Old 07-10-2020, 11:00 AM   #1
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
Default Oil Starvation road race b230
Hey guys has anyone experienced any oil starvation issues after making hard left hand turns while accelerating.. Working on getting our chump/champ car back into racing action and took it to a track day at Barber's. When coming out of turn 5 and down shifting down to 2nd gear I would notice the oil pressure light blink and the oil pressure gauge drop. Has anyone baffled a b230 oil pan?
https://www.youtube.com/watch?v=dmKm...ature=youtu.be
Keep your eye on the dash at the 13:08 mark
Thanks guys..
-Sam
90 245GL 2JSWEDE 2JZ 245...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 07-10-2020, 11:08 AM   #2
poulrais
poulrais's Avatar
Maybe you need one of these?
http://www.crank-scrapers.com/Volvo.html
1990, Volvo 740 16v +T
Old 07-10-2020, 11:52 AM   #3
shoestring
shoestring's Avatar
That's weird. I will say we had this happen once, but it was due to a rolled oil pump transfer tube seal.
On a side note your skill level is beyond mine. I most certainly would have brought out the yellow at some point...
Old 07-10-2020, 12:16 PM   #4
rb92673
I add an extra quart.
Old 07-10-2020, 12:18 PM   #5
culberro
culberro's Avatar
^I also do this if I’m going to a track day.
You can also wide sump the pan and/or add a sump with trap doors. Hiperfauto sells a b20 trap door kit that wouldn’t be too hard to make work on a slanted engine.
Pretty common problem with red blocks when you drive them hard. They’ll also starve for oil under very hard braking as well.
Old 07-10-2020, 12:27 PM   #6
rb92673
I noticed it more after I installed a remote oil filter kit. My seals have all gone bad due to the massive blowby and my current engine loses about a quart ever couple of hours. Fill it too the line then add a quart.
You could also do an accumulator.
Old 07-10-2020, 12:53 PM   #7
redblockpowered
redblockpowered's Avatar
I pretty distinctly remember overfilling a little as well. Not a quart, but maybe half that?
I sell chips for LH 2.4!
Old 07-10-2020, 01:41 PM   #8
122power
dude
122power's Avatar
Hmmm never had an issue at sonoma in a b230 in an amazon on a team i filled in for. They havant had issues either. I have a 245 and didnt have issues either. Ran jgr oil 10w40 though. Amazon team ran cheap stuff. Coming thru the carousel there is a pretty good left downhill turn. These were both NA cars.
Agree with above add 1 qt. Our engine teacher ssid put and oil pan in the passenger seat and fill it with oil and drive around. Youll see how much it moves around especially under braking, corners acceleration etc.
You could ask pat244ti his car is faster and turbo. Other fast volvo guys are two stupid to know any better. Turbo 745 thats pretty stout.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 07-10-2020, 05:37 PM   #9
sbabbs
sbabbs's Avatar
RSI Da Bomb mod! 3 inch exhaust pipe.
Old 07-10-2020, 05:45 PM   #10
GTJordan
Been here for too long
GTJordan's Avatar
The SloVo team based here runs an accusump due to this issue.
Jordan
Old 07-10-2020, 07:42 PM   #11
rb92673
"It's not a tumor"
Old 07-11-2020, 02:12 PM   #12
shoestring
shoestring's Avatar
Yes we did. 1 quart. It would lose about half that during the course of the day.
Old 07-11-2020, 03:28 PM   #13
F*ck 12
Jordan
This seems like the best solution to me. Added benefit of pre-oiling the engine before startup.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 07-11-2020, 11:41 PM   #14
Harry Tuttle
Same thing from tuff240:
http://forums.turbobricks.com/showth...=330429&page=3
just gutless low compression k-junk
Old 07-12-2020, 01:22 PM   #15
pat244ti
pat244ti's Avatar
I noticed it on my 244 at Sonoma coming through the carousel. As others have mentioned, I've only noticed it when the oil is in the crosshatch range on the dipstick. Keeping it overfilled about a quart keeps it away.
I've got an Accusump if you want it though Sam.
- Patrick
83 244ti - rally
73 1800es - resto mod cruiser
83 244ti - road race
79 262c - road race in the works
08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate
97 Dodge Dakota 5.2 4x4
70 Ford F100 2WD 351M/C6
Old 07-12-2020, 06:15 PM   #16
mikep
The MP
mikep's Avatar
I don’t see the inside pics, but the top and front of that cheek extend 2” into the pan. The baffles around the pickup are also about 2” tall and angled in.
It’s torch welded with the wrong tip. Sorry.
Originally Posted by leecatd8209 View Post
Being dead has a funny way of messing up your small business, too.
Old 07-18-2020, 10:07 PM   #17
DrZiplok
DrZiplok's Avatar
Same issue with the M52; nobody on the team was willing to try their hands welding the aluminium oil pan, so we went Accusump as well. Packaging is a bit tight, but it seems to do the trick.
DrZiplok is offline   Reply With Quote
Old 07-20-2020, 06:55 PM   #18
towerymt
the real Towery
towerymt's Avatar
Yup, sounds familiar. The DD would occasionally light the light under heavy braking when down about a quart and a half due to the cracked oil drain line.
Old 07-20-2020, 07:16 PM   #19
mikep
The MP
mikep's Avatar
Got any inside pics of a pan i welded baffles in?
I like to put perimeter shelves in at dipstick-full height, but who knows where all my corolla, datsun, b23 etc pics are at the moment. No time to search.
Old 07-22-2020, 01:17 AM   #20
dkrause
Team Slovo races a 240T in Lucky Dog and WCMA endurance racing and we use a 3 quart Accusump which totally solves the low oil pressure we encountered in Turns and under hard braking when running stock, in longer races it also makes up for lost oil as GTJordan says.
dkrause is offline   Reply With Quote
Old 07-22-2020, 04:22 AM   #21
F*ck 12
Where did you tie it in to the engine? I was thinking the 1/4" NPT hole tapped on the front of the engine at the end of the oil gallery, but not sure if that's big enough.
Old 07-22-2020, 09:23 AM   #22
Stiggy Pop
Stiggy Pop's Avatar
lifted the pictures from Dr. Fanning's thread:
'79 242
943 pickup
Old 07-24-2020, 12:47 PM   #23
dkrause
Default Accusump
We Tee'd off of the line (AN 10) to the oil cooler right at the sandwich plate. We also log oil pressure in our AIM data logger so we know how bad it was and how well the Accusump works, if you race hard it will keep your pressure up. When looking at data it was clear the major drop in oil pressure is not in long corners but when you have a hard brake zone and then turn into the corner, the oil is at the front of the head and pan leaving little at the pickup.
Old 07-24-2020, 01:38 PM   #24
DrZiplok
DrZiplok's Avatar
If you have to ask, it means you aren't running an oil cooler. You should run an oil cooler. 8)
Old 07-24-2020, 01:40 PM   #25
F*ck 12
I'm using the water/oil cooler off a 940T, thank you very much. I also have a crank scraper, just FYI.
