Old 10-01-2018, 09:07 AM   #326
Broke4speed
Broke4speed's Avatar
Here's a terrible video of the first test drive. It starts out vertical and then switches to horizontal, sorry. It's also pretty small, but it shows function well enough.
1984 244/ AQ140A / M46
Old 10-01-2018, 10:06 AM   #327
thessejway
Wannabe TBer
thessejway's Avatar
Been looking to swap from auto to a T5 manual in my 940
But something like this is tempting as a simpler way to get some sort of manual control/feel.
How painful is setting up the POI to work with the AW-7x transmissions? I have zero experience with this
thessejway is offline   Reply With Quote
Old 10-01-2018, 11:09 AM   #328
Broke4speed
Unfortunately, the AW7x boxes are all mech/hydraulic. The Poi box only works with electronic transmissions.
Old 10-01-2018, 11:36 AM   #329
thessejway
Wannabe TBer
thessejway's Avatar
What trans is it that you're using?
Old 10-01-2018, 12:17 PM   #330
Broke4speed
The AW30-40E (or A340e by another name), It comes stock on the B6304 in a 960, and a bunch of other cars (Mk4 Supra, some Lexus', Jeeps up to 2000, etc). I use the stock 240 shifter to actuate Park, Reverse, and Neutral, then when I shift into "D", the joystick shifter takes over.
Old 10-01-2018, 12:35 PM   #331
thessejway
Wannabe TBer
thessejway's Avatar
Welp I guess if I'm going to have to swap the transmission out either way. I may as well just do the T5 swap. I'd much prefer full manual
Thanks for the info
Old 10-01-2018, 01:34 PM   #332
Broke4speed
The AW30-40 bellhousing is different than the AW7x anyway. Full manual is your only other option, unless you go to a GM auto and manualize that.
Old 10-14-2018, 09:31 AM   #333
Broke4speed
Yesterday was a bang-up, f**kin good day. I got my Arduino CAN BUS display working:
Then I went for a long drive with no issues and a huge smile on my face the whole time . I thought the B6 would be too loud through the 3" exhaust...but it's definitely not. The sound is heavenly! My only issue is a VERY hard start when warm, due to the VR sensor. I have to look into changing/adding resistors in the VR wiring.
Old 10-14-2018, 06:54 PM   #334
Broke4speed
A frustrating day, but successful in the end. Swapped out the 4-bar MAPDaddy setup that came with my MS2, and after that...the car wouldn't start. Of course, I didn't notice the no-start until I tried to fire it up after some shunt resistor mods, so I had to work back to figure out what I did. Eventually I discovered a blown fuse (always check the easy stuff first, kids...sigh). The no-start was due to no fuel.
The end result is that I managed to reduce the size of the shunt resistor across the VR leads and still have the full rev range. This might help my hot sync issues...I hope. Either way, the car still fires up right away when it's cold, which is great .
Old 10-15-2018, 08:15 PM   #335
Broke4speed
Got a bit of help from the msextra forums to convert the *F to *C, which was more trouble than expected. Why there isn't an option to output CAN data in either unit is beyond me. Only 10% of the world uses *F anymore. I also added an ethanol percent display, since I have a sensor waiting to go in anyway. We don't have E85% in my area, but it'd be nice to see what the percentage of ethanol is in the local gas.
Old 10-15-2018, 09:21 PM   #336
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Really rad!
Old 10-20-2018, 08:29 PM   #337
Broke4speed
FINALLY! I got the display temporarily mounted and the interior buttoned up (mostly). I figured I'd celebrate by going for a drive to the junkyard (that relocated to 15 min from my house! :D ). I got there 10 minutes before closing, so I decided to take a few pictures and come back tomorrow. I actually ended up talking with the junkyard manager, who chased me down before I left the parking lot. He dug my car, which was a bit of an ego boost, lol.
I've got a tach adapter to wire in tomorrow, so I'll take some pictures of the dash display too.
Old 10-21-2018, 08:42 PM   #338
Broke4speed
No pictures, but the car is finally DONE (for now)...three months later than expected. I'll be driving it for a few more weeks, as long as it's not snowing too hard .
