Old 05-25-2016, 12:15 AM   #251
Joe_Diesel
Joe_Diesel's Avatar
how much power do they make after you convert them? Is it worth all the trouble to turbo the stock motor for the power levels?
Joe_Diesel is offline   Reply With Quote
Old 05-25-2016, 11:34 AM   #252
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
they'll make more power than the stock rods normally like.
Megasquirt Tuning!
Old 05-25-2016, 01:09 PM   #253
Mueller
Mueller's Avatar
Figure 7 to 10 hp per positive PSI boost. (stock is 7ish, easy to go to 10ish)
Go find a stock 740 or 940 turbo. A conversion will be very similar with the +T being possibly a little more responsive off the line due to the slightly higher compression.
If you spend 20 minutes going thru the builds you'll find that there are a lot of conversions from n/a to turbo, so I'd say yes it is worth it. Some people keep them at stock levels, others go for bigger boost numbers and others just toss it all and go the V8 route.
Define worth? People spend hundreds of dollars and time on upgrades that might only net 10hp. Each person is different on how they value their time and money.
Old 07-29-2016, 04:27 PM   #254
Toine van der Laan
Toine van der Laan's Avatar
Hi Guys
I have seen a lot of posts on this message , I am looking to do the somewhat the same thing , just build a B230F with a B234F head and Pistons @10/1.
All stock ! ,
Now I want to turbo it at max 10Psi and have bought the Chinese front mount turbo exhaust manifold, my question is what kind off turbo or which turbo should I use to get a powerband from 2000 rpm and on
I am not looking for max power , 200-250 bhp is just fine for me .
I am using stock LH2,4 and EZK with bushka WS bord , all other parts are stock !!
Anyone up for the challenge , I cannot images someone hasn't tried this before
Toine van der Laan is offline   Reply With Quote
Old 07-29-2016, 04:42 PM   #255
cwdodson88
Originally Posted by Toine van der Laan View Post
Hi Guys
All stock ! ,
A volvo/mitsu 15g or 16t should be sufficient. Since you have (i'm guessing) a t3 flanged manifold, a small Garrett t3 would do also, your spool may not be that low, but it should be pretty close
The Build Thread
SVEA - PUSHROD TURBO!
cwdodson88 is online now   Reply With Quote
Old 07-30-2016, 11:19 AM   #256
Toine van der Laan
What kind of T3 would be usable , could you give me a ballpark figure on size turbine and Ar ?
Your help would be highly appreciated
Old 09-21-2016, 11:08 AM   #257
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Nm
'91 744t...it's fast as phuck
Old 02-06-2017, 07:33 PM   #258
Sam b
It's it possible to get a turbo to run at like 6 or 7 psi with no computer work? It'd be on a b230f from a 1991 740 wagon
Sam b is offline   Reply With Quote
Old 02-06-2017, 07:40 PM   #259
740atl
educator monkey
740atl's Avatar
Gonna say no. Just swap the ecu's.
Old 02-07-2017, 07:00 PM   #260
Sam b
Is swapping the ECU just a matter of unplugging the old one and plugging in the new one? Or is there more to it then that?
Old 07-18-2017, 04:22 PM   #261
Quinnn
Quinnn's Avatar
Alright, I have a 1992 Volvo 740 that I'm looking to +T here in a few weeks.
Just to hammer it in, these are the parts that I need to get the car running, correct?
  • Turbo (duh)
  • Intercooler
  • Exhaust Manifold
  • Downpipe
  • high impedance injectors or greentops + ballast resistor pack
  • Intercooler piping
  • Downpipe
  • ignition/fuel ecu
  • oil lines
Does that seem right? that's my "junk yard shopping list"
Thanks!
Quinnn is offline   Reply With Quote
Old 02-22-2018, 12:50 PM   #262
emem1160
  • Turbo (duh)
  • Intercooler
  • Exhaust Manifold
  • Downpipe
  • Downpipe
  • ignition/fuel ecu
  • oil lines
Thanks!
How is the conversion going?
emem1160 is offline   Reply With Quote
