Old 04-08-2016, 01:32 PM   #126
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
lambda is a flag iirc. There should be more info on the injector constants as well, I think if you get that really out of whack it does odd things to the load calcs and signal as well
on some of the xdf's you can hover over the parameter and it'll have a blurb about what it is and does.
Megasquirt Tuning!
Old 04-08-2016, 10:19 PM   #127
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
I'll look further for the flag, now that I'm out of PC hell & have the MiniPro software & USB driver issued sorted out in WindBlows8.1 - ****ing 'BitLocker" crap.
Main thing I want right now is a higher rev limit. Put the 24lb injectors in today - cold start AFR's are improved, and light / part & heavy load AFR's are much improved. No sign of any knock. I'm going to see if I can run the 3º advanced curve with this injector / MAF combo before I tweak any EZK settings.
My XR July2013 - 446AWHP @ 8K rpm Feedback Thread
Old 04-09-2016, 08:14 PM   #128
lookforjoe
lookforjoe's Avatar
Old 04-12-2016, 11:15 PM   #129
lookforjoe
lookforjoe's Avatar
Clutch master took a ****, so had to work on that & the brake master over the weekend. Should be able to get back to tuning shortly
Old 04-15-2016, 10:20 PM   #130
lookforjoe
lookforjoe's Avatar
Running quite well, Adaptive seems to be settling the fueling disparity with the 24lb injectors. Clutch hydraulic problem was actually caused by a mechanical issue with the throwout fork & actuating lever
fingers have some wear - I'll swap out the clutch while the transaxle is out
Old 04-19-2016, 09:49 PM   #131
lookforjoe
lookforjoe's Avatar
Running it lean initially didn't work out well. Even though I didn't drive it more than 1/2 mile under very light load when it was still running the 18lb inj. - I found it missing & determined that I had lost compression, specifically on #2.
Pulled the head & found the fire rings damaged
pistons & bores look OK
Old 04-19-2016, 09:52 PM   #132
lummert
lummert's Avatar
I've never seen a head gasket do that before.
Old 04-20-2016, 11:41 PM   #133
lookforjoe
lookforjoe's Avatar
AFR's were 14.7 @ idle, but 15-16(!) under light load (minimal throttle, didn't push it as it felt all wrong)
Detonation does that - my compression is also 10.7:1.
Old 04-21-2016, 03:15 AM   #134
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
To have the fire rings deform like that? I'd be inclined to claim that that is the most common first symptom of detonation. If you're lucky it's possible that the detonation damage is limited to just the head gasket. If you're not lucky, it will be somewhat more expensive.
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 04-21-2016, 08:00 AM   #135
lookforjoe
lookforjoe's Avatar
I'm going to draw a vacuum on each cylinder. If they all hold up equally, I'll likely just put it back together. If not, I'll drop the pistons. The bores look fine, but that doesn't rule out some ring damage of course.
I was expecting to see obvious evidence of bore/piston damage on #2, so I'm happy that is not the case. The 87mm "flat top" pistons are very hard to get, and required flycutting for the oversize valves. Rings will be easy enough to locate.
Old 04-21-2016, 08:46 AM   #136
linuxman51
linuxman51's Avatar
yeah. if it was a volvo motor I wouldn't even check the pistons, seen several gaskets go like that with nothing worse for the wear.
hopefully it all checks out.
Old 04-21-2016, 10:18 AM   #137
F*ck 12
Still trying to figure out why you're trying to run your motor so lean, 2.2 and 2.4 are MAF based and should only inject as much fuel that will go along with that mass of air/load signal. I wouldn't think you'd have to adjust the tables injector size too much unless your engine magically has a different stoich ratio or the air in NY has some fuel already in it. I understand low 12's give the best power theoretically but you just found out what uncontrolled detonation will do.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 04-21-2016, 10:21 AM   #138
linuxman51
linuxman51's Avatar
I don't think he's really gotten it tuned yet, I doubt he wants it to run in the 16's under load...
Old 04-21-2016, 05:36 PM   #139
lookforjoe
lookforjoe's Avatar
Not trying to run it lean at all - I had 18lb injectors in there, running LH2.2, AFR's were OK - 13's under mid - high load, 14.7-15.2 idle & cruise.
For whatever reason, after switching to LH2.4, it wouldn't keep an AFR under 15 as soon as any load was placed on it with the stock MAF & the 18lb injectors . As I stated, I only drove the car a very short distance around my neighborhood under very light load (almost no throttle) as it became abundantly clear it was NOT going to adapt (I have a AEM WB02 in the car). I switched to 30lb injectors & 012 MAF to confirm that fueling was the issue, and drove a few miles that way. Ran great, AFR's perfect under light load, but way too rich under mid/heavy load (12's & richer).
Anyway, I ordered 24lb Bosch injectors & put those in with the stock 016 MAF. Decent AFR's across the board, but clearly the damage was already done. Just glad I didn't drive the car any further before detecting the issue.
