Old 09-08-2011, 03:44 AM   #76
Mylesofsmyles
Yay moar movin partzzzz...
This is the orientation I had in mind...but yes, that'd require a twin sided ribbed belt and the alternator DOES run backwards, or am I missing something.
Originally Posted by T3hw1nn3r View Post
only for hers i need to stop drinking so much.
Drink too much and you'll really need those ribs to give her any sense of pleasure.
Old 09-08-2011, 03:44 AM   #77
Mylesofsmyles
Old 09-08-2011, 07:52 AM   #78
T3hw1nn3r
T3hw1nn3r's Avatar
Trust me, I still get **** from the ONE time i fell asleep
Originally Posted by ErikS View Post
Who is this Max Boost guy and why are you running from him?
1991 b230f+t AW71 + Accumulator mod
MSD + blaster2 coil
ebay 57trim @ 8-12psi
stock block, head, intercooler
42lb delphi injectors high rez(too small)
RSI stage 2 turbo cam
The Build Thread
T3hw1nn3r is offline   Reply With Quote
Old 09-08-2011, 10:11 AM   #79
DMFWallace
Ignoramus Bigotus
Do want.
'90 244 - Too many memories to crush
'92 944T - Need any 940 parts?
'96 854 GLT - Not mine any more but still in the family
'92 245 - Current Daily
'97 854R - Totaled by a drunk driver
'06 XC90 V8 - Family Hauler - Wifemobile
Feedback:http://forums.turbobricks.com/showth...ght=dmfwallace
DMFWallace is offline   Reply With Quote
Old 09-08-2011, 08:43 PM   #80
lookforjoe
lookforjoe's Avatar
This (my) alternator is running backwards, based on the arrows indicating normal rotation. 00'- alternators are designed for this specific belt routing, so those are not running backwards as they are designed to run CCW.
My XR July2013 - 446AWHP @ 8K rpm
Old 09-08-2011, 08:52 PM   #81
Mylesofsmyles
Cuzz, the 00- can do the moonwalk? go forwards'n'backwards?
The 01+ have a fixed rotation?
Just want to be clear.
Old 09-08-2011, 09:05 PM   #82
srbliss
Does this 850 setup get rid of those blasted rubber bushings on all of the accessories? This alone would make it worth the swap.
srbliss is offline   Reply With Quote
Old 09-08-2011, 10:32 PM   #83
DCOE 240
DCOE 240's Avatar
YES All the rubber bushing are gone it's all mounted rigid.
DCOE 240 is offline   Reply With Quote
Old 09-08-2011, 11:02 PM   #84
lookforjoe
lookforjoe's Avatar
As far as I know, 99- use the CCW rotation, clutch style alternator.
Old 09-08-2011, 11:02 PM   #85
srbliss
That is good news indeed. I need a new AC compressor so now is the time to swap to a modern drive. Is it a Ford water pump (hard to imagine) or just the pulley?
Steve
Old 09-08-2011, 11:21 PM   #86
Mylesofsmyles
Which is NOT what we want, right???
Dayummmmm, that's cool about the bushinzzzzz
Old 09-09-2011, 06:25 AM   #87
Juggernot
Taking myself seriously.
Juggernot's Avatar
But, the clutch can be replaced with a regular pulley, and then the alt. can turn the other way.
Juggernot is offline   Reply With Quote
Old 09-09-2011, 12:56 PM   #88
DCOE 240
DCOE 240's Avatar
It's just the pulley from a ford rear wheel drive 4 cal. I little bit of machining but not much. I also think a pulley from a long chevy water pump 350 style will work also but some spacing would have to be changed. Hopefully this weekend I will get some more photos posted
Old 09-10-2011, 12:25 AM   #89
lookforjoe
lookforjoe's Avatar
If you route the belt such that a dual rib belt is required (as with mine), of course allowing for the addition of the WP on the right/center, then you DO want the CCW alternator (whether it's clutch pulley or not), since air flow through the alt is likely more of an issue with RWD setups.
Old 09-10-2011, 12:53 AM   #90
larry818
larry818's Avatar
It seems Bosch only worries about rotation if the alt comes with a fan...
http://www.bosch.com.au/content/lang...Starters_A.pdf
larry818 is offline   Reply With Quote
Old 09-10-2011, 11:04 AM   #91
lookforjoe
lookforjoe's Avatar
All these alternators have fans - they are just internal F&R of the casings, instead of old style external
Old 09-12-2011, 11:12 PM   #92
DCOE 240
DCOE 240's Avatar
Here is a photo of the belt with the roation suggested. Works out great belt can be the same length or a little shorter. Only problem is the single sided belt is $25.00 and double sided is like $75..
[IMG][/IMG]
Old 09-12-2011, 11:16 PM   #93
DCOE 240
DCOE 240's Avatar
Here are a couple of photos of the brackets.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 09-12-2011, 11:27 PM   #94
DCOE 240
DCOE 240's Avatar
double post
Old 09-12-2011, 11:55 PM   #95
Mylesofsmyles
I'd still like one of these please.
Got all my 850 stuff waiting to go...got my PS pump, Alternator and A/C compressor, along with some, well, now useless single-sided belts, a tensioner and the bracket.
Did you say something about modifying the 850 bracket? If so, do you have a detailed picture?
Old 09-17-2011, 06:20 PM   #96
DCOE 240
DCOE 240's Avatar
Ok so double sided belts are hard to come by. The single sided belt I was using was 83 1/4 inch which worked on the alternate routing. Could be an inch shorter or so. The only double sided belt I could find was a dodge caravan 2000 which is like 79". I think this will work if I raise the tensenor arm a little. Have to wait till next week to try it out.
Old 10-09-2011, 10:48 PM   #97
DCOE 240
DCOE 240's Avatar
Finally got it done. Found a double sided belt. They don't make as many sized in the double sided as the single side. Had to move the tensioner and modify it a bit. Here is a couple photos of the new routing and belt.
If anyone is interested in the parts I'm going to make a post in the for sale forum.
Old 10-10-2011, 12:33 AM   #98
Texas240
Prius Owner
Texas240's Avatar
this is fantastic except for 16v guys like myself. The 16v gear is wider so everything else wont align up exactly unless you can find a way to space the tensioner/bracket for the power steering/ Alt/ and AC Compressor out a little farther front engine wise
93 245 LS Engine Swap Project
Old 10-10-2011, 02:40 AM   #99
Angus242164
Angus242164's Avatar
Some late model VW's and Peugeot's use double sided belts, that may be a source of suitable belts for this project.
Originally Posted by Dauntless View Post
Boost FTW.
I have over 300 parts for sale to suit 100, 200, 700 and 900 series Volvo's, for more info see: http://zyrex.org/gallery/Cars/acw/volvoparts/
Updated April 21st 2016.
Angus242164 is offline   Reply With Quote
Old 10-10-2011, 03:56 AM   #100
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
now you need only a chainbeltdrive for the cams and your engine will be maintainencefree ;)
