Old 04-06-2017, 12:39 PM   #26
Surfingbird
Originally Posted by snailpoweredbrick View Post
Assuming a performance cam is installed, doesn't the RPM's diving at higher rpm have a lot to do with the Intake manifold, throttle body size, exhaust manifold, turbo and head work? If you don't have the pervious parts I mentioned upgraded, I don't think it will matter that much how big of a cam you put in, the engine acts as a restriction.
This is a question, I'm just curious.
My intake manifold is stock, but exhaust manifold and so on are not. I run big manifold pipes for topend, and 4" exhaust all the way back, paired on a 76mm turbo. I find that the plenum intakes look to race to use in a daily car.
Surfingbird is offline   Reply With Quote
Old 04-08-2017, 11:19 AM   #27
Can play the blues
I would suggest an enem V16 turbo cam. The power band is 2500-6500 rpm. Or the nastiest cam without changing cam followers from enem is the K15 which would support that power quite well. A few years ago when I got one for Hank Scorpio enem made a turbo version of the K15 for him. That is what is in his old 242 with the Holset on it.
1982 242 turbo. 339k miles. Lots of good changes.
1993 245 Classic, 415k miles, enem V15. 5spd. IPD bars and chassis braces. Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
Old 04-10-2017, 04:53 PM   #28
Surfingbird
Interesting! did not know they do custom work.
I wonder why all the turbo cams do not really support a lot of revs.. I bought 56kg springs, which should get me up there, if i get a good cam to pair them with.
Might just be the fact that the redblock does not breath too well over 6k rpm
Old 04-11-2017, 07:26 PM   #29
Can play the blues
I have a V15 version in both of my sig cars. Their cams have served me well for many years.
Old 04-12-2017, 05:20 PM   #30
mark244turbo
mark244turbo's Avatar
Agap, enem, kl-racing, sts, sten parner, catcams, kg-trimning, sam steffanson, folkraceshop, etc all sell performance cams.
1994 960 B204FT, full options, leather interior (soon to be B234FT)
1991 745 B204GT (Swede Sixteen VT), M46 flywheel/ Diesel-clutch/M90L gearbox, poly bushing, polaris rimms, 23/19 sways.
1986 745 B230FT, MBC@13psi, 302mm V70 brakes, camber mod, poly bushing, 960 braces, 23 mm front sway, MBC@13psi (sold)
1983 244 turbo B21FT/AW71, full RUSToration/new rear (USA-import)
mark244turbo is offline   Reply With Quote
Old 04-13-2017, 01:11 PM   #31
Surfingbird
Yeah i know of a lot of makes, just wondered if anybody had some dyno results with different cams, as the car is not exactly stock no more. Not that it is a race car, but i do not care a second if it pulls in the low end, i just want power when i get boost
Old 04-21-2017, 05:17 AM   #32
Surfingbird
I have one last question, where can i find a cam with asymmetrical grind? I figured some more duration and lift on exhaust will be the way to go.
Old 04-21-2017, 07:58 AM   #33
VolvoGuy123
VolvoGuy123's Avatar
With an IPD T cam or equivalent you should be able to pull some extra top end with some cam gear tuning. I am about to try one, anyone have any good results retarding the cam a few degrees?
VolvoGuy123 is offline   Reply With Quote
Old 04-21-2017, 10:01 PM   #34
snailpoweredbrick
snailpoweredbrick's Avatar
RSI stage 2 turbo cam or KG2T have more lift and duration on the exhaust side.
RWD Parts for Sale (240,740,940)
http://forums.turbobricks.com/showthread.php?t=243774
snailpoweredbrick is offline   Reply With Quote
Old 04-23-2017, 08:22 AM   #35
Surfingbird
I do not believe the ipd turbo cam aggressive enough. Aiming for 450 whp capable cam, so i think i need a more race ish one.