The tach adapter worked perfectly too. If anyone needs one, I recommend this guy: https://www.ebay.ca/sch/gkgoodcheapp...p2047675.l2562
Old 10-26-2018, 06:22 PM   #339
Broke4speed
Big picture, but it's easier to see the final mounting place of the display that way. I found the 'plans' for a small enclosure for the screen and had it 3D printed. It fits nicely on the switch panel in the center console, although I had to leave one plug out so the cable would fit.
(Excuse the box on the passenger floor, it's the shift controller. Haven't really decided where it's going to go yet, since I mounted the 'gear display' LEDs on it. Might have to relocate those.)
Old 10-30-2018, 01:54 PM   #340
240wagonguy
Hows the coolant temp sensor working for the gauge? I was looking for the part number you quoted, but can't seem to find it. Any details, like a part number I could find online?
Old 10-30-2018, 09:20 PM   #341
Broke4speed
It's actually working great! I'll look up a part number and post it up .
[edit]The number I posted has apparently been superseded by 049919501. Same thing, just different number.
The part number shows this:
The stock Volvo spade connector slips right onto the button head connection, but it's likely they've changed all the sensors to a proper male/female connection now.
Old 10-31-2018, 02:04 PM   #342
240wagonguy
Awesome thanks! Just ordered one off Amazon. The 740 and 240 gauge senders interchange, so this should work for my 85 740 as well.
Old 11-02-2018, 09:28 PM   #343
Broke4speed
Cool, glad to help .
Tomorrow is my last drive in the car until spring, so I modified one of the generic Tunerstudio dashboards to use while tuning. The font is Volvo Broad, and it's as close as I could get to the R-sport yellow, without having the proper pantone code. The Volvo logo is the datalogging on/off button, and the center lights up green when operating .
Old 11-04-2018, 12:49 PM   #344
Broke4speed
...and now it's time for storage, sigh :(.
I went on a 5-hour round trip to visit a buddy at his old-school junkyard, and check out a 73 Porsche 911/930 that I'm going to be helping him with next year. I'm super stoked at how trouble-free the drive was, considering I haven't really shaken down the swap yet. I need to swap to a chambered resonator or rear muffler to kill some of the drone during cruise, but I love the sound/feel of the B6304 in a 244. Honestly, all these cars should have come with a 6 of some sort, IMO.
I REALLY love the sound of these engines, btw. I'm very tempted to boost it, but I don't know if I will just yet.
Old 11-05-2018, 11:11 AM   #345
Broke4speed
The big bit of info that surprised me after the long drive is that I think my rear end is a 4.10. I counted teeth and came up with 3.73:1 (IIRC), but my cruising RPMs at 100kph are ~2300 with 205/55-16s. The math says 4.10 at that point. I'm cool with that, because it makes for great acceleration, but I just wonder how I could have been so wrong. I can't remember what car I pulled it from, but I think it was the same non-turbo 940 I got the AW-71L from. If it is from the same car, it's definitely a 4.10.
Old 11-06-2018, 06:45 PM   #346
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Oh how badly I want to do that swap on a 240.
Awesome job. One of my favorite builds on here.
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 11-06-2018, 07:16 PM   #347
Broke4speed
Thanks man .
It's a great engine for these cars, even NA. I really dig it.
Old 11-07-2018, 06:19 PM   #348
vwbusman66
vwbusman66's Avatar
Thanks man .
Will next summer be the year of ITB's?
Old 11-07-2018, 08:04 PM   #349
Broke4speed
I think next summer will be the year of road trips and car shows, since I missed out on all of them this year. I really don't know what direction I'm going to go next. I have been a turbo guy since the mid-90s, but I also love the sound of open ITB/carbs.
Old 11-08-2018, 06:00 PM   #350
DET17
Reformed SAABaholic
Yup, nearly all the North American NA late 9's came with the 4.10 final gearing. Sorry I didn't keep up.... did you throw a complete G80 into your 2 series rearend, including setting up the pinion? I've never heard of anyone modifying a 9 series 1041 rear end to fit a 240!
