Old 02-21-2019, 01:24 PM   #1
Marvelous3
Who engineered this?
Marvelous3's Avatar
Default external wastegate with a 90+ manifold
Is anyone using an external gate with a 90+ manifold? I'm trying to do this and am curious how people have the gate set up.
Old 02-21-2019, 01:55 PM   #2
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I'd do it sloppy style and weld on to the turbine housing
Megasquirt Tuning!
Old 02-21-2019, 06:02 PM   #3
Marvelous3
Marvelous3's Avatar
Have any idea what welding wire people use? 309?
Old 02-21-2019, 06:47 PM   #4
309L is my filler of choice when welding to cast-iron.
I heat the casting up with my 40k btu propane heater, weld them, post heat for 5-10 minutes, and then wrap it in a welding blanket until it's cooled down.
Old 02-26-2019, 11:03 PM   #5
mark244turbo
mark244turbo's Avatar
http://i31.photobucket.com/albums/c3...ps4a904c8d.jpg
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 02-26-2019, 11:22 PM   #6
Marvelous3
Marvelous3's Avatar
^^My man!
Old 02-26-2019, 11:31 PM   #7
2turbotoys
Astro Zombie
2turbotoys's Avatar
Use an internal wastegate housing, you can get a flange that bolts to it instead of the wastegate housing, do this:
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 02-28-2019, 03:54 PM   #8
Stefan940T
I'm using a 90+ manifold, eBay T04E turbo and a custom EWG set-up
https://www.instagram.com/p/Bh64AAflWaw/
Stefan940T is offline   Reply With Quote
Old 02-28-2019, 04:51 PM   #9
Sjeng
Sjeng's Avatar
Use a NA manifold and fabricate a nice steel up-pipe (can be twin entry).
Weld wastegate flange to up pipe.
Flows better than 90+, proven to 600+hp.
No need to weld cast, good performing manifold, and cheap as hell.
Sjeng is online now   Reply With Quote
Old 02-28-2019, 04:52 PM   #10
white855T
If I were to go this route, this looks to be the best method. Looks great!
Old 03-04-2019, 02:51 PM   #11
BDKR
Section 9
BDKR's Avatar
Can we see a pic with the oil return?
On mine, the WG is a bit further downward. I did interfere a little with the oil return. That's why I'm asking.
For all you Dijkstra fanboys:
Old 03-04-2019, 03:36 PM   #12
Stefan940T
Old 03-04-2019, 11:36 PM   #13
BDKR
Section 9
BDKR's Avatar
Cool.
Now if I could just find a picture of mine.
Old 03-05-2019, 12:01 AM   #14
2turbotoys
Astro Zombie
2turbotoys's Avatar
Still like my solution best, no welding to cast manifolds (never a good idea) and simple
Old 03-05-2019, 12:08 AM   #15
BDKR
Section 9
BDKR's Avatar
The bit that looks like a trumpet going off to the right is what mounts the WG. It's been tweaked a little since this pic and is tapped right before the WG entry to get a pressure reading.
Old 03-05-2019, 12:09 AM   #16
BDKR
Section 9
BDKR's Avatar
Yeah, you're probably right. I think I'm just lazy.
