Old 10-21-2019, 09:03 PM   #1
Redheaded sailor bum
Redheaded sailor bum's Avatar
Default Best wheel spacers?
I'm looking for new wheel spacers when I bought my 940 it had aftermarket rims on there and I'm currently trying to find wheel spacers to fit my rims I want to get some 850 r wheels later on down the road but for now I'm focusing on just spacers the ones on there now are 1.5 inch and are just obnoxiously too long and cause really bad tire rubbing (sometimes even smoking when in on track days) and figured downsizing to a IPD 25mm would be a good fit but wasn't sure what the difference in the 2 types they had one seems to be something called a trax+ and then the other seems to be a regular so I was a little confused
If I recall I have some rear boxes on the struts to convert the nivomat to a normal kyb with 325 pound springs so the rear sits a little lower and has somewhat a little camber from the tophats being pivoted in if any of this makes a difference as far as spacers just want sure if there was another brand out there besides ipd and was unsure on the 2 diffrent variants they offer
Redheaded sailor bum is offline   Reply With Quote
Old 10-21-2019, 09:06 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
Trax+ are H&R parts and some of the best quality.
Otherwise i have heard good stuff about https://www.motorsport-tech.com/
Link to what you are looking to use?
On a 7/9 I like the look of 25/32 spacers with fwd wheels.
Old 10-21-2019, 09:12 PM   #3
All I've seen is ipd and cheap amazon chinese crap for the most part I think if I keep it at 25mm I'll be fine it's just the 1.5 inch is overkill and the tire run is obnoxious
Old 10-21-2019, 09:14 PM   #4
What's the real difference in the trax+ and the other that ipd sells
Old 10-21-2019, 09:32 PM   #5
https://www.whistlerwheels.com/colle.../17-kr1-chrome
These are what I'm currently running aswell
Old 10-21-2019, 10:14 PM   #6
lummert
lummert's Avatar
Maybe it would help to put 1991 Volvo 940 SE (944 SE for sedan, 945 SE for wagon) in you signature. A 940 SE is a different creature from a regular 940. Can't tell from your picture if it is a sedan, or a wagon. If it's a wagon the rear springs and shocks for 740 wagon/760 wagon/940 wagon/92-94 960 wagon fits. If it's a sedan it has rear multi-link suspension.
Old 10-21-2019, 10:27 PM   #7
It's the multilink se rear I'm sorry I should have specified
Old 10-21-2019, 10:30 PM   #8
My hub bore is also 7.31
Old 10-22-2019, 08:17 AM   #9
Fa182
Stage 1
Fa182's Avatar
Sorry to be an ass, but please try to use some punctuation. Your posts are extremely hard to read.
And yes, +1 to lummert to put your car in your signature. A 940 SE can be very different in a lot of areas compared to a standard 940.
Difference is most likely a combination of different material (aluminum / magnesium alloy), brand name + made in Germany.
Old 10-22-2019, 11:12 AM   #10
AndrewNance
Amateur hour!
AndrewNance's Avatar
Motorsport Tech will make whatever you want and is top quality. A set of hubcentric/wheelcentric will run $240.
Old 10-22-2019, 02:50 PM   #11
I just decided on the IPD spacers, I already bought the hub bore rings. If I end up needing spacers/adapter for another project I'm gonna have to check out motorsport tech they have a really nice and easy to use website
Old 10-25-2019, 12:24 PM   #12
DrZiplok
DrZiplok's Avatar
Their customer support's good, and the product is top-notch as well. Money well spent.
DrZiplok is offline   Reply With Quote
Old 10-27-2019, 07:15 PM   #13
mooseturb
+1 for Motorsport Tech. Quality products and easy to deal with. Have used them for spacers and hub rings for non Volvo vehicles.
mooseturb is offline   Reply With Quote
