Tfrasca
- Apr 20, 2015
- Ben Lomond, CA
I had a freeze plug pop out of my B23ft the other day. We put new ones in when I had the block cleaned. We used black "aviation sealant" (I think Permatex #2 or some equivalent), and dimpled the middle of the plugs with a ball peen hammer.
They have all held well at much higher coolant pressures, since I used to have a 16psi cap on the car. It is now only 7psi, but I still lost a plug at 6k rpm. I don't suspect a head gasket failure.
Anyway, today I got around to cleaning up the freeze plug hole to pop a new one in, and noticed what looks like some serious core shift between the shoulder and the through hole for the plug. The bottom part of the plug doesn't have much of a should to back it up:
Does that seem weird to you? Would you just put some Permatex on the new Volvo plug and wail on it till it seats? Because that's what I'm about to do.
