Old 10-24-2020, 08:54 PM   #3026
patrickstar
patrickstar's Avatar
Originally Posted by LC4CARL View Post
PM me your address and I'll send you the bushings.
I'm in no rush, my new shop space is out in Camas so I'll be on your side of town more often
1983 242 - 4.8/AR5
1980 242 - Daily
1980 242 - Shell
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 10-24-2020, 09:51 PM   #3027
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by Wilford Brimley View Post
Not great...hey that's china for ya
By disconnecting the manifold signal from the WG actuator, have I ruled out a misadjusted or weak actuator as the cause of lower than expected peak boost?
+/- 14 psi surge / leveling off at +/- 12 seems go be about it. I tightened the actuator push rod adjuster three, 360* turns, shorter with no change. At some point, adjusting the MBC netted no change.
Maybe this is the peak performance of this set up. If so, I am happy with that. It runs great.
@PDXvolvo on IG
Old 10-30-2020, 10:43 PM   #3028
LC4CARL
Aero challenged
LC4CARL's Avatar
Consensus is that the current WG actuator does not have the spring to hold the flap closed at higher boost levels. Done pouring money into the abyss for a while. Going to dyno at +/- 12 PSI on the 13th. It is what it is.
Spent my recent evenings chasing the oil leak. The under side of the car is coated with oil: trans crossmember, exhaust, axle. Meh. Replaced an O-ring, crush-washers, oil filter, snugged up a few fasteners. Hosed her down with cleaner for the 100th time. Been chasing this bitch for a year now. ****, ****, ****.
Son and I are doing a 1,000 mile road trip to south eastern Oregon next weekend. Should be fun. Despite traveling for work, I've never seen this area.
Bought some eCode stuff. Pretty excited. Well, gotta spend when the deal is hot...
Old 10-30-2020, 10:56 PM   #3029
MrBrown
MrBrown's Avatar
Throw a manual boost controller on there
GhettoFab build thrizzie
Old 10-30-2020, 11:41 PM   #3030
LC4CARL
Aero challenged
LC4CARL's Avatar
Got one. Even disconnected the boost is less than expected.
Probably for the best with an M47.
Old 10-31-2020, 12:29 AM   #3031
Cwazywazy
Single jingle
Cwazywazy's Avatar
Did you try more preload?
I don't know what I have
Old 10-31-2020, 12:52 AM   #3032
LC4CARL
Aero challenged
LC4CARL's Avatar
I added 3 x 360*. Looking at ATP actuators.
Old 10-31-2020, 02:11 AM   #3033
culberro
culberro's Avatar
KINUGAWA actuator Carl, swappable springs.
Old 10-31-2020, 11:09 AM   #3034
LC4CARL
Aero challenged
LC4CARL's Avatar
Oh right...
Old 10-31-2020, 01:17 PM   #3035
MrBrown
MrBrown's Avatar
But even with a 5-7 lb spring the boost controller should allow it to hold off more then snap open quickly. Maybe bad MBC. I went through two before I got one that worked.
Weird...
Old 11-01-2020, 12:18 AM   #3036
LC4CARL
Aero challenged
LC4CARL's Avatar
I need to learn more about the relationship between actuator spring pressure and resulting boost pressure. Not sure what the stock actuator spring was VS my current aftermarket unit. It's a fun conundrum finding the sweet spot for the actuator spring pressure and the MBC adjustment.
Pretty sure my breakerless / 2.2 combo could handle 28 psi...
Old 11-01-2020, 01:21 AM   #3037
Quin
ಠ_ಠ
if you say so.
Old 11-01-2020, 02:53 PM   #3038
LC4CARL
Aero challenged
LC4CARL's Avatar
if you say so.
Right up there with finding oil leaks...
Gotta have the tires balanced before the big road trip next weekend. Got my tool kit laid out. Makes me a little nervous going that far off the grid. Should be fun though. One of the passes is 6,200 feet. Hope I don't regret not bolting on the snow tires.
Beautiful day for IG pix.
Old 11-04-2020, 12:29 AM   #3039
brendon_ak
What's the tool kit look like?
Old 11-04-2020, 01:25 AM   #3040
LC4CARL
Aero challenged
LC4CARL's Avatar
Volvo’s don’t need no stinking tools...
Old 11-04-2020, 02:34 AM   #3041
LC4CARL
Aero challenged
LC4CARL's Avatar
What components trigger the LH2.2 rev limiter (at +/- 6,000)?
007 air flow meter? Other?
Is this all she’s going to do?
Old 11-04-2020, 02:37 AM   #3042
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 11-04-2020, 05:34 PM   #3043
Cwazywazy
Single jingle
Cwazywazy's Avatar
ECU and EZK both have limiters. You can increase the ECU limiter with a chip but I dunno about the EZK.
Old 11-04-2020, 07:09 PM   #3044
Swedbrick
Swedbrick's Avatar
Both can be increased with a chipped ezk, preferably you put the ezk limit a little lower, for a soft ignition cut before the hard fuel cut
Volvo 745 - IPD springs, 25mm front w 19mm rear swaybars, K-cam, LH2.4, M90 swap, 3.54 racingdiff lsd, track/daily
Old 11-04-2020, 08:43 PM   #3045
MrBrown
MrBrown's Avatar
Did it do the limit at the same rpm before?
Old 11-05-2020, 01:09 AM   #3046
LC4CARL
Aero challenged
LC4CARL's Avatar
This rev limit condition is new to the current set up. I had never seen this “Bah!bah!bah!” at 6k before. Part of this may be that it now loves rev.
Old 11-05-2020, 01:14 AM   #3047
LC4CARL
Aero challenged
LC4CARL's Avatar
Engine still leaks oil. I may not be up to this. Think I could get $4k for it?
Old 11-05-2020, 03:17 PM   #3048
MrBrown
MrBrown's Avatar
So you never got on it before the turbo?
The noise sounds like a rev limit and won’t change without tuning the map.
That said, it could be something else and not rev limit but I don’t know since my stock 2.4 limit was also ~6000
I’ll buy it for $500 tho. Let me know.
Old 11-05-2020, 03:18 PM   #3049
MrBrown
MrBrown's Avatar
P.s , I have a chips you can have. If someone has an Ostrich you could borrow we can fix it
Old 11-05-2020, 07:59 PM   #3050
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx boss.
The old turbo was "done" by redline. This one wants to go.
Just need to throw another $3k at her for EFI and transmission upgrades.
Leaving on three-day road trip tomorrow. Chicks dig fast 245's...
