Old 10-02-2020, 12:04 PM   #1
90volvo
Default header options
I know in the past the ebay OBX headers had to be flipped. Does anybody know if they got that fixed? Also what do you recommend for 240 with Turbo. I want to upgrade to a header. Thanks
90 Volvo 240 19T-3 inch ex-Aw71-Npr-V cam-E85-Megasquirt-650cc inj.-280000 miles.
Old 10-02-2020, 12:30 PM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
AFAIK all the 8v tubular manifolds on ebay have the flange backwards.
I'd look at Sweden Exhaust or KL Racing
http://swedenexhaust.se/en/volvo/366...vo-240-8v.html
https://shop.klracing.se/sv/artiklar...bogrenror.html
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 10-02-2020, 12:49 PM   #3
90volvo
Thanks for the info. Diffently dont want an ebay header. The once from s.e. looks sweet. Its higher but I can run a twin scroll turbo.
Old 10-02-2020, 01:25 PM   #4
culberro
culberro's Avatar
The Sweden Exhaust one would be nice. Especially with a v-band turbine entry and an external wastegate. Not a bad way to spend ~$650 USD.
Old 10-02-2020, 01:45 PM   #5
90volvo
Yelp sure is pretty. I think I can adapt a evo turbo to it. But man, to
Play you gotta pay. Sold quite often few parts.
Old 10-16-2020, 07:35 PM   #6
someoldbrick
First time writing on this site. Got a 740 looking to +T soon. i have leads on cheap 90+ manifolds but they're cracked. I'd rather not mess with welding and get something new and solid. suggestions? any differences between 2 and 7 series manifolds fitment? thanks
someoldbrick is offline   Reply With Quote
Old 10-16-2020, 09:57 PM   #7
2turbotoys
Astro Zombie
2turbotoys's Avatar
Welcome! There is no difference between any B230 manifolds as far as fitment. I made my own since I didn't like any of the options available at the time I did it, but look at the above suggestions. There is no real problem with eBay manifolds if you are willing to cut the flange off and flip it. Some gussets/reinforcements wouldn't hurt either. If you aren't willing to do that you need to pay for the more expensive stuff.
If you can find a person who can properly repair cast materials, a 90+ manifold is a great budget option. The last repair I had done on one cost about $10 because Amish people repair cast stuff all the time.
You will get better responses starting your own thread instead of posting questions on an existing thread.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 10-17-2020, 12:49 AM   #8
90volvo
There is a top mount header on eBay but it’s for 16v. For quality manifold/header klracing and Sweden exhaust. But they are beyond casting distance. Takes a couple weeks to get klracing stuff. I contacted Sweden exhaust and they claim a week to 10 days.
Old 10-17-2020, 04:11 AM   #9
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
I had an ebay one...they're a bitch to weld...just ****ty metal...I'm thinking I'll skip that headache and go kl this time around
Old 10-17-2020, 08:50 AM   #10
F*ck 12
I had an Ebay one, just sold it, when I did the finger test the pipes didn't seem any bigger than the 90+ runners.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 10-22-2020, 09:10 PM   #11
90volvo
So I picked up an ebay header and as usual the flange is wrong. Ive checked around locally for a stainless steel welder with no luck. So tonight I was scoping it out and thought I could flip the header which makes the ports wrong. But I thought a guy could drill new holes to get it to line up with the head. Then grind the bracing down so you can get to spark plugs. Like to hear if anybody thought of that or has tried it. Thanks
Old 10-22-2020, 09:19 PM   #12
F*ck 12
Which car? I don't think there's room by the strut tower on a 240 to run it as is.
Old 10-22-2020, 10:17 PM   #13
90volvo
scoped it out. Its diffently tight but think it can work.
