Old 10-11-2020, 06:18 AM   #1
K9 240
K9 240's Avatar
Default New problem with larger wheel fitment
Finally got some 215/60/15 tyres on my 7x15x20 multi X wheels.
The wheels fit under my 240 without a problem even though it's lowered a bit.
Problem came when trying to fit the spare tyre in the space provided (left rear butt cheek).
Basically it does not fit even after trimming the side panel & letting all the air out of the tyre.
This is not a large tyre/wheel combo by any means, so what are people on here doing?
Is there a space saver spare that would fit in the space under the floor?
That empty butt cheek is just the right size for a bottle of nitrous!
Tim
K9 240 is offline   Reply With Quote
Old 10-11-2020, 11:17 AM   #2
F*ck 12
I just lay my 275/40/17 flat on the floor, but I don't go to Costco with this car either.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 10-11-2020, 02:45 PM   #3
carver
Redblock for life.
carver's Avatar
195/65/R15's will fit but even then you have to let out a fair amount of air. Caught me by surprise too.
carver is offline   Reply With Quote
Old 10-12-2020, 02:28 AM   #4
hessam69
Do you have any more multi x wheels for sale?
Old 10-13-2020, 03:15 AM   #5
K9 240
K9 240's Avatar
Unfortunately my wagon is regularly loaded up which makes having a spare wheel in the cargo area a problem. Looks a bit odd to carry the spare on the back seat (when it is a seat).
Sorry hessam69 - no extra wheels to sell.
Old 10-13-2020, 11:10 PM   #6
Harry Tuttle
I was aggravated to find this too. Who wants to carry a deflated spare? Currently working on modifying the cover. The tight area is only 2"X4".
The joke is that I was previously using a pretty narrow spare and a 140 cover. Didn't realize until lately that the 140 cover is much flatter. It didn't even come close to closing with a normal tire.
Originally Posted by sbabbs
just gutless low compression k-junk
Old 10-14-2020, 04:47 PM   #7
klr142
Turbo, what?
klr142's Avatar
Your spare tire/wheel do not need to match the rest of your tires. Having a close diameter is all you need. 185/65-15(slightly shorter than your new tires) or 195/65-15(basically the same diameter as your new tires) will fit better and be just fine for use in emergency situations only.
Old 10-14-2020, 05:16 PM   #8
205-60-15 on a 6" wheel barely shoehorns in there, on a 7" wheel it doesn't quite go in.
Old 10-19-2020, 06:53 PM   #9
I too use a 205-60-15 for my spare. It's on a 740 steelie and just fits in the area. If I set up another spare I will probably use something like Kyle suggests. That size is also a lighter tire. The 205-60-15 on a steelie is quite heavy.
Old 10-19-2020, 06:59 PM   #10
F*ck 12
Heavy,schmeavy just turn up the boost
Old 10-20-2020, 10:46 PM   #11
klr142
Turbo, what?
klr142's Avatar
The wheels he's using are 7" wide and yours are 6", so if he puts the 205/60-15 on a 7", it might still not fit.
Old 10-20-2020, 10:52 PM   #12
JohnMc
JohnMc's Avatar
I got a space saver spare tire out of a newer Volvo in the junkyard. Easily fits under the cover in the back of the wagon, fits over the large brakes (RX7( in front, fits properly on the adapters (I'm running FWD offset 17X7 wheels).
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-21-2020, 01:30 AM   #13
BeaverMeat
Put it on the roof. Off-road style.