Didn't even get to the point of attempting any tuning yet....
Old 05-01-2016, 09:20 AM   #140
lookforjoe
lookforjoe's Avatar
Unfortunately enough detonation to break the ring lands on one of the Mahle pistons
cracks are visible here (pistons have grease from my coating the bores while it sat with the head off for a few weeks)
I pried out the broken pieces
These pistons have less than 1K miles on them since I built the motor. Should have installed LH2.4 from the start - with no control over timing adjustment, 93 r/m2 fuel & 10.7:1 compression, I guess it was inevitable something would break.
The problem now is that there are no more 87mm 34.15CH Mahle pistions out there, so I will likely have to go with forged. With my experience with Wiseco's, I'm not entirely keen on that prospect.
Old 06-21-2016, 06:56 PM   #141
Mueller
Mueller's Avatar
Any new progress on this?
Get new pistons?
Old 06-21-2016, 10:05 PM   #142
lookforjoe
lookforjoe's Avatar
Get new pistons?
Hey, thanks for the interest.
Yes, had to go with custom from Wiseco. No Mahles in this spec left in the world.
Just put them in last Friday along with new Clevite rod bearings.
checking the ARP bolts for correct stretch
Waiting for the head work to be completed. Intake valves recessed another .010", exhaust valves recessed .040". Based on the calculations, that, along with the increase in piston volume above the ring land & larger flycuts should get me down from 10.7:1 to 10.3:1.
Old 06-21-2016, 10:26 PM   #143
Hope you don't plan to continue messing with LH...
Old 06-21-2016, 10:50 PM   #144
lookforjoe
lookforjoe's Avatar
Yup - gonna be running LH2.4. Now that I have the injector sizing figured out (expensive test) I can get it running & then look at tweaking the timing map to optimise for my setup. Dropping the compression to 10.3:1 range will make it a little more forgiving.
Old 06-21-2016, 11:35 PM   #145
Old 06-21-2016, 11:38 PM   #146
Mueller
Mueller's Avatar
I like stubbornness once in a while!
Old 06-22-2016, 10:06 PM   #147
lookforjoe
lookforjoe's Avatar
Machine shop head work completed.
Valves recessed
measured chamber volume -
they are all at 35cc, which is not enough to drop the compression down to 10.3:1
took a little out around the back wall and the exhaust
now it's 36cc
(took a tiny bit more out after this measurement to get exact 36cc)
Just have to do the same for the other 3 cylinders....
Old 06-29-2016, 10:03 PM   #148
lookforjoe
lookforjoe's Avatar
Measured the Wiseco piston pop-up & flycut volume.
.035" pop -up (must have made an erroneous measurement - this doesn't make any sense - should b .025", CH is 1.344", slightly under the 1.3445" of the Mahle's)
2.1cc flycut.
Deeper offset of ring land from piston crown, and smaller OD of the crown above the ring land (8mm vs. 6.5, and 86.15 vs.86.5) which should net me almost .5cc volume gain over the Mahles
36cc chamber volume.
Just need to do the math to figure out what this translates into in terms of revised static CR
Checked head alignment dowel depth again. Measured TTY head bolt insertion depth; even though they are longer, they still have .25"/6mm clearance in the block. I used the hardened washers anyway.
Bolt bottomed in head
Put putty in the flycut to check valve clearance (valves have been further recessed to increase chamber volume);
installed original thickness HG, torqued to 20ft/lb
after:
no contact at all, so no worries there.
Engine mostly back together. TTY bolts torqued in 4 stages: 14ft/lb, 29ft/lb, 90º, 90º.
Still have to weld a boss on the oil pan to provide a 2 point bolt down for the crank position sensor, so that will hopefully get done tomorrow, then I have to finish up the revised exhaust.
EDIT: checked Squish:
Used soldering wire, pre compressed:
after compressed:
checked against calipers
Old 06-30-2016, 12:27 AM   #149
bobxyz
bobxyz's Avatar
Wow, beautiful workmanship! Very nice.
Have you thought about adding a MegaSquirt just for logging? I think you could tee off existing or temporary sensors and get temp/map/maf/rpm and afr (with wideband) but not timing advance. Once it's tuned and happy, you could sell the MS for not much loss.
Old 06-30-2016, 07:22 AM   #150
lookforjoe
lookforjoe's Avatar
Thank you.
My main concern is really the timing map. I would like to be able to log that. I do have an Ostrich 2.0 that I am going to feed into the EZK116. I'm assuming the live trace feature works in Tuner Pro with the available bins, but perhaps I'm mistaken.
Once it's up & running, and had a few hundred miles to settle in I'll have to start playing around with that.
EDIT: I do have the log box from my M4.4/TunerPro install - I hadn't thought of repurposing that for LH2.4/Tunerpro use - I may be able to get the creator to write them into the ADX (or is it XDF, I always get them mixed up)...
