Old 03-22-2019, 01:01 PM   #2501
LC4CARL
Aero challenged
LC4CARL's Avatar
Turbo motor passed the smog test. Glad I left the cat on for the visual.
@PDXvolvo on IG
Old 03-22-2019, 01:54 PM   #2502
mrak
Beefsma by Design
mrak's Avatar
Originally Posted by LC4CARL View Post
Looks pretty nice.
So much gravel on the roads. But no salt? Growing up in Michigan the cars rusted badly. Many of the older Alaska cars I saw still looked pretty solid.
It depends on how far north you are. Historically we haven't salted the roads, so most of the rust comes from cars parked in fields with wet grass. But recently as the wintertime temps have increased, they've started using a salt solution on the roads here when the temps are hovering around freezing. Once it drops down below 25 they stop salting.
mrak is online now   Reply With Quote
Old 03-22-2019, 05:37 PM   #2503
LC4CARL
Aero challenged
LC4CARL's Avatar
Cool. When I moved to Arizona I thought I’d gone to heaven with all the rust free steel.
Old 03-22-2019, 05:43 PM   #2504
LC4CARL
Aero challenged
LC4CARL's Avatar
“Ray Charles with his feet” booger welds for the new wide-band hook up. Sigh.
Old 03-22-2019, 05:48 PM   #2505
LC4CARL
Aero challenged
LC4CARL's Avatar
The dyno sniffer said that my AF is OK but, since I have the gauge, what the heck.
Old 03-22-2019, 05:51 PM   #2506
LC4CARL
Aero challenged
LC4CARL's Avatar
“Transmission” leak appears to be blow-back from an engine oil leak. It never ends...
Old 03-23-2019, 11:51 PM   #2507
MrBrown
MrBrown's Avatar
You’re right it never ends.
GhettoFab build thrizzie
Old 03-25-2019, 11:10 AM   #2508
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
We're rich men owning these cars.
-Stephen
#mclovethesenuts
-My car: White 1991 244, 330k miles. B230F LH2.4, AW70, R134a retro
-Wife's car: White 1990 244DL, T cam, 200k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
-PSM 2002 Subaru WRX wagon: EJ205, 5MT, 120k miles, Perrin TBE
-1997 Subaru Legacy Brighton: EJ22, 5MT, 236k miles
Old 03-25-2019, 01:45 PM   #2509
mrak
Beefsma by Design
mrak's Avatar
Isn't that a little close to the turbo outlet?
Old 03-25-2019, 02:44 PM   #2510
thessejway
Wannabe TBer
thessejway's Avatar
Yes.
See page 10
https://www.aemelectronics.com/files...GO%20Gauge.pdf
"Mount the O2 sensor in the exhaust system at least 18 inches downstream from the exhaust port"
____________________________________________
1993 945t
thessejway is offline   Reply With Quote
Old 03-25-2019, 03:23 PM   #2511
LC4CARL
Aero challenged
LC4CARL's Avatar
Going in I thought we would mount it under the car but the muffler guys said it should be placed ahead of the cat. I don’t know to what extent the cat effects the reading. As I recall, the efi O2 threads into the bottom of the manifold before the turbo. Any advice would be appreciated.
Old 03-25-2019, 10:20 PM   #2512
77volvo245
77volvo245's Avatar
You are going to burn up your wideband. Where is your cat located? stock b21ft location?
STSmachining
Old 03-25-2019, 11:25 PM   #2513
Doubt it. That engine is putting out relatively little heat.
Old 03-25-2019, 11:46 PM   #2514
Unless you have a stupid E-fan then it's gonna cook.
Old 03-26-2019, 03:40 AM   #2515
quillc
yv1a.com
quillc's Avatar
You need to be before the cat. If you have it after the cat (assuming the cat isn't a gutted shell), you will have erroneous readings. https://www.youtube.com/watch?time_c...&v=HADOcrcMikA
All modern vehicles have pre and post cat O2 sensors.
Chris
www.yv1a.com
Old 03-26-2019, 11:11 AM   #2516
Cwazywazy
Single jingle
Cwazywazy's Avatar
I had mine in that spot for a long time without issue. Just leave it until you upgrade the whole exhaust.
I don't know what I have
Old 03-26-2019, 11:13 PM   #2517
LC4CARL
Aero challenged
LC4CARL's Avatar
Old and busted.
New hotness.
Old 03-26-2019, 11:21 PM   #2518
LC4CARL
Aero challenged
LC4CARL's Avatar
Dye in oil / black light. Bottom to top.
Old 03-26-2019, 11:24 PM   #2519
LC4CARL
Aero challenged
LC4CARL's Avatar
Amazingly the turbo drain is dry. Best guess is the oil cooler connection. The fitting is tight. Maybe try new washers.
Old 03-26-2019, 11:40 PM   #2520
Or anneal them on the kitchen stove.
Yes there's a method to this madness, the wider ones you'll find aftermarket don't produce the pee-ess-eyes to seal as well.
Old 03-30-2019, 12:56 AM   #2521
LC4CARL
Aero challenged
LC4CARL's Avatar
What would you price the Pdx dl at? No wrong answers. Just a survey. Thx.
Old 03-30-2019, 11:38 AM   #2522
Probably less than you paid for it on here, [think $14.99] maybe more on BAT, but you'd get raked over the coals in the comment section there for molesting it.
Old 03-30-2019, 08:21 PM   #2523
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
It’d probably an honest 5-9k on BaT because of how well documented and properly tweaked it is.
IMO
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 03-30-2019, 09:30 PM   #2524
IMO
It might even break the $2.5K mark.
Old 03-30-2019, 10:03 PM   #2525
LC4CARL
Aero challenged
LC4CARL's Avatar
BaT?
