Old 10-13-2020, 03:31 AM   #1
BeaverMeat
Question Spacer and extended studs
I am wanting to use a 5mm spacer with my 740 Dracos on my 240 to get the proper ET20.
There are a few options for spacers. H&Rs are on the top of my list along with Motorsport Techs. Is there anything else "better"?
Just to be safe I want to install extended studs. Who offers the "shortest" extended studs? I plan on using the longer wheel nuts but, I don't want cut them to fit as I'm ill-equipped to cut them down "nicely"... a Dremel and a sacrificial wheel nuts.
Thanks
BeaverMeat is offline   Reply With Quote
Old 10-13-2020, 03:54 PM   #2
Lankku
Lankku's Avatar
700/900 rear stud is slightly longer. Naturally then you would need 700/900 nuts also.
With a 5mm spacer the rim isn't hubcentic anymore so take care when tightening the nuts.
245 -90 "B6284T"
Old 10-13-2020, 04:16 PM   #3
4 & 5 Lug 3mm Thick Spacer (Pair) $11.99
Old 10-13-2020, 08:41 PM   #4
mooseturb
I have used Motorsport Tech products (spacers and hub-centric adapters) on several vehicles, quality products and good to deal with.They will know what you want.
mooseturb is offline   Reply With Quote
Old 10-13-2020, 10:14 PM   #5
Fred Gwynne
FWIW those spacers work with the stock studs on my car but the nuts really are flush with the end of the studs.
Fred Gwynne is online now   Reply With Quote
Old 10-13-2020, 10:46 PM   #6
You can usually get away with 3mm spacers without totally losing your mind / breaking the bank.
Old 10-14-2020, 11:20 AM   #7
Volvo sells an shorter extended stud for the 240 (at least they used to) but its fairly $$$
Much cheaper to buy these and cut them to the length that you need or want.
https://www.bneshop.com/collections/...-wheel-spacers
We can always charge you to shorten them if you got money to burn and don't want to DIY.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-15-2020, 10:34 PM   #8
Missing the offset by 5mm isn't really a problem, early 240 steel wheels were the same offset as Dracos at 25et after all...
Old 10-18-2020, 09:36 PM   #9
BeaverMeat
Right now the car has 16x7 ET18 rim with a 205 wide tire. It’s a very tight fit as it is.
The tires for the Dracos will be 205/60r15 and the offset change will pull the wheel in by 8mm. There isn’t 8mm of room to spare.
Old 10-18-2020, 09:42 PM   #10
I had 225-50-15 steamrollers on Dracos and they didn't hit but the car went down the road wandering around & shaking like a dog trying to sh!t peach pits.
That said I'd bet they clear just fine with 205s.
Old 10-18-2020, 10:18 PM   #11
BeaverMeat
lol
You’re probably right... I’m just getting overly technical and over planning again.
Old 10-18-2020, 11:03 PM   #12
Your ADHD is kicking in hard, an inch wider wheel will make a significant tire profile difference even with the same exact tire.
NB:
You'll need right around 6 turns of the lug nuts to be safe with 1/2 x 20 threading, so I'd test fit them before buying the 3mm spacers.
Stock 240 studs with 5mm spacers and alloy wheels won't offer quite enough threading engagement in my experience.
Old 10-18-2020, 11:07 PM   #13
LC4CARL
Aero challenged
LC4CARL's Avatar
Virgo on BNE.
@PDXvolvo on IG
Old 10-18-2020, 11:28 PM   #14
Besides which beating the studs in and out of an installed hub isn't paticularily good for the bearing races which is why Volvo supplied a press to do the job right.
Old 10-18-2020, 11:35 PM   #15
BeaverMeat
NB:
I’ll see how I rolls.
I don’t want spacers... try my best to avoid them.
Virgo on BNE.
One day when I find a set. The price was right on these Dracos so I’ll roll them.
Old 10-18-2020, 11:41 PM   #16
I had to use some the 3mm EZaccessory spacers to clear the 240 front vented calipers with some 15 Spoke Desone wheels and it was fine.
Right about 6 turns fine to be exact.
Surprised you aren't buying some 195-65-15 snows for your dragoon wheels?
Old 10-19-2020, 12:20 AM   #17
BeaverMeat
These are for the slick above freezing rain we get all winter. For a rain specific tire it’s preferable to have a wide contact patch. I went with Vredestein QuaTrac 5 all-weathers because they’re asymmetrical, excellent rain performance, and for the money they aren’t absolute garbage. Had them on my Miata which would skate around in the rain. It was actually frightening. These tires planted the car.
Don’t really need winter tires on the car all winter on this island. Since I’m a wheel whore I am wanting a set of wheels for hardcore studded winter tires just in case.
195/65r15 or 195/70r14
Old 10-19-2020, 12:26 AM   #18
BeaverMeat
Double post
Old 10-19-2020, 12:40 AM   #19
Sounds good, I was thinking Canadian winters but kind of glossed over the Vancouver islands part.
