Old 10-10-2011, 04:22 PM   #101
DCOE 240
DCOE 240's Avatar
Everything could be moved out for the 16v how far are you talking.
DCOE 240 is offline   Reply With Quote
Old 10-10-2011, 04:46 PM   #102
lookforjoe
lookforjoe's Avatar
Originally Posted by DCOE 240 View Post
Finally got it done. Found a double sided belt. They don't make as many sized in the double sided as the single side. Had to move the tensioner and modify it a bit. Here is a couple photos of the new routing and belt.
Nice Work! That looks great - much better contact area on the crank pulley.
My XR July2013 - 446AWHP @ 8K rpm
Old 10-10-2011, 05:42 PM   #103
Texas240
Prius Owner
Texas240's Avatar
3-5mm I would have to double check then triple check that
Originally Posted by MadDog_945 View Post
now you need only a chainbeltdrive for the cams and your engine will be maintainencefree ;)
I love it, So let me do that math here for the redblock. Never change the oil "check" Never add coolant "check" Never change the Belts "check"
93 245 LS Engine Swap Project
Old 06-17-2012, 11:06 PM   #104
DCOE 240
DCOE 240's Avatar
Ok its been a while but I have a couple of new photos. I switched back to a single sided belt and turned the grooves off of the alt pulley. I ran the belt over the idler pulley and over the alt.That gives a lot of belt wrap around the crank.
Also I made a crank pulley that will fit a b230 motor.
Ive been running this set up for quite some time now and have had no problems. Also I changed my cam to a b cam so Ive had a lot higher revs and its smooth as silk. I still haven't figured out the ac lines but thats next.
Old 06-18-2012, 01:11 AM   #105
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
Nice, glad to see you got a b230 solution.
962j 815/692@27psi
THIS IS FORSALE V
Old 06-18-2012, 09:22 AM   #106
turbojose
let us know if you decide to make the brackets and crank pulleys available to the masses....
turbojose is offline   Reply With Quote
Old 06-28-2012, 11:03 PM   #107
DCOE 240
DCOE 240's Avatar
I have a parts list together and am willing to help with the modification for a nominal fee just send me a pm and we will talk
Old 08-14-2013, 01:34 AM   #108
Mylesofsmyles
I put one of Aaron's setups on my 16vt motor...
I had the pulley milled down 5mm, to compensate for the wider timing belt. All looks to be in order, though the motor has not been fired yet.
Old 05-14-2014, 05:15 PM   #109
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Any further developments on this?
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 06-02-2014, 02:39 PM   #110
Råda
Volvoretard/Partshoarder
Råda's Avatar
Jonas
Old 05-01-2015, 01:56 AM   #111
BritishBrick
BritishBrick's Avatar
Thread bump and would like to know if you would make/sell another?!
Best
T
BritishBrick is currently hoarding parts for a vert 16v monster like half of the rest of you..
Fo Sale Thread : http://forums.turbobricks.com/showthread.php?t=276795
Wanted Thread : http://forums.turbobricks.com/showthread.php?t=254940
Feedback Thread : http://forums.turbobricks.com/showthread.php?t=242385
BritishBrick is offline   Reply With Quote
Old 09-28-2015, 06:54 PM   #112
Chilm
Double Dutch
Chilm's Avatar
Default Come on folks.
Bumpiedoptiedoo
Nathan, Yoshi, come in please, where is the kit?
I should buy
Double Dutch - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 01-27-2016, 01:33 AM   #113
klr142
Turbo, what?
klr142's Avatar
Originally Posted by Chilm View Post
Bumpiedoptiedoo
I should buy
Agreed!
Old 01-27-2016, 10:57 AM   #114
DMFWallace
Ignoramus Bigotus
Yeah I'm tired of spraying my V belts with silicone spray every week to keep them quiet..
'90 244 - Too many memories to crush
'92 944T - Need any 940 parts?
'96 854 GLT - Not mine any more but still in the family
'92 245 - Current Daily
'97 854R - Totaled by a drunk driver
'06 XC90 V8 - Family Hauler - Wifemobile
Feedback:http://forums.turbobricks.com/showth...ght=dmfwallace
DMFWallace is offline   Reply With Quote
Old 04-15-2017, 11:07 PM   #115
jmc0369
jmc0369's Avatar
And the list of interested, willing to pay customers keeps on growing.
Bump.
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
Old 04-15-2017, 11:15 PM   #116
57plymouth
57plymouth's Avatar
This is a club I can join. Availability?
Old 04-15-2017, 11:38 PM   #117
Buy some 9.5mm Roulunds belts from volvo.
Bump.
I think DCOE 240's out of the game as well.
Old 04-16-2017, 01:09 PM   #118
Mueller
Mueller's Avatar
Bump.
I was supposed to get some parts from Jack to start making a set for him and myself, I'll send him a PM and harass him.
Old 04-17-2017, 10:20 AM   #119
jmc0369
jmc0369's Avatar
Sweet! Tuned in to the developing situation.
Old 04-17-2017, 12:02 PM   #120
culberro
culberro's Avatar
I know it's a bit out of the T-brickers budget at a whopping $250 for the WP/Alt/PS, but this already exists....
https://shop.klracing.se/sv/artiklar...2-2/index.html
It's on sale if you want it in blue: https://shop.klracing.se/sv/artiklar...juls-sats.html
The crank pulley is around $130, and they even make them with a bolt pattern for a tone ring.
Old 04-17-2017, 12:10 PM   #121
More than a month's tweak money for something unnecessary that's gonna be a slow go.
Old 04-17-2017, 01:05 PM   #122
Mueller
Mueller's Avatar
Easyoff oven cleaner will remove the blue
I'd want hard anodized or steel if a daily driver, of course not as critical as a timing belt as long as the belts don't slip.
Old 04-21-2017, 04:31 PM   #123
jmc0369
jmc0369's Avatar
No response from Jack?
Old 04-21-2017, 04:46 PM   #124
Last Activity: 04-01-2017 12:12 PM
Old 04-21-2017, 08:12 PM   #125
jmc0369
jmc0369's Avatar
You must know something I don't. Jack ain't coming back?
