Old 04-15-2017, 05:30 PM   #1
AlexStromberg
Default "ARP" style bolts and such for b230?
I've tried looking on ARP's website but no luck there, only for the 5-cyl. So is there any other manufacture who makes strong bolts and such for the redblocks?
AlexStromberg is offline   Reply With Quote
Old 04-15-2017, 05:31 PM   #2
soclosenotnear
I think yoshifab.com had them last I looked..
Old 04-15-2017, 05:35 PM   #3
AlexStromberg
There is some, thanks!
Old 04-15-2017, 06:02 PM   #4
cwdodson88
You can always call the supplier or arp with the thread and bolt dimensions and they will say yes or no.
The Build Thread
SVEA - PUSHROD TURBO!
Old 04-15-2017, 06:11 PM   #5
AlexStromberg
That is also an option.
Old 04-15-2017, 08:41 PM   #6
classicswede
Volvo upgrades
I stock the ARP stud kits for 8v engines
Old 04-15-2017, 11:43 PM   #7
gsellstr
Vintage anti-ricer
gsellstr's Avatar
So nice to use...just swapped heads on mine today, so much nicer than bolts.
RIP
74 144 B20
90 745Ti
Old 04-16-2017, 01:43 AM   #8
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
I'm not hating on the ARP secret sauce but would Grade 12.9 studs(or bolts) with the right pitch work just as well(for these engines)? A few discussions in the past had suggested they would, others say they wouldn't; Arguments go back 14 years with no clear answers...
FWIW The head bolts that I pulled today were grade 10.9...
Old 04-16-2017, 08:12 AM   #9
Addi_Sig
I put the 12.9 grade in my engine, according to the given tensile strength and shear force, the 12.9 grade bolts are very close to the ARP studs in strength.
I bought the 12.9 grade allen bolts and 10.9 grade shims, for around 1/10 of the price of ARP studs in the States, and that's without shipping and customs clearance on the studs
Addi_Sig is offline   Reply With Quote
Old 04-16-2017, 08:53 AM   #10
One hundred gift baskets
Did you use the old school torque procedure that requires re torquing them after you run it?
1980 primer JDM flares franken-242DL, 1989 silver 780 bone stock.
Old 04-16-2017, 09:19 AM   #11
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Something to keep in mind as well. The ARP stuff is fine thread at the top, a touch better for more even clamping force. That's from a couple different sources.
Old 04-16-2017, 11:31 PM   #12
bearman683
does the B234F engine use the same studs?
bearman683 is offline   Reply With Quote
Old 04-17-2017, 08:42 AM   #13
Surfingbird
threads are the same, but the studs are of different lengths.
Surfingbird is offline   Reply With Quote
Old 04-17-2017, 09:00 AM   #14
Dan Stokes
ARP has almost ANYTHING in nuts, bolts, and studs. Just because you don't see a listing for whatever engine doesn't mean that they can't take care of you, just that they don't have a pre-made kit for that application. Contact them with sizes and lengths and they can take care of you. I used to get dyno driveshaft nuts, bolts, and washers from them and there for sure was not a catalog listing for that hardware.
Dan
Dan Stokes is offline   Reply With Quote
Old 04-17-2017, 10:05 AM   #15
Powder>Paint
this plus 1
Powder>Paint is offline   Reply With Quote
Old 04-17-2017, 10:10 AM   #16
GMS
GMS's Avatar
Vad är det du ska ha det till då? Acm har arp,till 230 motorerna och kl har nog lite också!
-Volvo V70 D3 Auto -13
-Volvo 242 B230FK -75
GMS is offline   Reply With Quote
Old 04-17-2017, 10:44 AM   #17
John V, outside agitator
No, but it's super easy. From the right supplier.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 04-17-2017, 08:47 PM   #18
dieselboy
Whooty patrol
dieselboy's Avatar
I got mine from yoshifab. I should get a set for my 940 too as it's a little bit of extra insurance
'82 242t hy35 @28psi, ebay header, big intercooler, microsquirt ecm, rsi stg2 cam, arp headstuds, tremec tko600, 3" exhaust, 13" brembos, coilovers, saabspoiler, 245/40r17s, lots of yoshifab stuff.
'07 v50t5 "kats" car
'93 940 turbo lifted #trophyvo
'08 f350 4x4 v10 cclb
'97 f-350 4x4 offroad toy
'94 4700 dt466 International toterhome build
dieselboy is offline   Reply With Quote
Old 04-18-2017, 03:06 PM   #19
Addi_Sig
No, as the head was already on with the 10.9 grade bolts I just changed the bolts one by one, in the same order as when replacing a gasket, and over torqued them compared to the manual.
I have an industrial manual indicating the maximum torque for a 12.9 grade bolt, I picked a number half way between the two manuals
