Old 04-15-2017, 12:28 AM   #1
Wilford Brimley
enjoys the beetus
Wilford Brimley's Avatar
Default Excessive crank case pressure
Ok so I need to drive this car and it keeps blowing oil of of the cap and leaking onto the header and smoking like crazy and I think it's crank case pressure. How can I relieve this....this is kinda critical
'91 744t...it's fast as phuck
Old 04-15-2017, 12:40 AM   #2
centason
Wine enemas for all
centason's Avatar
You might have to pull the breather box and soak it. If you need the car yesterday, pull the box and shove a hose in there until you can get time. Sucks I know.
Member: TBCCS
"Let's not burn the universities yet. After all, the damage they do might be worse." -H. L. Mencken
Just remember this guys. Im related to cocaine.
they were pushing sloppy poo up a steep hill with a pointy stick.
You sons of bitches are the biggest thread de-railers in forum history.
Any forums history.
centason is online now   Reply With Quote
Old 04-15-2017, 12:46 AM   #3
Wilford Brimley
enjoys the beetus
Breather box soaked in gas and rinced
Old 04-15-2017, 12:52 AM   #4
One hundred gift baskets
Compression test for broken engine parts?
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 04-15-2017, 01:02 AM   #5
Wilford Brimley
enjoys the beetus
Like? It runs great and its crazy fast. Its just seems to smoke like crazy on the exhaust side
Old 04-15-2017, 04:47 AM   #6
sbabbs
sbabbs's Avatar
I fixed it with my car getting that Yoshifab catch can setup. I got the whole kit with the extra breather at the oil fill cap. Before that I was blowing oil out everywhere also. Now just my rear main leaks a bit. Gonna fix that when I put in the M90, soon hopefully.
If you got your stock breather box out take a welding rod and jam it down that drain back tube the front hole of the two and make sure it's clean of gunk. That should be a rubber tube that goes all the way down to the bottom of the oil pan. Best to make sure it's clear. If it's clogged that can cause excessive oil blow outs.
Also make sure your oil cap gasket is good.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 542K MILES
Old 04-15-2017, 12:20 PM   #7
Wilford Brimley
enjoys the beetus
I acutally put new tube in it when I had the motor out
Old 04-15-2017, 09:46 PM   #8
lummert
lummert's Avatar
Have you tried replacing the gasket on the oil cap?
Old 04-16-2017, 06:21 PM   #9
quillc
yv1a.com
quillc's Avatar
Vented cap is really your only option (or fix the blowby that is the root cause of your crankcase pressure). I did a vented cap on my wife's DD and then spliced the line into the flametrap line with a T.
Chris
www.yv1a.com
Old 04-16-2017, 06:30 PM   #10
Send me $20 shipped for a B20 vented oil cap and hook it up.
how psi stock can support?
Old 04-17-2017, 11:32 AM   #11
lookforjoe
lookforjoe's Avatar
Assuming this is the car in your sig, running a larger turbo & much higher than stock boost will generate CC pressure if you don't have sufficient oil vapor passage volume - could be breather box, could the vent tubing. The problem will be worse the higher you rev the engine.
Volvo sells the proper 14mm ID vent hose by the meter - 949701 - you need to be sure you don't have any restrictions in your system as any fitting below that size will be the bottle neck. If you don't have it hooked up like factory where there is constant draw on the CC at all times, you are more likely to have pressure issues.
Also doing a leak down test would be a solid way to check that your motor is sound.
If you decide to VTA - make sure all the lines and fittings are oversize to prevent possible restriction.
My XR July2013 - 446AWHP @ 8K rpm
Old 04-17-2017, 12:16 PM   #12
KeizerBrickGuy
KeizerBrickGuy's Avatar
That would be a perfect band aide for now. And get a new Viton oil cap seal for it. ipd sells it and it works really well.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 04-17-2017, 09:06 PM   #13
Wilford Brimley
enjoys the beetus
Thanks guys. Ken Ill take you up on that