Old 04-29-2017, 03:35 AM   #36
Raimis760t
B230ft K block, 16t, freflow 3",stock 530, KL-Racing t2 cam,big ic, 044, fpr, stock lh2.2
1.2-1.3bar turbo pressure.
dyno runs with cam adjusting,very nice gains after adjusting cam
v2 run +2 degrees advance
v3 run +4 degrees advance
v4 run +6 degrees advance
89" VOLVO 760, B230FT, 16T, big IC, 3" dp and exhaust, 044 fuel pump, custom manifold Up pipe, KL-Racing T2 Cam and Cam gear, DET3 piggy, FPR, Bov, custom intake from turbo to manifold, hidraulic hand brake, welded diff, stripped interior, and.... 268HP 382NM
Raimis760t is offline   Reply With Quote
Old 04-30-2017, 07:40 PM   #37
Boris740
Broad Member
Boris740's Avatar
I went from VX to V15 and than V16. Much happiness with V16.
Got knock? Got Megasquirt? Check out Knocksense knock indicator and KnocksenseMS indicating Megasquirt interface.http://www.viatrack.ca/
Boris740 is offline   Reply With Quote
Old 05-02-2017, 02:36 AM   #38
Surfingbird
Cool, i did look into the V16. Seems to be nice! Does it work on OEM buckets? I intend to only upgrade springs, and maybe exhaust valves. Best regards.
Old 05-07-2017, 08:56 PM   #39
Stereophile33
Stereophile33's Avatar
The C2 will eat the factory springs ;). But it will be a lot of fun for all out top end. What compression, headwork, turbo and intake?
in quasi-retirement...
Stereophile33 is offline   Reply With Quote
Old 05-08-2017, 12:44 PM   #40
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
what springs would you recommend for the C2 (or the rsi stage3)?
Megasquirt Tuning!
Old 05-09-2017, 02:32 AM   #41
Stereophile33
ideal rev range? what size valves?
Old 05-09-2017, 05:20 AM   #42
Surfingbird
I contacted Enem, and they recommended either the K13 or K15 for my ideas. They seem to be some aggressive cams, so i think i will have a go at the K15 turbo. 292/292/111/115/12.5/12.5/2.6/2.0/ 0.40
Old 05-09-2017, 01:04 PM   #43
linuxman51
linuxman51's Avatar
all the RPMS. stock sized valves I think. realistically, no higher than 7500 unless the need is there (And the power is there)
Old 05-09-2017, 07:37 PM   #44
aristg
aristg's Avatar
@Surfingbird Told you so @post 13 !! However if you are targeting 350 whp, don't go for K15, try K13 ... Tested in my build thread ...
aristg is offline   Reply With Quote
Old 05-10-2017, 03:22 AM   #45
Surfingbird
You got the win haha!
Though i know of a swede running 498 whp on a 531 head at 2,3 bar (33 psi), why shouldn't i be able to run at around 400whp. I have around 270-300 whp right now i think (not measured, but calculated 340 crank horses or so)
I am really considering the K15, could always advance it a bit, if it is too high revving for me. I read something about the stock cast crank having some frequency issues at around 7500. So i'll keep it under that.
Old 05-16-2017, 01:07 PM   #46
aristg
aristg's Avatar
BTW, this friend of yours, what is his displacement and what fuel does he run on ? And does he have bigger valves than stock ?
Only thing i have to notice, with 100 RON, or 100+88 = 94 (AKI), and K13 the result is a flat dyno chart, before knocking, but clocking the cam gear does not much, almost nothing. Advanced or Retarded. Of coure this result is perfect for me, but the question still remains !
Maybe running some serious octane booster will solve my question, if it is the fuel type or cam/head/valve/intake limit..
Old 05-16-2017, 01:11 PM   #47
cosbySweater
cosbySweater's Avatar
Straight up always seems to have the best curve, grosspolluter did a write-up on it iirc
Old 05-16-2017, 02:35 PM   #48
gsellstr
Vintage anti-ricer
gsellstr's Avatar
And that was what, 425whp on a 9:1 B21FT before the freeze plug incident? Pretty respectable.
FWIW the max lift will depend on both the springs (coil bind) and the lobes clearing the head. You can always clearance the head (pretty sure Hank Scorpio had to clearance his a little for lobe clearance), but you will need to look at the coil bind situation.
RIP
74 144 B20
90 745Ti
Old 05-16-2017, 03:42 PM   #49
Pro Sneaker Peddler
As far as stock cams go this is true. Evidence also suggests that the RSI cams like less advance, but who knows without degreeing.
Old 05-16-2017, 09:31 PM   #50
cosbySweater
It would be interesting to see with the split duration cams they offer.
