Nattvard
- Feb 16, 2014
- Lund, Sweden
Hello,
I'm going to install an oil cooler from a 240 Turbo on my B230FT:ed 1976 242 and get rid of the 13C.
Does anyone know what thread the "nuts" at the end of the hardline that goes in front of the engine is? I measured the outer dimension to 22 mm and the inner to 17 mm. The pipe itself has an outer diameter of 12 mm. I'd like to adapt this to AN10 (screw the metric stuff!). I see two router:
1) Find an adapter from this unknown dimension to AN10. Easiest route if such adapters exist
2) Cut the weird nuts off and weld AN10 fitting directly to the pipe.
Any opinions?
(By the way - I'm looking for the lower bracket for the oil cooler, if any one has one for sale)
Any opinions?
