turbobricks.com/pr...ad.php?t=26083
the blue one has the number 0280155830, problem is the 3,8bar pressure.
If i raise the pressure from 3 to 3.8 bar with the normal 310cc green tops from the FT i will get also 392cc/min. I need inj. which provides 390-410cc with 3 bar.
Old 02-24-2007, 07:08 PM   #12
frpe82
Guest
The 0280150402 CFI injectors will flow 390cc/min @ 3bar.
Old 02-24-2007, 08:04 PM   #13
stoni
stoni's Avatar
ok, found this here, a great paper:
http://209.85.135.104/search?q=cache...lnk&cd=5&gl=de
This list confirms the flow of 391cc/min of the 0280155830 blue R Injector.
Old 02-26-2007, 05:59 AM   #14
stoni
stoni's Avatar
bought on ebay the following injectors: 0280 156 063 - 393cc/min
The injectors are from these cars:
AUDI S3 TT 225PS
VW VR6
VW 1.8T TURBO
They are micro inj., 4-beam type, to fit them i must rebuild the Injector rail. Since i want to drive my turbo with E85, the 4-beam inj. will help hopefully with my cold-start issue on E85.
http://www.nord-com.net/stoni/images/inj_spray1.JPG
Old 02-26-2007, 06:12 AM   #15
JW240
All idiot, no savant
JW240's Avatar
look at this:
probably not. Bernoulli's law.
p = .5 * rho * velocity^2
increase the pressure with factor x, the velocity increases with x^0.5.
Velocity * area = volume flow.
doubling the pressure will give 2^0.5 = 1.41 times as much fuel. Theoretically.
I dunno if efi injectors follow this rule exactly (because of the internal valve etc), but oil nozzles do.
240 | 1991 | 341K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
940 | 1992 | B230FB
Old 02-26-2007, 06:53 AM   #16
MikeHardy
MikeHardy's Avatar
calculations would say that a 310cc at 3bar injector raised to 3.8bar would flow about 355-360CC
Old 02-26-2007, 07:29 AM   #17
stoni
stoni's Avatar
Yeah guys, you're right - was only babbled without correct data ...
Old 02-26-2007, 09:35 AM   #18
frpe82
Guest
AUDI S3 TT 225PS
VW VR6
VW 1.8T TURBO
I have a lot of experience with swapping injectors for the S2 and S4 ones, which are great injectors.
If you are going to use 4-beam injectors, you have to listen to me. To be able to get the same performance out of all of them, you need to have all the connectors on the injectors pointing straight up from the intake manifold. You can´t turn the injectors because the cables/connectors are easier to hook up without any tension in the cables. The connectors must all face up.
If they don´t, the beams will be aimed differently and you will get different results on every cylinder.
On the S2/S3/S4 the injectors are held at the same position, pointing straight up, by a plastic frame so that all the injectors will be aimed at the intake valves.
Those injectors work great. Very good beam and atomisation.
Old 02-26-2007, 09:36 AM   #19
frpe82
Guest
Revised...
Old 02-26-2007, 10:34 AM   #20
stoni
stoni's Avatar
Hmmm... now when looking at the numbers I can see that Bosch number is the stock VW 1.8T injectors. Those are only 300cc/min @ 3bar (347cc/min @4bar).
Fred, don't make me crazy ....., i've looked in more than one list, on several ebay tasks, all are telling these inj. are 380cc/min, my new found list says they have flow tested the inj. with 393cc/min .....
Old 02-26-2007, 05:24 PM   #21
frpe82
Guest
I have to revise what I said before...
I have looked at all the lists available, and the results for the 0 280 156 063 injectors is this:
This page says that those injectors flow 269g/min @ 3bar: http://209.85.135.104/search?q=cache...lnk&cd=5&gl=de
According to this, the injectors should flow 269/0.75 = 359cc/min @ 3bar
And this page says that the injectors flow 347cc/min @ 3bar: http://users.erols.com/srweiss/tableifc.htm
So the flow should be around 347-359cc/min @ 3bar for the injectors you have bought.
And in my experience with the 1.8T engines, and as far as I can remeber, the 1.8T injectors came in three versions (flow taken from memory):
~270cc/min @ 3bar (runs at 4bar in all the VAG engines)
~300cc/min @ 3bar (runs at 4bar in all the VAG engines)
~350cc/min @ 3bar (runs at 4bar in all the VAG engines)
If you run the injectors you have bought at 4bar, the flow would be ~410cc/min.
And regarding the injector "pointing" issue:
What I meant was that the connectors on the injectors should all face straight up from the engine, or else the spray pattern will not be aimed towards the intake valves. The injectors can not lean towards any direction, and this is why all the Audi's have a plastic frame that holds all the injectors in a certain position.
ADDITION:// When you have installed the injectors, they will not move around. They usually sit still.
Old 03-01-2007, 04:20 AM   #22
bmxp
Funny how I found this. Was looking up information for OEM fuel injector specs for this "0 280 156 063" injector. If I remember right it comes of the 225hp audi TT (european version) and the Audi S3 and I believe the Seat Cupra R. I'm not 100% sure if it's a 364cc/min like its counter part here in the US.
The 1.8t only has 3 injectors, the main one is a
317cc/min at 3 bar. All 1.8t engines (except for the audi and passat engines and the 225hp Audi TT)
364cc/min at 3 bar. (225 hp audi TT and the ones stated above)
I can't recall what the audi/passat 1.8t engine has and I think the VW beetle 1.8t engine has a weaker injector I can't recall what it is but it's not worth it
One thing you missed about the injectors you spec'ed on that one page is that it's listed as Statisk kapacitet(100% duty cycle)g/min(n-heptan) @3bar. N-heptan has a different density than gasoline. N-Heptane has a density of 679.5kg/m^3, vs. gasoline's 737.22kg/m^3
unless somebody did the that conversion...
bmxp is offline   Reply With Quote
Old 03-01-2007, 05:17 AM   #23
stoni
stoni's Avatar
Originally Posted by bmxp View Post
0 280 156 063" injector / I'm not 100% sure if it's a 364cc/min like its counter part here in the US.
Yes, it is.
We did the conversion with a density of 0.72 (dont knew the exact value since now, thanks to you), but if you use a density of 737.22 than you have exactly the flow from 364cc/min (listvalue: 269g/min:0.73722=264cc/min )
