Old 06-06-2017, 09:55 AM   #76
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Thank you Kenny for spending your time to show actual data. Despite some morons who want to nit pick and put down your info I found it very valuable to start to quantify this.
Hello My Glorious!
CAPT_BLOTTO is offline   Reply With Quote
Old 06-06-2017, 10:09 AM   #77
JohnLane
Originally Posted by Stiggy Pop View Post
First one I saw was on a Lexus SC400
Those were all about quiet operation. Quiet, effective, no babysitting. Toyota gave that one enough radiator capacity which helps.
Old 06-06-2017, 11:51 AM   #78
James10952001
Originally Posted by JerryJS8 View Post
Not all ECUs support an e-fan, so grab one from a doner that has one installed from the factory. Forget swapping chips and just swap the whole ECU. As long as the engine is the same and the 940 didn't have an immobilizer installed it should work out just fine. AFAIK, If there was an immobilizer installed, then you'll have to get a chip burned to replace the onboard one. That's what I did for my project 740 (see signature) with a 984 ECU, works great with the computer controlled fan.
You'll need to populate pins 10 and 11 on the harness to run a wire to the low and high speed relays on the fan, but it's simple, easy and avoids hacking radiator hoses to install thermal switches.
A list of ECUs with information on motors and if it has an immobilizer can be found here: http://forums.turbobricks.com/showthread.php?t=84817
Replacing the whole ECU is not something I particularly want to do since I've already got a spare that's the same as the one in the car. I can burn EPROMs and populating the connector is no problem but if the actual ECU hardware is different I'll probably just keep the mechanical fan.
James10952001 is offline   Reply With Quote
Old 06-06-2017, 11:57 AM   #79
Marvelous3
Who engineered this?
Marvelous3's Avatar
+1!
Old 06-06-2017, 12:33 PM   #80
Definitely thank you for taking the time to do the dyno pulls! It'll be really cool to see the gains as you get the car back to running well in stock form, and beyond.
The 240 rally car sees a lot of high revs and sideways action, so air is not always going into the radiator, and the tropical clutch is almost always engaged by the end of a stage (who knows when it kicks on). So for us, the power loss from a fully locked up fan at 4k-7.5k rpm is actually of interest. The good news about that setup is that we have never seen temps over 200F on stage.
I just installed a shrouded e-fan from a 9 series and used the thermo switch in the radiator as well as a switch inside. Heading to one of the hottest rallies we do every year this weekend, will report back on how the system worked.
Old 06-06-2017, 12:38 PM   #81
JohnLane
You sir are in need of more radiator capacity.
Aftermarket aluminum radiators can be purchased by core size, by application... Made up however you like. Another 3-5 pounds in a big aluminum radiator is well worth the effort when the engine stays cool regardless of savagery on the part of the driver.
I did this in the rallycar. Temp gauge never climbs.
Old 06-06-2017, 12:46 PM   #82
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Agreed. Mishimoto would is a go-to for aftermarket aluminum radiators for me. They have fantastic build quality, not to mention a kick ass warranty that covers front end collision.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 06-06-2017, 02:33 PM   #83
I wouldn't say it needs more capacity. The system works just fine as it is with a stock fan shroud and tropical fan clutch, since it never sees the temps over 180-190F and the needle is steady.
Old 06-06-2017, 02:42 PM   #84
thismachine13
Out of curiosity....why did you decide to switch to an efan? Noise? Engine bay space? Seriously curious.
thismachine13 is offline   Reply With Quote
Old 06-06-2017, 02:54 PM   #85
The added space is a bonus, but it comes down to being able to control the fan.
The mechanical fan definitely does work, but it's likely overkill and we have no clue how often it's actually on.
The e-fan will use less power when it's on, and we can control when it's on and off... which may be more often than the mechanical fan... but who knows?
Old 06-06-2017, 03:22 PM   #86
thismachine13
Thank you.
Old 06-13-2017, 03:56 PM   #87
Update on the efan:
It worked great all weekend at the rally race. We never had to over-ride the stock temp switch, and the coolant temps never got over 195F-ish while on stage. Ambient temps were from 60-80F.
Old 06-13-2017, 04:15 PM   #88
gross polluter
They see me trollin'
gross polluter's Avatar
Update on the efan:
This didn't happen to be the Idaho race, was it?
Old 06-13-2017, 05:01 PM   #89
Yep!
Old 06-13-2017, 08:59 PM   #90
gross polluter
Yep!
Cool. My sister was racing her E30 there this past weekend. Looked like good times.
Old 06-13-2017, 09:31 PM   #91
She was navi for Eli? If so, I met her at Olympus when she was navigating for Rebecca. Small world!
Old 06-13-2017, 09:32 PM   #92
gross polluter
Yep! Shannon is my lil' sis.
Old 06-13-2017, 10:10 PM   #93
Can play the blues
Isn't the real story that you should spend money on other performance improvements?
Then if you can't leave well enough alone or you want a quieter fan so you can hear more turbo noise. Go for the efan.
Just my thought. Myself I have not changed any of my cars But I am not against using electric fans. I like adding the extra pusher in front. It helps the a/c work a bit better in the hottest part of the summer. Added that to the 82 turbo when it had working a/c.
1982 242 turbo. 339k miles. Lots of good changes.
1993 245 Classic, 415k miles, enem V15. 5spd. IPD bars and chassis braces. Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
