doucheNozzle
- Feb 26, 2009
- The Pitt, 15147
You weren't ****ting me. You garage is nice. Car is meh. Needs more turbo.
That looks great, I'm pretty sure I like this car more than your other one. Such a hard decision to make!
What's the issue with the speedo? You're using the diff cover pickup?
Just to double check, I believe the sensor has to be shimmed the correct distance from the tone ring.
I dig the new rollers! I had a staggered set of those on my '99 528i and loved them...but the rears were crazy concave and looked rad.
No way....i would put a 60 or a nine inch under it before i would ever think about a 44. Worked on far to many broken 44's to ever own one.
Yes Tethys will be available. More than likely very soon
DNA sequence.....thanks. It's all in the details.
Been working on rear suspension so far this weekend. Rear coilovers are on. Adjustable perches and 10" 175 lb springs. Got a 22 mm rear ipd sway bar on the back.
Also picked up a 25mm bar for the front and a coilover sleeve kit. Might make an attempt at getting the fronts done tomorrow if i still have the motivation.
Sean
This guy my dad built a 59 corvette is rocking the C4 dana 44, 10+ years of constant abuse (over 120k and many many track events) with a documented 650whp and not a single hiccup.
Hell there is some people in the local auto x circuit that are squeezing 500+ through the dana 36 from the C4s
Hell there
