Old 06-16-2019, 06:04 PM   #2576
oldschoolvolvo
oldschoolvolvo's Avatar
I used some jute padding under the carpet which helped to cut down on the road noise.
https://www.albrightssupply.com/Jute...z-p/jute40.htm
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 06-16-2019, 10:56 PM   #2577
Originally Posted by LC4CARL View Post
I did the Dyna-Mat on the floors and doors. Put the foam thing in the shifter tunnel and insulation under the hood. Any other tips for a quiet 240?
Get a 244
Old 06-17-2019, 11:15 AM   #2578
LC4CARL
Aero challenged
LC4CARL's Avatar
I like it. Maybe around the wheel wells in the back. Or above the head liner.
I've noticed that many new cars use a felt type material for fender skirts now vs plastic.
@PDXvolvo on IG
B21FT with a T3/T4, STS coil-overs, T5 trans.
Old 06-17-2019, 11:20 AM   #2579
LC4CARL
Aero challenged
LC4CARL's Avatar
Get a 244
I've heard that too. Are sedans really quieter that wagons?
It's mostly the road noise that fatigues. The motor / exhaust noise is reasonable.
Old 06-17-2019, 11:34 AM   #2580
Ya don't turn the key.
how psi stock cna sprout?
Old 06-17-2019, 12:02 PM   #2581
yep the cargo area is a big resonance chamber. A cargo cover helps too.
Old 06-19-2019, 06:58 PM   #2582
LC4CARL
Aero challenged
LC4CARL's Avatar
Don't want to worry about excessive heat building up in the steering during the heat of battle over the summer months...
Old 06-19-2019, 07:12 PM   #2583
Use ATF, not power steering fluid. Your rack and pump will leak in short order
Old 06-19-2019, 08:58 PM   #2584
culberro
culberro's Avatar
Will it? I run the Redline PS fluid in the rally cars, and drift car without issue. DD 240 gets whatever is red and in excess supply.
Old 06-19-2019, 09:38 PM   #2585
Seen many cars with significant pump leaks and bottles of power steering fluid and snake oil half empty. I'll go on a limb here and suggest causation based on this and correlation.
From the horse's mouth:
"Power steering fluid
Capacity: 0.8 US qts = 0.75 1iters
Fluid type: ATF type F only
Replace: no fluid change required.
The dipstick is attached to the cap. Fluid level should be between MIN and MAX marks. Add fluid
when the level is at the ADD mark."
https://volvo.custhelp.com/app/manua...1988/model/240
Old 06-19-2019, 11:32 PM   #2586
LC4CARL
Aero challenged
LC4CARL's Avatar
Anybody know about dash lighting? I replaced all the burned out bulbs, but the speedo, small gauges and HVAC are still dim. I was thinking about trying LED, but don't know what number bulb I'm looking for. Not a 194, I know that much.
https://www.superbrightleds.com/sear...er-gauge/dash/
I found these. Any advice would be much appreciated.
Old 06-20-2019, 12:58 AM   #2587
77volvo245
77volvo245's Avatar
From their website I think he is good
RED LINE POWER STEERING FLUID satisfies the service fill requirements of most auto manufacturers and can be used where the manufacturer calls for any automatic transmission fluid such as Dexron®, Dexron II®, II-E®, or Dexron III®, Ford Type-F, Mercon or M2C138-CJ such as required by Ford, AMC, Toyota, Nissan, Lexus, Infiniti, Jaguar, VW, Mercedes-Benz, BMW, SAAB, Subaru, Volvo, Porsche, Mitsubishi, Mazda and many others.
STSmachining
Old 06-20-2019, 10:56 AM   #2588
Huh. Fair enough then.
Old 06-20-2019, 11:41 AM   #2589
LC4CARL
Aero challenged
LC4CARL's Avatar
My rack leaks...
And the engine.
And the trans.
I'm getting a Corvette.
Old 06-20-2019, 11:49 AM   #2590
My rack leaks...
And the engine.
And the trans.
Cheaper than trying to build one out of a sow's ear.
Old 06-20-2019, 12:16 PM   #2591
My rack leaks...
And the engine.
And the trans.
Nooooo. S2000!! M3!!! Not a Corvette!!!!
Old 06-20-2019, 12:33 PM   #2592
hackster
For what its worth, I am running Royal Purple synthetic power steering fluid in my car, seems to be doing ok now. Curious how it does in the long term. I have had excellent luck with it in my buggy for the last 12 years.
I would take a vette over an S2000.....fan boy cars. E92 m3 vs. Vette is a tough one, Beemer is better build quality by a long shot, vette is faster and way easier and cheaper on maintenance.
You find your motivation to get this thing done yet? Summers here...
hackster is offline   Reply With Quote
Old 06-20-2019, 01:00 PM   #2593
Kids are sucking up my motivation. Been carrying 90% of child rearing duties over the last 2-3 months so I get maybe 4 hours a week total to work on it. I welded and painted a bracket last night though, so I have that going for me.
As far as Vettes go, they are definitely faster and cheaper, but feel harsh and kind of brutal. I kind of like how delicate the others feel by comparison. Then again my garbage is an oxcart by comparison to the others so my point of view is weird.
Old 06-21-2019, 07:58 PM   #2594
LC4CARL
Aero challenged
LC4CARL's Avatar
Does anybody run their PS fluid through the transmission cooler in the radiator?
Old 06-21-2019, 09:55 PM   #2595
I mean if you run it in the return I don't see why not
Old 06-21-2019, 10:31 PM   #2596
LC4CARL
Aero challenged
LC4CARL's Avatar
Breathe easy my friend. If I could tell my younger self one thing, it would probably be to try to take a "longer view" on things (which you are obviously already good at doing). In my early days I started and quite countless projects as time and funds did not permit, what I felt to be, reasonable progress. I will say that it is still of value to me to at least "move the ball forward" a little bit each day. Whether in thought, on-line or actually in the garage. It just makes me feel better to think that I did something for myself on a given day.
Which is a large part of the reason why, for most of my life, I have fixed up the sow's ear versus going with the turn-key. We all have our thing. My realtor drives an amazing new Camaro SS with the monstrous Brembo brakes. Yet knows nothing about cars. That's fine. I enjoy tinkering and learning.
Old 06-30-2019, 12:12 AM   #2597
LC4CARL
Aero challenged
LC4CARL's Avatar
Running out of space for Volvo parts. Decided to build a new house.
Old 06-30-2019, 12:34 AM   #2598
LC4CARL
Aero challenged
LC4CARL's Avatar
Looking for a new job too.
Mid-life crises I guess. New house. New job. Empty nest.
Updated my LinkedIn account. Tired of driving 30k miles a year. Need to find a bigger company with a smaller territory. And stuff.
Going to properly lower the DL. Coil-overs, SAI correctors, the whole she-bang.
Other than that, everything is copasetic.
Old 06-30-2019, 08:31 AM   #2599
MrBrown
MrBrown's Avatar
Woah!
GhettoFab build thrizzie
Old 06-30-2019, 11:00 AM   #2600
You gonna out garage Kyle?
