Old 04-24-2015, 08:20 PM   #1
t8fanning
8v are still cool, right?
t8fanning's Avatar
Default 850 TPS Adapter
I've searched, and found a few solutions to adapt the Volvo 850 TPS to a 240 throttle body, but I was unhappy with all of them. So I made my own.
Designed it and came up with this. I 3D printed it for easy testing:
Then I made this:
Here it is in action:
I think it turned out pretty well, and will work just fine. At first I was worried about the heat and a 3D printed part, but I think if I printed it with ABS it would work. So if anyone wants to try a 3D printed one, let me know.
1982 242 Turbo.
Old 04-24-2015, 08:46 PM   #2
740atl
educator monkey
740atl's Avatar
Looks great. Did you cnc the finished part? Wanna make some more?
Old 04-24-2015, 10:05 PM   #3
t8fanning
t8fanning's Avatar
I did CNC the aluminum one. I've thought about making some more, but haven't decided yet. What would a reasonable price be?
Old 05-12-2015, 01:20 PM   #4
tt460
tt460's Avatar
Nice work.
Is there any particular reason you put the slotted screws on the inside screws vs the ones that hold the TPS? Seems like it will be hard to adjust the TPS since you have to remove the sensor, adjust, replace sensor, take a reading and repeat if it's still not right.
I'm guessing you already thought of this and you designed it the way you did for a reason, but it would be easier if the adjustment screws weren't captive by the sensor itself.
87 Volvo 745T
lambdatuner.com
tt460 is offline   Reply With Quote
Old 05-12-2015, 01:29 PM   #5
t8fanning
t8fanning's Avatar
Thanks.
Yes, I put the slots inside mostly because I like the looks better, and I wanted to mount directly to the throttle body rather than the stock TPS bracket. RSI designed one that mounted to the bracket, and it looked like this:
I don't really like the looks of this design, and it would require significantly more material and machine time. Additionally, I knew I would have to set it once and forget about it, so I wouldn't need frequent access to the adjusting screws. Sure it takes a bit more time to initially set up, but I have to convert intake manifolds for my build anyway, so it's very easy to do outside the car. I just set it so the end of the potentiometer travel is when the throttle plate is parallel to flow.
Old 05-13-2015, 08:56 AM   #6
tt460
tt460's Avatar
I agree, your design is much cleaner and more simple. You've definitely thought it through. Good work.
I'm working on an MS3 box right now and building a plug & play to replace my aging LH2.2. So the 850 TPS is a true potentiometer style sensor? Does it use the same connector as the LH2.x style "throttle switch" sensors? (I'm assuming the wiring would be different if it's a pot style sensor, requiring 3 wires for +5v, sensor ground and signal return)
Old 05-13-2015, 08:58 AM   #7
Stiggy Pop
Stiggy Pop's Avatar
It's a 3 pole Bosch junior power timer connector, like on an lh2.4 crank position sensor.
'79 242
943 pickup
Old 05-13-2015, 09:08 AM   #8
t8fanning
t8fanning's Avatar
Thanks! And yes, the 850 tps is a true potentiometer. It does require a 3 wire connector.
Old 05-13-2015, 10:07 AM   #9
gsellstr
gsellstr's Avatar
Uses the same connector if I believe, pinouts are different. I've got a home-brew adapter to do what the OP did, not nearly as clean since I have no CNC, but the 850 TPS works nicely with MS.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 05-13-2015, 02:13 PM   #10
I ran a 3d printed TPS adapter on my 240 and never had any issues with it.
I would prefer to run aluminum though.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is online now   Reply With Quote
Old 05-13-2015, 04:39 PM   #11
t8fanning
t8fanning's Avatar
I actually sent a 3D printed one to a guy recently. I did 100% fill, so I think it'll be fine, but I'm waiting on his review. If anyone wants a 3D printed one of mine, I'd be happy to make one.
I'm going to IPD for the garage sale and could be talked into bringing a few.
Old 03-15-2016, 09:08 PM   #12
cwdodson88
Any idea if this would work on a b20 djet manifold? I apparently forgot to loctite mine and lost my tps sensor all together.
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-16-2016, 03:08 AM   #13
t8fanning
t8fanning's Avatar
No idea. What's the distance between bolt holes for the stock throttle switch?
Old 03-16-2016, 10:38 AM   #14
cwdodson88
They are 2.75" apart and perfectly vertical. But I have a nice bit of flat space that I could drill and tap.
Old 03-17-2016, 05:02 AM   #15
kimove
hmm i could use one of those :p
Aerodynamics is for people who cant build engines
kimove is offline   Reply With Quote
Old 11-09-2017, 04:08 AM   #16
jsdevel
jsdevel's Avatar
Recently used the Yoshifab adapter on an MS2 conversion and was having trouble with TPSdot lag. Turned out that the TPS I used (same as in OP) expected a bigger diameter shaft than what my 2.4 TB had. Cut a 1/4" wide 2" long piece off a soda can, wrapped it around the TB shaft, put the TPS back on and no more lag. I noticed the lag when I had a MAPdot gauge right next to a TPSdot gauge in TunerStudio. AccelEnrich is much more responsive now and I don't have the idle issues I was having with 100% MAPdot based AE.
jsdevel is offline   Reply With Quote
Old 01-25-2018, 03:01 PM   #17
t8fanning
t8fanning's Avatar
A few people have asked for the files, so I figured I'd just include them here.
A folder is attached with the solidworks part file and two stl files (I don't remember if they're different, but 3D_print_TPS_Adapter.STL is the newest one). Enjoy, and if you use this, don't "mass" produce and sell them.
Old 01-25-2018, 03:42 PM   #18
MrBrown
MrBrown's Avatar
Thank you!
GhettoFab build thrizzie
MrBrown is online now   Reply With Quote
Old 02-11-2018, 01:18 PM   #19
BDKR
Section 9
BDKR's Avatar
Thanx!!!! I'm about to use an 850 TPS so I needed a solution.
For all you Dijkstra fanboys:
Old 02-26-2018, 08:14 AM   #20
FreeEMSFred
FreeEMSFred's Avatar
Not required with a later throttle such as the B234F, right? It's still a switch type, but the screws are far apart as above, I think. Or am I confused?
