Old 01-29-2018, 01:28 PM   #1
Rhys340
Rhys340's Avatar
Default Upgrade my 13c
I have a td04h-13c, I have been told I can upgrade to a 15g
Would a 15g bolt upto my td04h-13c hotside then custom make a bracket for my actuator
Do I need a complete 15g? clock and custom bracket and mod down pipe ?
I dont want to t3/t4 either!
Rhys340 is offline   Reply With Quote
Old 01-29-2018, 01:31 PM   #2
JohnMc
JohnMc's Avatar
Need a complete 15G. The 15G/16T is a TD04HL, the 13C is a TD04H - they're not compatible. The hotside of an HL is larger.
There is a conical flange version of the 15G that wouldn't require a new DP, but that also doesn't improve things quite as much. Clocking is trivially easy. A bracket is fairly easy to create, you'd need that regardless.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-29-2018, 01:47 PM   #3
Rhys340
Rhys340's Avatar
Thanks for the quick response!
Old 01-29-2018, 02:14 PM   #4
woodenpudden
lacks goats
woodenpudden's Avatar
All good info, and worth mentioning in addition that at this point (age, mileage etc.) consider buying professionally rebuilt, or rebuild the turbo yourself if you're into that sort of thing.
Originally Posted by DMFWallace View Post
Flunt delivers!
woodenpudden is offline   Reply With Quote
Old 02-06-2018, 06:44 PM   #5
emem1160
Just to close things out for the future, are there any turbo cartridges that would fit the 13c exhaust housing? (besides the 13c obviously). Makes for an easy turbo change not having to undo the exhaust downpipe and exhaust housing
emem1160 is offline   Reply With Quote
Old 02-06-2018, 08:10 PM   #6
tryingbe
Boosting along.
tryingbe's Avatar
None, zero, nada.
85 GLH 367whp
00 Insight mpg > yours.
Old 02-07-2018, 08:50 PM   #7
throw 13C in garbage... replace with 16T or similar
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is online now   Reply With Quote
Old 02-08-2018, 07:48 AM   #8
DET17
Reformed SAABaholic
I've built a 19t from a 15g core.... details in my build thread on my 9 series. You can see how I fab'd a WG bracket from the one supplied with the KINUGAWA wastegate actuator, and a 90's A/C mount used on the late cylindrical compressors. Right now, the bracket is out for electroless nickel plating...... and I wouldn't call the fabrication "trivial" as JohnMc states. It is doable with hand drill, metabo cutoff wheels and a welder.
Old 02-09-2018, 03:31 PM   #9
BDKR
Section 9
BDKR's Avatar
Here is an easy way to do it. It's going to be considered sacrilege but I'm pretty good at not caring about that.
Anyway, the shaft sizes of those two turbos are the same! That's a key thing!!!! As a result, you can take the entire shaft and 13c turbine impeller and use it in the 15g CHRA.
Now you're not going to make killer top end power, but you're not going to with a TD04HL hot side either!
But what you will gain is amazing bottom end and roll on performance. Set it at 1 bar and be happy. PM me if you have a question.
For all you Dijkstra fanboys:
