Old 10-13-2010, 12:24 AM   #76
rally240
so quick info about cooling systems. 1) NEVER RUN YOUR CAR WITHOUT A THERMOSTAT! a trick is to cut out the spring part, for serious engines. 2) Changing the Radiator cap will change the pressure in the cooling system thus changing the boiling point. 3) Freeze plugs are a part of an engine build up, which should be done by people who know what the heck they are doing! 4) It is very important to remove the air from the coolant if it is starting to boil. 5) If you have blown a properly installed freeze plug you have done more damage to then engine then just that. 6) NEVER RUN YOUR CAR WITHOUT A THERMOSTAT! over cooling can do just as much damage as over heating.
rally240 is offline   Reply With Quote
Old 10-13-2010, 12:39 AM   #77
qwkswede
faster than you think
I do remember reading about freeze plug loss in road racing vintage Volvos with B18s and B20s, which have the same style freeze plugs as the B21/23. And that seemed to be high rpm problems. It does seem to be way more common in boosted Volvo motors though. Its not like people are making this up.
I do have a pressure gauge that I can install. I think I'll try to have it ready for the next dyno trip. Its time to get a little more scientific about this.
-Ken
1967 Volvo 122S
1992 Volvo 244 driver
Old 10-13-2010, 01:47 AM   #78
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
qwkswede....what kind of motor and tranny mounts are you running?
Old 10-13-2010, 03:06 AM   #79
smokeyfan1000
Guest
Only problem I've ever seen, runing V8s without a T stat, was that it never got to a good Operating temperature. Would stay about 160F-170F. Lots of Florida guys run with no T Stat in V8s.
So engine oil keeps moisture in it, because OT is always lower than WT, at least in an N/A engine. +t I do not know, suspect oil would get much hotter than n/a .
Old 10-13-2010, 12:32 PM   #80
qwkswede
Im running the hydraulic 740 motor mounts. And a GM stock rubber trans mount. Nothing overly stiff.
Old 10-13-2010, 12:48 PM   #81
nathaninwa
nathaninwa's Avatar
mine are hella stiff. gm poly tranny mounts at all 3 locations. if you look in the dyno video.....my motor does not move. i was thinkin of all the vibration could be dampened a little by softer mounts the problem might lessen. but your already runnin em. and im going to switch to them.
Old 10-13-2010, 01:05 PM   #82
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I had a single poly motor mount in mine when it cut loose (both times), I'm back to OE rubber now, at least for the moment.
Like I said in my first post.. in my case I'm not ruling out installation issues as well as other mitigating factors.. i.e. the blown headgasket on the dyno. and if fool up there wants to argue about sudden pressure increases and what "should give" and what "should not give", and cannot understand why shucking a hg at high rpms would cause sudden exit of ajacent freeze plugs, then fool above should not be allowed to continue in this discourse... I can promise that the 'instantaneous' pressure at the back of the engine when this occurred was substantially higher than 11 psi (closer to 30 + cylinder pressure), and nothing came out of the radiator cap. Think about compressibility and time frames for events like this:
you blow the gasket into the jacket and instantly that part of the cooling system is over-pressurized some 200psi +-. Water as most know, does *not* compress much at all, and you've just added half a liter of compressed air right there.. it will immediately start pushing and trying to get out/go where ever and at that point the closest pressure release points are the rear two freeze plugs as well as the freeze plug at the back of the cylinder head. All of which exited stage left in a terrific display of coolant and steam. the pressure wave from the back of the engine never made it to the coolant reservoir, never popped the "11 psi safety valve".
I have a spare 2.5 bar pressure sensor, maybe I'll hook it up to the proefi and datalog some pressures at various points in the cooling system, and see what's up.
Megasquirt Tuning!
Old 10-13-2010, 01:30 PM   #83
leslie_s
Originally Posted by smokeyfan1000 View Post
I tend to think freze plug problems(if they are correctly installed) are most likely due block flex/vibes.Are not most of you guys having these problems running turbo boost pressures(& HP) way above what Volvo probably intended for these engines/blocks to stand? Especially when they get to be 18+ years old?
DO not most hi-perf V8 engine builders go to brass threaded freeze plugs for engines intended to run way above OEM intended HP engine blocks, figuring they will add a bit of rigidity in the freeze plug area, above the OEM press ins?
Actually, no. My dad built a couple of high performance v8s, and the last one he did was quite extreme....actually put out as much horsepower as some of these turbo brickers....500 at the crank.... No brass threaded freeze plugs. However, the first step was always the machine shop. They take the freeze plugs out, clean the block, get all the old paint and grase out, magna flux the block, and put brand new freeze plugs in.
Also, he was running a 190 degree thermostat. Never had a problem except once when he forgot to turn the water pump on....heheheh....always wondered why he didnt hook that into the ignition switch. Now, that particular engine was never ran on the street except a couple of times, drag track engine only. However, his smaller ones, which are more similar to a turbo brick in power, were ran extensively on the street..NEVER had a problem with freeze plugs. Never ran cooler thermostats either.
Anyway, boost itself is not going to increase the pressures in the cooling system. The boost does not get there...
i drive a 2008 Jeep Wrangler
Originally Posted by cancer man View Post
On May 21st 2011, the official majority language will be Hispanic in the great U.S.A. Adios Gringo.
leslie_s is offline   Reply With Quote
Old 10-14-2010, 02:18 PM   #84
williamb82
as i said before, i dont run a thermostat in my 7mgte, however it reaches operating temp just fine. i use electric fans. the fan switch kicks on at 185deg and off at 170. when on the interstate the fans never run. in traffic, they cycle on/off on a reg basis. i guess it depends on the engine. in the volvo case, you guys have some sort of bleed back port i wasnt aware of. my engine doesnt have this and runs fine except it takes alot longer to warm up when cold outside. but its cold here so rarely that it isnt an issue. i just wait till the temp gauge reads at least a 1/4 of the way before i drive anywhere, cold or hot outside.
williamb82 is offline   Reply With Quote
Old 10-15-2010, 11:19 AM   #85
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Alot of this conversation seems to go towards reducing the waterpumps effectiveness to reduce pressure at high rpm. If this is localized boiling causing a pressure spike, the only solution to this is Increased flow to the area of localized boiling. If you look at this photo of the group A head closer, they have drilled several smaller holes next to the cylinders. presumably to balance flow and coolant temps across the head.
Originally Posted by NotSoFresh View Post
It appears the coolant flows all the way from one end of the head to the other without these holes in a factory head, correct me if Im wrong.
It makes me think of the water manifold used in houses to balance pressure.
By adding pathways you add flow capacity, and prevent pressure spikes by having a balanced flow, resulting in no hot water scalds in the shower from a toilet flushing...... I imagine, the increased coolant turbulance in the head due to these holes might force stagnant overheated coolent out of the nooks and crannys of the head better, helping eliminate any hot spots there are.
Old 10-26-2010, 02:53 PM   #86
RS1
RS1's Avatar
Note on using pure propylene glycol, such as Evans.
http://www.uponone.com/howtos/15.pdf
If you are able to keep the water temp below boiling point of water, pure deionized water with some kind of additive with corrosion inhibitor effect like Water wetter would be the best (If your climate allow for this). If you engine have the tendency to boil, Evans coolant is an option or a mixture of anti freeze and water.
RS1 is offline   Reply With Quote
Old 10-26-2010, 04:58 PM   #87
RESURRECTED
back from the dead.
RESURRECTED's Avatar
are you guys making sure the system has no bubbles? via vacuuming down the system, and adding coolant under vacuum?
my brick hauls ass on its jack stands
RESURRECTED is offline   Reply With Quote
Old 10-27-2010, 10:52 AM   #88
mikep
The MP
mikep's Avatar
I do know that Smokey Yunick slowed the flow on water in the block on his NASCAR BBC engines. Said it was pumping too fast. But now they same the opposite.
Nobody is overdriving water pumps in a race app. NASCAR engines run 2:1, or on the big tracks, 3:1 underdrive ratio. They also run a high pressure system.
...edit...
A V8 is not nearly as stressed as a 4cyl at that HP.
And if a head gasket leak allows cyl. pressure into the jacket, it becomes a high pressure problem.
That is silly.
Originally Posted by miguels244 View Post
*edit: running around screaming MAGA Clinton cats Ben Gazi.
Originally Posted by ovlov760 View Post
Ya know, if the FBI wasn't spending so much time on the Trump Russia stuff, maybe they could clean up after their dog.
Old 10-27-2010, 10:59 AM   #89
smokeyfan1000
Guest
Butthere are a lot of hi flow capacity WP on the market today.
Smokey restricked the hole in water neck/Tstat hsg to 3/4" IIRCC. to slow flow.
Old 11-01-2010, 09:28 PM   #90
DustyLBottoms
DustyLBottoms's Avatar
That is silly.
They do it at the factory for Porsche.
'90 745t - TD04HL-13T, Custom ground cam , V90 Interior, V90 Moonroof, T-5 Swap. Sold!
'00 Lincoln LS - V6, Sport, Getrag 221.
DustyLBottoms is offline   Reply With Quote
Old 11-02-2010, 12:11 AM   #91
RESURRECTED
back from the dead.
actually, its standard for a lot of shops... i've been a tech for a good number of years, and have run into this problem on many vehicles. air pockets can cause some serious issues. vacuuming it down and adding coolant take care of it, especially in such a poorly designed system like these are.
most shops have tools for this, and makes it far easier then regular fill anyway.
Old 11-02-2010, 12:08 PM   #92
smokeyfan1000
Guest
Smokey's theory was that if the coolant flows too fast, it wouldn't absorb the heat as well. Seems it worked for him in NASCAR for many years.
Old 11-02-2010, 01:39 PM   #93
qwkswede
Its really only a problem in cars with awkwardly designed engine and cooling system layouts. The long pipes between the engine and radiator in a Porsche make this necessary. Its just not that complicated in a Volvo engine compartment. Air goes up, water goes down.
Old 11-02-2010, 02:20 PM   #94
RESURRECTED
back from the dead.
air goes up, water goes down... except when water is being pushed by at a rapid rate. forcing large bubbles into smaller ones and carried around causing then to heat and expand in unexpected areas.
sure once the engine is off, they collect back where they normally would.
I've seen this happen many times, and have seen some a lot of over heating in a otherwise perfect cooling system, once pushed hard.its really nothing new.
Old 11-02-2010, 06:04 PM   #95
Poik
Backwards Turbo
Poik's Avatar
This is a great thread to have as a sticky. Seems like lots of people are having cooling issues and this is one of the areas that does not have a cut and dry recipe for success yet.
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 11-03-2010, 10:07 PM   #96
nathaninwa
nathaninwa's Avatar
When my head gos back on, Ill be going back to the larger of the volvo pulleys to help cooling at idle in traffic (its about an inch smaller than the one I have right now). Ill also be installed the solenoid vavle that is tied into the rearmost head port, and Im thinking about T'ing into the stbd side pipe plug behind number 2 exhaust...something smaller tho, like 1/4 tube which is smaller than 3/16 on the ID......just to eliviate some water from the front of the block too under boost/rpm.
Old 11-12-2010, 12:51 AM   #97
wennstroma
Here is a picture of a new Volvo water pump, they have switched to a stamped impeller. Not sure if it is just a cost reduction thing though. Says made in UK, but no other maker markings.
wennstroma is offline   Reply With Quote
Old 11-12-2010, 03:41 PM   #98
mikep
The MP
mikep's Avatar
We are still talking about this?
Generally, it only saves time on an initial fill when the system is completely drained. If coolant blocks an air pocket, it just expands the pocket, then allows it to contract again. unless you are filling your cooling system in space.
The best way is to use the bleed screw if so equipped, then take your time and allow all the bubbles to migrate to the top of the reservoir, tank, etc.
That silly theory (I never saw any proof that he believed it, but lots of car guys tell that tale)about the speed of coolant was wrong. He slowed the pump so he could make power. Everything he did was in the interest of making power. Power first, longevity second. That's why he was so good.
Toyota's current NASCAR engine does not even have a housing for a thermostat. Big pulley for most tracks, huge pulley for superspeedways, heat the hell out of the oil prior to qualifying but leave the coolant alone, only shut it off if it gets really hot, but about 20 deg. F cooler than the best teams.
Old 11-12-2010, 07:37 PM   #99
745 TurboGreasel
745 TurboGreasel's Avatar
I have driven multiple 'statless cars that ran cool around town, but would overheat on a spirited drive up the mountain.
This completely cured by installing a thermostat, even one with the pill clipped out.
Feedback
Old 11-12-2010, 08:38 PM   #100
buzz
To inspamity, and beyond!
buzz's Avatar
I've been putting pumps with that impeller design on for years and they always seemed to work well. I picked up a new GMB a couple weeks ago for the 940T just to have on hand and now their new pumps have been internally redesigned/reshaped and are running this impeller:
Originally Posted by Råda View Post
I usually don't get compliments on my penis from guys, but thanks!
I used to be indecisive. Now I'm not so sure.
The Phoenix
buzz is offline   Reply With Quote
